Old 2nd April 2009, 02:56   #781  |  Link
hlrsnd
Originally Posted by MrC View Post
From AviSynth documentation:
If you are saving in mp3 format, AVISource should be able to open it. For more info, please post here the log file of your crashed AVStoDVD project.
Bye
I tried some more tests and the problem appears to be solved. It was a strange one: My file names had the text "AVISource" in them. Your program cannot use AVISource for AC3 audio, so it appears to automatically change every instance of AVISource to DirectShowSource. Unfortunately, in my case, that meant the Avisynth script was looking for audio in a file that didn't exist.
My solution was to rename AVISource in my file names to AVIS. Everything seems to work now.
hlrsnd is offline   Reply With Quote
Old 2nd April 2009, 09:43   #782  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
AVISource cannot read AC3 audio, so AVStoDVD forces DirectShowSource if AC3 audio (to be encoded) is found. It adds a comment to the script:
#'AVISource' replaced with 'DirectShowSource' for AC3 audio support
Could you post your AVS script or (better) the entire log file?
Bye
MrC
AVStoDVD Homepage
AVStoDVD @ Doom9 Forum
MrC is offline   Reply With Quote
Old 3rd April 2009, 02:31   #783  |  Link
hlrsnd
Bye
Here is the log file with my comments. The file name includes the text "AVISource" which is causing the error.
<4/2/2009 9:22:53 PM>
START PROCESS
DVD SETTINGS
DVD Titles number: 1
DVD Video Standard: PAL
DVD Chapters Interval: 5 min
DVD Menu: Static DVD Menu
DVD Size: 8/4435 MB (0%)
DVD Output Setup: DVD Folder
Delete Temp Process Files: Yes
Delete Working Files: Yes
Edit Command Parameters: No
Save Log file: Yes
Output Folder: D:\Dave's Documents
TITLE 1 SOURCE FILES
Video: D:\Dave's Documents\TEST AVISource.avi
Info: M-JPEG - 14400 kbps - 640x480 - DAR 1.333 - 30 fps - PPF - 6 seconds - 202 frames
Audio: D:\Dave's Documents\TEST AVISource.avi
***AUDIO FILE NAME IS CORRECT HERE***
Info: PCM - 705 kbps - CBR - 44100Hz - 1ch - 6 seconds
Subs:
[MediaInfoLib - v0.7.10]
AVISYNTH SCRIPT
Video = AVISource("D:\Dave's Documents\TEST AVISource.avi", audio=false)
Video = Video.ConvertToYV12
Video = Video.ChangeFPS(25)
Video = Video.Lanczos4Resize(720,576)
Audio = DirectShowSource("D:\Dave's Documents\TEST DirectShowSource.avi")
***AUDIO FILE NAME HAS BEEN CHANGED BY PROGRAM***
Audio = Audio.SSRC(48000)
Audio = Audio.ConvertToMono
AudioDub(Video, Audio)
START VIDEO ENCODING OPERATIONS
Encoding Profile: QuEnc CBR 1-pass
Target Video FileSize: 7.1 MB
QuEnc Parameters: -i "C:\DOCUME~1\Dave\LOCALS~1\Temp\TEST_0_Title_01.avs" -o "D:\Dave's Documents\TEST_0_Title_01.m2v" -b 8500 -1 -hq -novbr -scene -trell -aspectratio 4:3 -nointerlaced -mpeg2mux noaudio -dc 10 -priority 5 -auto -close
<4/2/2009 9:23:04 PM>
PROCESS ABORTED DURING TITLE 1 VIDEO ENCODING OPERATIONS.
CHECK LOG FILE <D:\DAVE'S DOCUMENTS\TEST_0.LOG> FOR MORE INFO.
Log file created by AVStoDVD Release 2.1.4
Old 3rd April 2009, 07:38   #784  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Thanks, you found a little bug in the AVS script analisys routine.
I will fix in next release
Bye
MrC
AVStoDVD Homepage
Old 7th April 2009, 02:31   #785  |  Link
carlmart
Carlos Martinez
I'm getting this:
Run-time error '383'.
'Text' property is read-only.
What might be happening and what can I do to solve it?
It happened both in versions 2.1.3 and 2.1.4.
carlmart is offline   Reply With Quote
Old 7th April 2009, 19:11   #786  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Well, the message is very generic. Could you specify when it happens? If the cause is sistematic is much better.
Bye
MrC
AVStoDVD Homepage
Old 9th April 2009, 11:58   #787  |  Link
carlmart
Carlos Martinez
Well, I have a DVD that I demuxed, both with PgcDemux and DGIndex, and when I load the files I get that message. It doesn't happen with other files I loaded.
Old 10th April 2009, 20:22   #788  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
You are saying that you have 2 files: one m2v and one ac3, do you? When does the error message come out? When you add them to the titles list? Or when you try to edit the title?
Bye
MrC
AVStoDVD Homepage
Old 10th April 2009, 21:44   #789  |  Link
rendez2k
rendez2k's Avatar
I think I've asked a similar question before, but is there anyway to edit the avg video bitrate for all the added files in one go? I've added 17 videos and it would be handy to be able to globally set them to the value I need.
rendez2k is offline   Reply With Quote
Old 11th April 2009, 02:12   #790  |  Link
carlmart
Carlos Martinez
I get to load the file, but when I click on Edit Title settings I get that message.
Old 11th April 2009, 15:02   #791  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
@calmart
What kind of audio/video streams are contained in the file that gives you the error?
@rendez2k
No way right now to set one bitrate for all (17! wow!) titles. Actual best approach is to play with 'Custom DVD Size' to find the filesize that fit the wanted bitrate.
Bye
MrC
AVStoDVD Homepage
Old 11th April 2009, 19:40   #792  |  Link
carlmart
Carlos Martinez
@calmart
It's an m2v file that was demuxed from the DVD with PgcDemux.
Old 12th April 2009, 16:10   #793  |  Link
Richardw322
audio delay problem
I have a little problem here with audio sync. I have aAVI file with XVID video and AC3 audio, and when I try to create a DVD, the audio is out of sync. I can't preview and use delay because no audio in the preview. Is this a limitation of AVS2DVD, or is there some other workaround? I guess I could make a pass and then use FFDshow to figure the delay, and then make a second pass, but that seems a little involved.
Richardw322 is offline   Reply With Quote
Old 12th April 2009, 16:24   #794  |  Link
wg
Run your files through AVI-Mux GUI before conversion to DVD, if there are any sync issues they will show up & AVI-Mux GUI will fix the problem(Read the online manual)
http://www.alexander-noe.com/video/amg/
Good Luck.
wg is offline   Reply With Quote
Old 12th April 2009, 22:37   #795  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
@calmart
And the audio stream? Is it an AC3? I would try to reset AVStoDVD settings by pressing 'Option'/'Restore default settings'.
@Richardw322
wg' suggestion is good. BTW another path (that will lead to audio re-encoding) could be: go to 'Settings'/'AudioVideo' and toggle off 'Keep DVD compliant audio'. Audio preview will be activated and you can play with 'DelayAudio'.
Bye
MrC
AVStoDVD Homepage
Old 12th April 2009, 23:51   #796  |  Link
carlmart
Carlos Martinez
There's no AC3 stream to be loaded: the file is demuxed. The video I am loading IS the demuxed video.
Pressing "Option'/'Restore default settings" just deletes my input.
Old 13th April 2009, 17:03   #797  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
You are saying that you are loading a single m2v file without audio? It should be an easy scenario...
Could you please take a shot of the main AVStoDVD form with the error message box and post it here?
Bye
MrC
AVStoDVD Homepage
Old 13th April 2009, 23:13   #798  |  Link
Richardw322
wg, That worked a charm. Made a great DVD.
MrC: Another good suggustion, that would have worked. Another question. I like to make DVD's with a single title, but a menu. That leaves me with a play all button, and the thumbnail button. Seems redundent to me. Any way to get rid of one or the other? I tried shrinking the thumbnail to 4x2, but then I get "Can't resize image" on the menu. (Made that damn thing 4 times yesterday before I was happy with it, between the audio and the menu).
Thanks guys!
Old 13th April 2009, 23:58   #799  |  Link
carlmart
Carlos Martinez
OK. Here it is the error message screen,
http://forum.doom9.org/attachment.ph...1&d=1239663373
What can you make of it?
Old 15th April 2009, 11:43   #800  |  Link
carlmart
Carlos Martinez
Sometimes when I press the Preview Title Output button, what I get is an upside down image.
This usually turns out right when conversion is finished. But I had some (rare) cases when this doesn't happen.
Why's that and what (script line?) puts things back as they should?
[IMG] code is Off
