23rd June 2007, 17:39 | #42 | Link |
Wewkiee
The diff link on that thread gives an error message. couldnt get get the patch file
Also.. I just use diff/patch from zlib . this works, although it produces slightly different looking patch files (although they work). what svn app are you using?
...yeah...but...why on earth would I compare apples with apples? |
27th June 2007, 12:28 | #43 | Link |
Errr... if you were asking me, I use Tortoise.
the whole thing is new to me. It's easy to select to diff and patch files but applying is confusing because source files have changed since the patch were created. So at that point I'm not too sure what to do. |
30th June 2007, 22:03 | #44 | Link |
Wewkiee
i should have out a threaded version with aq/hrd/pulldown for 663 by tomorrow. svn command line seems to work the best for me thanks
1st July 2007, 19:07 | #45 | Link |
Wewkiee
ok.. check the sourceforge page. 663 checkout with aq hrd pulldown and pthread-w32 .
will put up a combined hrdpulldown patch in a day or so
2nd July 2007, 01:29 | #48 | Link |
Wewkiee
663b up! I compiled and tested it properly in debug mode.. then when i switched to release i missed a step. sorry. This one works.
2nd July 2007, 05:14 | #50 | Link |
Testeur de codecs
mp4 and mkv output is completely useless here. This build produce HDDVD/BD compliant stream and these stream must be ES.
Le Sagittaire ... ;-) 1- Ateme AVC or x264 2- VP7 or RV10 only for anime 3- XviD, DivX or WMV9 |
2nd July 2007, 11:28 | #54 | Link |
if your interested i have another head scratcher for you:
i am finding the timecodes of the hrd build 663 arent adding up to what i see as the correct timecode output from cinevision. to test that theory i put the resulting .264 through your h264info app and applied 29.97fps to it. now that shouldnt have really changed anything right as it should have been pulldown 29.97 to begin with. but after processing it into cinevision it gave the exact same timecode as the cinevision result which i believe is correct. heres a screenie of what i mean below, the properties you see shows the .264 file is 29.97 but the time is out by about 11 frames. |
7th July 2007, 16:50 | #58 | Link |
There's something else going on since the thread support was added. There is an audio sync issue with builds after 616c. The audio falls out of sync half way through the movie. It's in sync for the first half, then out of sync by about a second for the entire second half.
Using the same command line with 616c the audio is fine. I'm starting another encode with 663c without threads to see if it's the threads or something else with the new builds. I see the timing is different for both streams using Streameye. At frame 100,000, the old version is 1:09:30 while the new (out of sync) version is 1:09:49. I haven't tested 663d yet because it won't run on the PC I use for encodes. |
7th July 2007, 20:50 | #59 | Link |
Wewkiee
i built 663e now w/out gpac so give that a whirl. (i tested it on a virtual pc window that wouldnt run 663d but does run 663e)
7th July 2007, 20:56 | #60 | Link |
Using 663b without --threads 2 results in OK audio, so it appears to be a threads problem. With threads, the problem starts approximately halfway through my 206,000 frame test movie.
Nice work so far. This is already one of the few ways to reliably get video into scenarist. If we can have threads, I'd prefer it over Cinevision. |
