26th May 2007, 12:23 | #2241 | Link |
Crop Only
Hello. I try to encode some DVD's and I only want the blackbars cropped, so that I can set aspect ratio in mkv and have the image displayed as it should. But the "Crop Only" option automatically adds a resize to 720 in the end of the script. Is there a way not to resize at all.
Also, if I check the "Anamorphic encode" then the final mkv is the wrong aspect ratio (is very tall) |
26th May 2007, 13:08 | #2242 | Link | ||
HDConvertToX author
@delacroixp
from avisynth manual Quote:
your formula for 29.97 to 25 should be this (100.0*30.0*1001.0)/25000.0 @pdanpdan Quote:
if you don't want any at all resizer you must use the manual crop fuction (setting all values, but width/height... leave 720*576) AND set in main panel NONE as resizer about anamorphic: as a previusly said the fuction is under testing and not supported (and btw when using anamorphic encode ... the actors are very tall always) BHH
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 |
27th May 2007, 11:16 | #2243 | Link |
Emperor building empire
@buzzqw
Zoom, VLC and MPC player can't find the 'SegmentInfo' (see post).
I'm going to try a 2-pass based on a 10% decrease on the 21-CQ-CRF encode... Pascal /************************** EDIT ***************************** /* I ran out of disk space... incredible... 30 MB from a complete mux... /* I re-ran the mux.bat and all is well... though the video does 'feel' a bit odd... /************************************************************ Last edited by delacroixp; 27th May 2007 at 11:29. |
27th May 2007, 17:41 | #2245 | Link |
HDConvertToX author
@delacroixp
never seen this error .. could you post a sample ? BHH P.S. finally added AR error in preview panel!
27th May 2007, 21:41 | #2246 | Link |
Here you can see content of DVD disk.
Numbers are for absolutely different video files on this dvd, which you can choose in menu. I would like you encode all of them one by one. But when I open VTS_04_0.IFO for some strange reason it opens VTS_05_0.IFO and encode only this file. Not the first one. Also if I open VTS_06_0.IFO it still opens VTS_05_0.IFO. Why? What should I do? Here is photos. Step by step: Opening And the result |
28th May 2007, 02:08 | #2247 | Link | |
Forum Member
However, wanted to know if you could tell me what I'm missing as "LimitedSharpenFaster" comes back as no function. I thought adding the import of "LimitedSharpenFaster.avsi" would fix it but it doesn't seem to help. Is there a declared .dll needed? Also, can seesaw and LSF be used together? From the looks of this post they can but I wasn't sure. This is what I came up with: Code:
avisource("C:\Documents and Settings\Desktop\test3.avi") LoadPlugin("C:\Documents and Settings\Desktop\VirtualDub\plugins\EEDI2.dll") LoadPlugin("C:\Documents and Settings\Desktop\VirtualDub\Avisynth Scripts\SeeSawSharpen\MaskTools-v1.5.8\MaskTools.dll") LoadPlugin("C:\Documents and Settings\Desktop\AutoMKV 0.84b\exe\Filter\hqdn3d.dll") LoadPlugin("C:\Documents and Settings\Desktop\AutoMKV 0.84b\exe\Filter\RemoveGrainS.dll") LoadPlugin("C:\Documents and Settings\Desktop\AutoMKV 0.84b\exe\Filter\RepairS.dll") LoadPlugin("C:\Documents and Settings\Desktop\AutoMKV 0.84b\exe\Filter\UnDot.dll") import("C:\Documents and Settings\Desktop\VirtualDub\Avisynth Scripts\SeeSawSharpen\SeeSaw.avs") import("C:\Documents and Settings\Desktop\VirtualDub\Avisynth Scripts\SeeSawSharpen\Soothe.avsi") import("C:\Documents and Settings\Desktop\VirtualDub\Avisynth Scripts\SeeSawSharpen\Base.avs") import("C:\Documents and Settings\Desktop\AutoMKV 0.84b\exe\Filter\LimitedSharpenFaster.avsi") # Not sure if needed a= last b=a.hqdn3d() SeeSaw(a,b, NRlimit=3, NRlimit2=4, Sstr=1.5, Slimit=5, Spower=5, Sdamplo=6, Szp=16) EEDI2().TurnRight().EEDI2().TurnLeft() Spline36Resize(852,480) Last edited by Seraphic-; 28th May 2007 at 02:40. |
28th May 2007, 07:22 | #2248 | Link |
HDConvertToX author
@vorob
this is a normal behavior of automkv when selecting a ifo file, automkv will look in this folder for a bigger file and then select this ifo. This is done because the main film has usually the biggest ifo If you want to select a specific ifo you must , in order, open automkv, go in advanced settings and check Use this IFO, then in main panel select your ifo other solution is to put every group of vts is a specific folders BHH
28th May 2007, 10:37 | #2249 | Link |
No it is not working. It opened first file, but when I’ve opened preview I saw only first part of this file only VTS_04_1.VOB. Also when I’ve started encoding, I received this
Same happens when I put all files from video 1 in different folder. Opens only first part and I receive this error. By the way, AutoGK opens and encode exactly what I ask, but you understand that Xvid is a bad thing )) |
28th May 2007, 12:11 | #2250 | Link |
HDConvertToX author
this message have nothing to do with automkv
this message is given by dgindex i suggest to look at dgindex manual for fixing these transitions then use the corrected dv2 file as input for automkv BHH
28th May 2007, 12:32 | #2252 | Link | |
HDConvertToX author
and it work if i encode only the audio but since is not possible (there aren't command line muxer) to mux wmv video and wma audio together in new wmv file... i must encode audio WITHIN the video file When encoding within video i can use the directshowsource or the wavsource but the 5.1 file audio got borked in new avisynth 2.58 (alpha) there are some workaround ... i hope to get 5.1 fuctional BHH
28th May 2007, 17:34 | #2254 | Link |
I have a resolution question:
A file that I encoded is coming out as a 4:3 encode. It's originally 16:9. The original resolution/aspect is 720*480/16:9 but when I encode it AutoMKV changes it to 720*576/5:4 (at least this is what mediainfo tells me when I check the encode. I left the resolution at original. When I check the original in Avinaptic it says: Code:
Resolution: VERY HIGH (720 x 480) Width: multiple of 16 (GOOD) Height: multiple of 16 (GOOD) [ Video track ] Codec ID: V_MPEG4/ISO/AVC Resolution: 720 x 480 Frame aspect ratio: 3:2 = 1.5 Pixel aspect ratio: 853:720 = 1.184722 Display aspect ratio: 853:480 = 1.777083 (~16:9) Framerate: 23.976024 fps Im not sure if Im making any sense here LOL, or if im even really understanding what im reading. But.... My question is, How do I keep it widescreen when I encode? I've tried resizing it to 704*400, 1280*720 (for PS3), and Original and the picture always comes out squeezed. Original File Encoded file keeping original resolution avinaptic output of original file avinaptic output of encoded file Last edited by esso; 28th May 2007 at 17:44. Reason: Posted incorrect pics |
28th May 2007, 18:27 | #2255 | Link |
Here's the complete output from avinaptic after I encoded the file:
[ About file ] Name: Appleseed [Movie] 2004.mp4 Date: 28/05/2007 04:27:05 Size: 1,875,999,736 bytes [ Generic info ] Play duration: 01:45:25 (6324.841666 s) Container type: MP4/MOV Major brand: ISO Base Media version 1 Compatible brands: JVT AVC Creation time: 27/05/2007 08:22:59 UTC Modification time: 27/05/2007 08:22:59 UTC Number of streams: 2 Type of stream nr. 1: video (avc1) {GPAC ISO Video Handler} Type of stream nr. 2: audio (mp4a) {GPAC ISO Audio Handler} Audio streams: 1 [ About quality ] Resolution: VERY HIGH (720 x 576) Width: multiple of 16 (GOOD) Height: multiple of 16 (GOOD) [ Video track ] Codec: avc1 Resolution: 720 x 576 Frame aspect ratio: 5:4 = 1.25 Pixel aspect ratio: 1:1 = 1 Display aspect ratio: 5:4 = 1.25 Framerate: 23.976023 fps Number of frames: 151643 Bitrate: 2208.240315 kbps [ Audio track ] Codec: mp4a Bitrate: 161.199606 kbps Channels: 2 Sample rate: 48000 Hz [ About H.264 encoding ] User data: x264 User data: core 54 svn-654M User data: H.264/MPEG-4 AVC codec User data: Copyleft 2005 User data: http://www.videolan.org/x264.html User data: cabac=1 User data: ref=3 User data: deblock=1:0:0 User data: analyse=0x1:0x131 User data: me=umh User data: subme=6 User data: brdo=1 User data: mixed_ref=1 User data: me_range=16 User data: chroma_me=1 User data: trellis=1 User data: 8x8dct=0 User data: cqm=0 User data: deadzone=21,11 User data: chroma_qp_offset=0 User data: threads=1 User data: nr=0 User data: decimate=1 User data: mbaff=0 User data: bframes=3 User data: b_pyramid=0 User data: b_adapt=1 User data: b_bias=0 User data: direct=3 User data: wpredb=1 User data: bime=1 User data: keyint=250 User data: keyint_min=25 User data: scenecut=40 User data: rc=2pass User data: bitrate=2208 User data: ratetol=1.0 User data: rceq='blurCplx^(1-qComp)' User data: qcomp=0.60 User data: qpmin=10 User data: qpmax=51 User data: qpstep=4 User data: cplxblur=20.0 User data: qblur=0.5 User data: ip_ratio=1.40 User data: pb_ratio=1.30 SPS id: 0 Num ref frames: 4 PPS id: 0 Entropy coding type: CABAC Weighted prediction: No This report was created by AVInaptic (06-03-2007) on 28 mag 2007, h 13:24:28 |
28th May 2007, 18:54 | #2256 | Link |
HDConvertToX author
your source file is mkv and automkv don't know the AR of these file
automkv could extract correct ar from mpeg files not mpeg4 files like .avi/.ogm/.mkv... i suggest to use in advanced settings "Force Mux AR" and set it to 16:9 also.. look at encoding log file... what is written in mkvmerge command line ? BHH
28th May 2007, 19:46 | #2258 | Link |
HDConvertToX author
yep.. i hope! (try with a small sample...)
BHH
29th May 2007, 02:21 | #2259 | Link |
Learning To Fly
Hey buzzqw do you think that i used an .avs script with the loadsubtitles script in it automkv would work and harsub it correctly?
AutoMKV - The New Alternative to AutoGK with X264 and MP4/MKV |
