21st June 2017, 22:34 | #44161 | Link |
Whenever my TVs display gets turned "off" after Windows power manager kicks in if I attempt playback the audio plays as normal but madVR displays only a frame or few, I have to rewind or forward for madVR to continue as normal.
Anyone else experience this on graphics other than Nvidia? Using W10. Last edited by ryrynz; 21st June 2017 at 22:38. |
22nd June 2017, 21:51 | #44162 | Link |
How do I enable the stats display of each processing filter under rendering in the CTRL+J OSD? (as I see it on some screencaps)
I tried a search but couldn't find it. I also try enabling the debug mode using the batch script and that didn't work. Thanks |
22nd June 2017, 22:00 | #44163 | Link |
don't use the debug version of madVR. it just replaced the madVR version with a debug version that creates a log on your desktop which multiply GB big.
for the advanced render steps option you need to created a new file or folder in the madVR folder with the name "showrendersteps". don't use this for playback and use this to judge performance. it can lower performance. |
22nd June 2017, 22:44 | #44166 | Link | |
22nd June 2017, 22:46 | #44167 | Link | |
The source really is native 50i, to confirm here is a second screenshot I made of today's broadcast with LAV forced to weave (the 'Disabled (Progressive)' deinterlacing setting): https://drive.google.com/open?id=0B2...Uh6T3B3d3ltQW8 If you zoom in, in the background of the newsroom on the pillars and the screens hanging off them you can see the combing interlace effect. I'll try getting screens this weekend of sport programming using madVR and deinterlacing on/off to provide another compare.
HTPC: Windows 10 22H2, MediaPortal 1, LAV Filters/ReClock/madVR. DVB-C TV, Panasonic GT60, Denon 2310, Core 2 Duo E7400 oc'd, GeForce 1050 Ti 536.40 |
22nd June 2017, 23:03 | #44168 | Link |
If deinterlacing is actually on, there is a "dxva queue" in the OSD, as well as a "dxva" entry in the "stats" section.
Try playing a interlaced file where it should definitely be working.
23rd June 2017, 13:21 | #44172 | Link |
Hi @madshi,
Mediaportal got compatible to MadVr from the last release: https://www.team-mediaportal.com/new...1-16-0-release guys from the testing/dev Mediaportal forum agree to kindly ask you if would be possible to add Mediaportal to your homepage list of supported players. https://forum.team-mediaportal.com/t...in-mp1.133972/ Thank you |
23rd June 2017, 16:57 | #44174 | Link |
between lav settings of hw decoding: no hw decoding through dxva, which of them the "proper/right way" for madvr?
because i've got trouble when using sw decoder and somehow my gpu got idle and playback got heavy framedrops. the only work around with this that i can think of is changing nvidia setting to maximize performance instead of optimal (default) |
23rd June 2017, 21:06 | #44177 | Link |
To all 1080 (non-Ti) users:
' Can you guys play the LG 4K HDR demos at the link below without frame drops using a 1080 and Madvr at 60p? I'm using LAV video decoder with DXVA-CB HW decoding enabled for UHD and HEVC but I'm still getting frame drops. These files are 4K HEVC with HDR @59.94fps but I'm sure the 1080 can handle it? MadVR - chroma upscaling = Bilinear, dithering = ED2, FSE D3D11 (required for HDR), nothing else enabled Nvidia driver 378.92 Windows 10 64bit Anniversary Edition (1607) http://demo-uhd3d.com/categorie.php?tag=hdr |
24th June 2017, 00:09 | #44179 | Link | |
ERIC Last edited by egandt; 24th June 2017 at 01:24. |
24th June 2017, 01:32 | #44180 | Link |
Odd, I can play "The_World_in_HDR_in_4K_HDR10.mkv" downloaded from that link on my Titan XP (it was at 2038MHz).
This was the OSD during the final credits after watching the entire video, reset right after playback started.
madVR options explained |
