13th August 2006, 11:08 | #2481 | Link |
clueless n00b
The command you posted is for the commandline version of svn.. if you're using tortoisesvn all you need to indicate is the url of the svn repository of megui, so presumably https://svn.sourceforge.net/svnroot/megui (I have very little experience with svn but I got it working somehow)
13th August 2006, 13:06 | #2482 | Link |
Mr. Sandman
So, anyone knows if there's an OSS lib for FTP that supports PASV mode?
13th August 2006, 14:31 | #2483 | Link | |
When birds burp, it must taste like bugs! (Calvin&Hobbes) |
13th August 2006, 17:16 | #2484 | Link | |
sound engineer
Double change of volume.
13th August 2006, 19:32 | #2485 | Link | |
clueless n00b
14th August 2006, 14:21 | #2487 | Link |
Mr. Sandman
0.2.3.2186 Commit by Doom9 - mp4box / mkvmerge got new split commandlines, adapted megui accordingly - dgindex reports video % instead of film % when video % > 50 starting with v1.4.8, adapted megui to not apply forcefilm in such a case - reshuffled menu shortcuts, megui no longer uses standard shortcuts like CTRL-A/C/V/X - Changelog now has its own dialog - Introduced a help menu with links to the megui wiki and the support forum - Renamed Vorbis container to Ogg since that's the container's name Code:
0.2.3.2187 Commit by Sharx1976: - Cosmetic fixes (part 2...)
14th August 2006, 18:32 | #2488 | Link |
clueless n00b
I'm looking at the profile bug (new profile overwrites the currently selected one) and I'll go for the update button so that it'll be clear to everyone when a profile is updated.
Just one thing.. should pressing OK update the currently selected profile? And if not.. then I guess the profile shouldn't be returned to the main window, should it?
14th August 2006, 23:29 | #2489 | Link | |
If the nero aac encoder is the main reason (so we can update it from megui as well), do you know about ncftp ? (a crossplatform, opensource, command line ftp client) http://www.ncftp.com/ncftp/ There is a 168 KB program in the package called ncftpget that will do the trick (and it knows passive connection). http://www.ncftp.com/ncftp/doc/ncftpget.html |
15th August 2006, 06:06 | #2491 | Link |
I don't know if anyone has had a look at the refactor branch I made, but I see a whole lot of big changes going on in MeGUI. However, since it will take a while, can you say again what changes you want to make? Then I can tell you how much they are likely to interfere with what I want to do.
15th August 2006, 07:24 | #2492 | Link |
ангел смерти
Well, GUI changes, mostly referencing or changing values between the classes/panels - if they're going to be changed significantly it'll be a little pointless to do the binding work now. Particularly integrating the AVC options into the panel better, some xvid zone plumbing, and the profiles manager; and also splitting the profiles box into per-codec profiles.
I did look at your changes, but I'm not qualified to comment, honestly - I'm learning from you guys there. For the future, what do you guys think of every codec being a dll? Too complex for the benefit of adding new codecs on the fly? |
15th August 2006, 07:57 | #2493 | Link | ||
Can you explain what you mean by 'splitting the profiles box into per-codec profiles'? Does this mean sorting by codec, or creating a list-view instead of a combo-box, or what do you have in mind? Cheers, berrinam |
15th August 2006, 10:51 | #2494 | Link |
ангел смерти
Repopulating the combo box whenever the codec selected changes. Probably remembering the last selected profile with that codec.
It'll be interesting then, having essentially every class in its own dll. Are you going to call the zips .jar too? Looking forward to see what shows up. |
15th August 2006, 11:48 | #2495 | Link | |
BeHappy/MeGUI developer
BeHappy - AviSynth-based audio transcoding tool Audio encoding via AviSynth On2 VP7 is great in quality but it is unusable for long-term video backup puposes! Sincerely Yours, MCPD/MCTS |
15th August 2006, 19:31 | #2497 | Link | |
Mr. Sandman
i just prefer integrating the FTP capability into MeGUI.
16th August 2006, 03:00 | #2498 | Link |
Mr. Sandman
0.2.3.2188 - Cosmetic fixes (part 3...) - Swapped Crop and Resize controls position in Avisynth Script Creator window to better represent the correct workflow
16th August 2006, 09:21 | #2499 | Link | |
PS. I'm planning to return to active MeGUI development next month. Currently I'm too busy @ my primary work + I'm preparing for futher certification... PS2. Now I'm
16th August 2006, 11:05 | #2500 | Link |
clueless n00b
@dimzon: you are doing certification wise what I ought to be doing at work.. but they keep me so busy I never get around to doing it.
You may want to have a look at this issue though: http://forum.doom9.org/showthread.ph...813#post863813 At the end of the line I suspect the script returns RGB32 which never will work, but I'd expect some kind of a useful error instead of a crash.
development, megui, not a help thread |
