Old 13th December 2004, 12:41   #301  |  Link
blutach
Country Member
blutach's Avatar
@rolz
In the same spirit as removing the Ctrl for menus, can we also do it for "Trace". Now, it is Ctrl-T, where T alone would do fine, n'est pas?
I actually think that none of the "Ctrl's" in the file menu are necessary, except for perhaps R for reload and S for Save (don't wannna do them accidentally)
Regards
Les
Only use genuine Verbatim or Taiyo Yuden media.
blutach is offline   Reply With Quote
Old 13th December 2004, 14:45   #302  |  Link
r0lZ
PgcEdit daemon
r0lZ's Avatar
... and B for Create Backup.
OK. I will change them...
r0lZ
Old 13th December 2004, 20:27   #303  |  Link
blueboyec
move angels
rOIZ,
Is PgcEdit able to remove angles (keep one angle) and correct all referances to angles (have the DVD seam as thought it was never a multy angle move)?
thanks
blueboyec is offline   Reply With Quote
Old 13th December 2004, 21:03   #304  |  Link
r0lZ
PgcEdit daemon
r0lZ's Avatar
No. PgcEdit is not a VOB editor.
Use IfoEdit's strip angle function.
r0lZ
Old 13th December 2004, 21:12   #305  |  Link
blueboyec
rOIZ,
Thanks for your quick responce.
Old 19th December 2004, 15:12   #306  |  Link
r0lZ
PgcEdit daemon
r0lZ's Avatar
PgcEdit 0.4.5
PgcEdit 0.4.5 released.
  • Added 'Remove Cell' button in the PGC editor.
  • Added "Clone PGC" function (works in Title and Menu domains)
  • PgcEditPreview version 1.4, by Jeanl.
  • Menu buttons viewer: It is now possible to hide the buttons by clicking on the background image. (Windows only)
  • Dummy PGCs in the title domain are now labelled with "(dummy)" instead of "(0:00)".
  • "New Dummy PGC" in title domain now create the dummy 'attached' to the current Title (ie, it inherit the current Title and TTN numbers.)
  • The Layer Break checkbox is now disabled in the Cells List of the PGC Editor when the Seamless flag must be kept OFF. Therefore, the checkbox is checked and enabled only for real layer breaks.
  • Renamed some labels of the Type Flags in the Cells list of the PGC Editor.
  • The Remapping VOB/Cell ID function in the Cells List now clears the Seamless Playback flags of the remapped cell and the following one.
  • The TTN numbers are now retrieved from the VTS_PGCITI table, instead of VTS_PTT_SRPT. This is more reliable.
  • Bug in "New 'Play All' PGC" function with wrong Category Mask and Parental ID Mask in the VTS_PGCITI table fixed.
  • Bug in VTS_PTT_SRPTI table when saving a DVD with illegal dummy titles.
  • Bug when launching both Preview and Menu buttons viewer at the same time fixed by Jeanl.
PgcEditPreview 1.4 by jeanl (Windows only)
  • Improved error reporting in bitmap saving mode.
  • Fixed a bug that prevented preview from loading some VOB files in bitmap saving mode.
  • The elapsed time was wrong in some cases (SCR discontinuity), I'm setting it to 0 if the audio pack has no PTS.
  • Fixed a bug that caused an image to be displayed in the improved bitmap-saving version of preview.
  • Rolled in most changes made by jsoto for vobblanker.
r0lZ
Old 19th December 2004, 19:23   #307  |  Link
blutach
Country Member
blutach's Avatar
Thanks rolz for another masterpiece
Rgds
Les
Old 19th December 2004, 19:31   #308  |  Link
blutach
Country Member
blutach's Avatar
A tip for PGCEdit users
When using the Calls Cross References utility to see which PGCs are not in use, it can be useful to do this in 2 or 3 passes.
Once you have found a PGC that is not called (it will be highlighted in pink - make sure you have the highlight errors and GOTO targets option set), simply delete all the commands (pre, post and cell) for that PGC. Do this for all such PGCs. Call cross references again and see if any more unused PGCs appear and delete their commands, and so on.
This particularly applies if you are (re)authoring your DVD, where I have found this technique very useful to see if I have any broken navigation links.
One warning! BOV has not been implemented in PGCEdit yet, so be certain your disk does not contain any BOV. If it does, do not use this technique.
Regards to all
Les
Old 19th December 2004, 20:08   #309  |  Link
jeanl
jeanl's Avatar
good one blutach, I"ll keep that in mind for looking for a free register....
Jeanl
A few PgcEdit guides.
DVDSubEdit a free tool to edit subtitles directly inside the vob.
jeanl is offline   Reply With Quote
Old 20th December 2004, 01:59   #310  |  Link
stickboy
AviSynth Enthusiast
Can pgcedit be run from network shares using UNC paths? If I do this, pgcedit.exe runs but no UI appears. (I do have write access to the network share.)
Is this related to the known issue with pgcedit requiring ASCII paths?
stickboy is offline   Reply With Quote
Old 20th December 2004, 02:32   #311  |  Link
r0lZ
PgcEdit daemon
r0lZ's Avatar
Humm. I really don't know. And I have nothing to test this situation.
Probably... The symptoms are the same.
This may be a problem with the freeWrap method of accessing internal, wrapped files, in the standalone version. Maybe you could try to install Tcl/Tk and the PgcEdit sources.
Sorry, I can't help much more.
r0lZ
Old 20th December 2004, 10:39   #312  |  Link
stickboy
AviSynth Enthusiast
You should be able to test it by enabling file sharing and accessing your own PC through a UNC path.
Old 20th December 2004, 18:12   #313  |  Link
blueboyec
Re: PgcEdit 0.4.5
[list][*] The Remapping VOB/Cell ID function in the Cells List now clears the Seamless Playback flags of the remapped cell and the following one.
r0lZ,
This this mean that I can use pgcedit to correct pointer etc that ifoedit/dvddecryter did not correct after useing ifoedit/dvddecryter to keep one angle?
Old 20th December 2004, 19:48   #314  |  Link
r0lZ
PgcEdit daemon
r0lZ's Avatar
No. PgcEdit now sets the SCR discontinuity flag, and removes the Seamless flag when needed by a function of PgcEdit (VOB/Cell ID remapping, and Remove Cell). It does not fix the wrong flags set by other programs.
But maybe I can add this in a future version. This will not be totally automatic, but will ask if it must correct the wrong flags when you enter the PGC Editor, for a specific PGC. (It will work like the Total Playback Time fix of the current version.)
Anyway, it will not fix ALL the flags and pointers... Sorry, but that is too much work!
r0lZ
Old 21st December 2004, 00:12   #315  |  Link
blueboyec
Tring to learn.
Thank for your effort.
Old 24th December 2004, 00:51   #316  |  Link
lovelegend
I don't know since when but now when I double-click a command line, there is no new dialogue window popped up for editing command, and the program freezes... I just tried downloading and running the older versions and found that there is no such problem for version 0.2.1... Does anyone know how could I fix this problem?
P.S. I'm using win2k
lovelegend is offline   Reply With Quote
Old 24th December 2004, 00:57   #317  |  Link
jeanl
jeanl's Avatar
I downloaded the current version yesterday, running XP, all is OK on my side...
Jeanl
Old 24th December 2004, 01:19   #318  |  Link
r0lZ
PgcEdit daemon
r0lZ's Avatar
@lovelegend
This is the first time I hear of that problem.
Furthermore, the Command Editor has not been changed in the last version. So, maybe the problem is coming from your PC, a virus or something like that...
PS. Have you tried to launch the editor by single-clicking on the command, and then selecting the menu Edit -> Edit Cmd, or the Edit Cmd button?
r0lZ
Old 24th December 2004, 02:01   #319  |  Link
lovelegend
I know it's my PC problem, I think it got the problem after a crash or something. It may be caused by a corrupted dll file or so, that's why I would like to ask if anyone knows about it...
However, I don't wanna reinstall the os again...
Before I worked around this problem by adding a NOP command in pgcedit, and then use IfoEdit to edit that command... but now it's better since I can use version 0.2.1 to edit the command directly, though it makes the problem being more weird -- how comes it works on 0.2.1 but not newer (I remember 0.3.8 worked fine for me, but now it doesn't work either)?
And yeah, I tried using menu Edit -> Edit Cmd, or the Edit Cmd button, and both didn't work... ^^"
Old 24th December 2004, 04:02   #320  |  Link
r0lZ
PgcEdit daemon
r0lZ's Avatar
Well, one thing has changed between v0.2.1 and newer versions. It's the way config files are saved.
In v0.2.1, the config file was "C:\Documents And Settings\<your user name>\.pgcedit.cfg".
In 0.3 and more, the config files are stored in "C:\Documents And Settings\<your user name>\Application Data\PgcEdit\".
You may try to verify that the Application Data directory exists and is writable. (Note that it may be hidden. To see it, you may have to enable the "Show hidden files and folders" option in Windoze's Folder Options, View tab.)
If the PgcEdit folder is there and is writable, try to delete the .pgcedit.cfg file, and restart PgcEdit 0.4.5.
Let me know if it worked. Thanks.
r0lZ
