12th April 2010, 20:48 | #3943 | Link |
Aging Video Hobbyist
Or it does what Smartlabs wants-or-needs, for now at least. It seems to be one of those things where nothing happens for a long while, and then the OP works madly on it for a few weeks, then goes away again.
13th April 2010, 07:28 | #3944 | Link |
Hello everyone,
Not sure if this topic is still relevant or not... but I'm trying to use tsmuxer on linux to mux .mkv to .m2ts. After generating the meta file and running tsmuxer I keep getting a "Can't detect stream type" error and I'm not sure how to fix this. I'm trying to do this all in console as I just ssh into my linux machine. Hopefully someone might be able to shed some insight on how to get this working. It would be real sweet if I could do this! Cheers, - M -
- Matrix905 - |
26th April 2010, 15:37 | #3945 | Link |
NY Frame of Mind
For subtitles, where does tsmuxer get the default fonts from and can I add a font(s) ?
Edit: turned out that just installing a new font in the windows font dir makes it available in tsmuxer. I had asked because Avatar uses the papyrus font for the na'vi speaking parts.
"Talk to me Goose" Last edited by rapscallion; 26th April 2010 at 17:50. |
30th May 2010, 18:20 | #3949 | Link |
Hi, is there a way to demux the hole movie sound from a movie even if thereīs seems to be spreed on different m2ts fileson the dvd? Tried with TsMuxed, but it didnt collect hole movie sound only the present one out of the m2ts!?
Is there a tool to exktact DTS-HD, DTS and/or AC3 from a movie even if its on several m2tsīs ? Please help ! P.S works like a charm when movie sound is in only one (1) m2ts. |
30th May 2010, 18:28 | #3950 | Link |
Programmer (or just 教务长)
You'll have to find the correct movie PLAYLIST (mpls) and import it in tsMuxeR. Do not use single M2TS files.
Use BDinfo or some other tool to determine which MPLS file holds all information about the movie and import it. Then you can demux/remux only the video/audio/subtitles or extract the SD core of HD-audio tracks. Dean |
30th May 2010, 18:57 | #3951 | Link | |
31st May 2010, 19:45 | #3953 | Link |
There is no way, unless you parse and rewrite the m2ts files.
Of course - an easier way would be to insert "blank" streams (audio/subtitles) in place of the removed ones. Much easier to go that way. multiAVCHD does that in re-author mode. |
22nd June 2010, 20:57 | #3955 | Link | |
Thanks. Mike. |
23rd June 2010, 02:25 | #3956 | Link | |
I was planning on simply pulling the complete stream and inserting into the M2TS with adjustments to packet timing. But your way sounds better. Last edited by jdobbs; 23rd June 2010 at 02:28. |
23rd June 2010, 08:18 | #3957 | Link |
http://forum.doom9.org/showthread.ph...35#post1358535
To keep it short, you replace those streams with shorter versions ( 200ms video/audio streams ). I uploaded there an archive ready to be used. multiAVCHD can do this if you want to blank some intros or even audio streams. This is only done for keeping menu functions. |
23rd June 2010, 09:05 | #3958 | Link | |
23rd June 2010, 09:42 | #3959 | Link | |
MUXOPT --no-pcr-on-video-pid --new-audio-pes --vbr --vbv-len=500 --blu-ray V_MPEG4/ISO/AVC, "main_video.mkv", fps=23.976, insertSEI, contSPS, track=1, lang=eng A_DTS, "main_video.mkv", track=2, lang=eng V_MPEG4/ISO/AVC, "secondary_video.m2ts", fps=23.976, insertSEI, contSPS, track=4113, lang=eng, secondary A_AC3, "secondary_video.m2ts", track=4352, lang=bul A_AC3, "secondary_video.m2ts", track=4352, lang=bul, secondary the audio will be muxed with primary PID (0x1101). To use secondary audio you'll need to rewrite the m2ts files, mpls and clpi. Dean Last edited by deank; 23rd June 2010 at 09:51. |
23rd June 2010, 09:49 | #3960 | Link | |
One can create such small file for DTS audio, too. Dean |
tsmuxer |
