Old 30th October 2009, 22:32   #8981  |  Link
mrcorbo
Originally Posted by Thunderbolt8 View Post
hm I still havent understood what this is good for (bitstreaming) or what this adds to what these cards cannot do now. isnt it already possible to pass all those lossless sounds through HDMI? or only LPCM and for truehd & dts-hd programs like pdvd9 & TMT have to be used? am confused :S
The one definite advantage added with bitstream support is DTS-MA decoding. With no open-source decoder for DTS-MA, the only way to play this back in full quality is by using a commercial product (and/or it's included filters) or by sending the bitstream to a receiver for decoding. Other than that, it seems to come down to a personal preference for some to have the decoding done in the receiver.
mrcorbo is offline   Reply With Quote
Old 30th October 2009, 23:10   #8982  |  Link
liquidskin76
liquidskin76's Avatar
Originally Posted by SamuriHL View Post
albain is working on adding bitstreaming support for the ATI cards in ffdshow.
Not just the ATI cards but also Nvidia HDMI audio on Geforce 9300/9400 motherboards!
I've got this funny feeling that we're very close!
@Albain/SamuriHL,
I'll be ready to test on my 9300 when the next beta is ready.
Cheers
liquidskin76 is offline   Reply With Quote
Old 31st October 2009, 03:41   #8983  |  Link
Snowknight26
Originally Posted by rica View Post
Decided to have an AVR (HDMI 1.3) and an Ati 5770 to take in the trials
Learn to use the edit button please, there's no need to post twice in a row.
Snowknight26 is offline   Reply With Quote
Old 31st October 2009, 03:44   #8984  |  Link
whurlston
Bitstreaming currently only works with TMT on the Xonar. Adding bitstreaming capabilities to ffdshow would allow you to use other DirectShow programs (MPC-HC, MediaPortal, GBPVR, etc) to bitstream TrueHD/DTS-HD.
whurlston is offline   Reply With Quote
Old 31st October 2009, 07:33   #8985  |  Link
Snowknight26
Still have this really annoying bug with Fraps videos that's only fixed by using RGB output.
YV12:
YUV2:
RGB32:
RGB16:
NV12:
The strange edge on the right side is my main concern (as opposed to the banding).
Old 31st October 2009, 08:49   #8986  |  Link
Sebastiii
sebastiii, what about Ati?
I'm busy for now, i will try tonight
Thx
Seb.
HTPC : i7 920 6Go Win10(x64) / Nvidia 1050Ti / P6T Deluxe / Harman-Kardon AVR-355.
Sebastiii is offline   Reply With Quote
Old 31st October 2009, 10:29   #8987  |  Link
liquidskin76
@Albain/SamuriHL,
Cheers
Potentially any HDMI 1.3 audio card will be able to use the HD audio bitstream version of ffdshow, as long as the source files are decrypted.
Old 31st October 2009, 16:59   #8988  |  Link
XhmikosR
@devs: I'm getting 186 errors when building ffdshow x64 rev3121 with MSVS 2008, all pointing to xvidcore. Does anybody else have the same problem?
EDIT: Another question. Now the only stuff that are built with GCC are ffmpeg, ffmpeg-mt, mplayer and x264. Is this going to stay this way?
My Specs
XhmikosR is offline   Reply With Quote
Old 31st October 2009, 18:09   #8989  |  Link
tal.aloni
XhmikosR. I don't have any problem, try to clean the solution.
thanks for your builds by the way, impressive speed (up time).
tal.aloni is offline   Reply With Quote
Old 31st October 2009, 18:21   #8990  |  Link
XhmikosR
Did you try with rev3121? The problem is only with the x64 build of xvidcore. I always use /Rebuild to avoid any conflicts.
It would be much easier for me if I could find a way to automatically patch files. For example this patch which I use in order to use komisar's x64 GCC.
I use patch -i "ffdshow_makefile_inc.patch" and it does not work. It drives me crazy!
My Specs
Old 31st October 2009, 18:27   #8991  |  Link
Thunderbolt8
got a H.264 capture here which shows video corruption with ffdshow (v3119). plays fine with coreavc though.
50mb sample: http://www.sendspace.com/file/qltp8n
Old 31st October 2009, 18:38   #8992  |  Link
XhmikosR
@Thunderbolt8: your sample plays fine with libavcodec. But using ffmpeg-mt it indeed does not play right. Using ffdshow rev3121.
My Specs
Old 31st October 2009, 19:46   #8993  |  Link
tal.aloni
I have tested 3121 x86, I haven't tested x64.
Old 31st October 2009, 19:52   #8994  |  Link
XhmikosR
Then, that's why you don't have any problems, like I don't, for the x86 build.
My Specs
Old 1st November 2009, 00:14   #8995  |  Link
Thunderbolt8
yup, you are right. seems like it play just about fluently for me with only using 1 core. but it would be nice if this problem could be forwarded to the developers in case similar stuff might occur in the future with higher bitrates, then I'd have a problem :S
apart from that there seems to be a problem with .mkv remuxing using eac3to here, but thats another story.
Old 1st November 2009, 00:53   #8996  |  Link
Keiyakusha
契約者
Keiyakusha's Avatar
Hi. I have troubles with decoding this AC3 file using libavcodec in ffdshow. The audio is distorted... Have no troubles with it using MPC-HC internal decoder or ffdshow liba52. I'm using ffdshow r3122 icl11 x86. However things are the same with some previous revisions.
Old 1st November 2009, 02:58   #8997  |  Link
avivahl
Works well w/ 3114 generic. Maybe it's an ICL11-specific issue?
EDIT: my bad. AC3 decoding wasn't on libavcodec here. Same bad results. Distorted audio.
avivahl is offline   Reply With Quote
Old 1st November 2009, 03:03   #8998  |  Link
XhmikosR
It does gives distorted output when using libavcodec for AC3. It happens with both generic and ICL11 builds.
My Specs
Old 1st November 2009, 03:55   #8999  |  Link
Keiyakusha
契約者
Keiyakusha's Avatar
it looks like this is ffmpeg problem.
I can normally decode audio using ffmpeg SVN 19894, but with svn 20421 I have a bunch of errors like:
[ac3 @ 0x2268070]error decoding the audio block
[ac3 @ 0x2268070]exponent out-of-range
and audio distorted in the same way...
EDIT:
ffmpeg-r20024 -> fine
ffmpeg-r20060 -> distorted
Old 1st November 2009, 05:10   #9000  |  Link
Mr VacBob
My dual-core system is in repair for a week; I'll check it, but might not be able to until then.
Mr VacBob is offline   Reply With Quote
