27th January 2010, 12:52 | #11566 | Link |
In theory I think 24P playback on 23HZ refresh rate should be smooth during most of time especially when you use Sync renderer, but we've found that it doesn't work well when you have dual monitors and aero enabled. I think a lot of people use two screens and run 24P on TV/60HZ on monitor.
27th January 2010, 12:58 | #11567 | Link | |
_
Just to sum up: I'll try 1920x1080 24Hz, with Aero; I'll try madVR then EVR Sync (40 minutes videos). Today or tomorrow |
27th January 2010, 13:07 | #11570 | Link |
_
When you're in dual screen,
Aero seems to not support if one screen is in 60Hz and other in another refresh rate. So yes, it is rather recommended to disable desktop composition if you're in dual screen and you use different refresh rates. But without Aero it's possible you have tearing... |
27th January 2010, 13:08 | #11571 | Link |
Most of today's TV sets claim to have a variaty of "motion pulldown" algorythms implementated to make the movement smoother ,I'm wondering if they're useful for a 23.976 fps source to a 50 or 60 Hz TV dispaly,for example. I mean if we should keep all those sync. settings in MPC-HC ,reclocks ,and any others procedures or just let the TV to make that job....or both?
I'm asking that because I want to buy a full HD TV set for watching HD movies. All my consideration to all the developers of the MPC-HC. They all make a great job! |
27th January 2010, 13:32 | #11572 | Link |
For MadVR, you cannot disable Aero otherwise you get tearing all the time. The only option is to disable one monitor.
For sync renderer, it should work with dual screen no aero, but there was some problem when I disabled desktop composition in r1557, ar-jar will fix it hopefully. Last edited by somy; 27th January 2010 at 13:40. |
27th January 2010, 13:34 | #11573 | Link | |
Anyway let's know the result, cheers! |
27th January 2010, 13:37 | #11575 | Link | |
You probably need frame creation, my AE3000 has that feature and it works better. The idea is to output pure 24P to TV and let TV to do the rest work (pull down or frame creation). Last edited by somy; 27th January 2010 at 13:40. |
27th January 2010, 13:48 | #11576 | Link | |
I get perfect playback with MPC-HC/madVR/ffdshow/Reclock. It might be worth a try. |
27th January 2010, 13:56 | #11577 | Link | |
1. if you turn off aero it works 2. if you use single monitor it works. |
27th January 2010, 14:19 | #11579 | Link | |
ReClock does synchronization for you. BTW, you don't have tearing when aero is off? What version of MPC-HC do you use? Last edited by somy; 27th January 2010 at 14:27. |
