Old 18th October 2005, 00:26   #61  |  Link
Sirber
retired developer
Sirber's Avatar
ShowMessage(MediaInfo_Get(handle, 1, 0, 'ID', 1, 0));
... gives me nothing on MKV
General
Complete name        : Y:\Animes\E155-001.mkv
File size            : 7.97 MiB
Format               : Matroska
Overal BitRate       : 742 Kbps
PlayTime             : 1mn 30s
Date                 : UTC 2005-10-14 13:24:19
Video #0
Codec                : V_MPEG4/ISO/AVC
Width                : 640
Height               : 480
Aspect ratio         : 4/3
Audio #0
Codec                : AAC LC
[edit]
In fact, all other new flags gives me ''
Detritus Software
Sirber is offline   Reply With Quote
Old 18th October 2005, 10:36   #62  |  Link
Zenitram
Originally Posted by Sirber
BTW, do you have a paypal link?
https://www.paypal.com/xclick/busine...name=MediaInfo
Or if you prefer to donate with SourceForge :
http://mediainfo.sourceforge.net/Help
Want to know all about your media files? http://mediaarea.net/MediaInfo
Zenitram is offline   Reply With Quote
Old 18th October 2005, 13:20   #63  |  Link
Zenitram
Have you tested DLL v0.7.0.2 (do not work on v0.7.0.1...)? I tried with some MKV files, and it works
Note : for Debugging, I need the "debug" output (Debug-->Advanced mode) to have all indicators.
But, maybe the best is to use private messages for debugging...
Old 18th October 2005, 13:37   #64  |  Link
Sirber
retired developer
Sirber's Avatar
I got the 0.7.0.2b. I will make more tests. Do you have msn?
Detritus Software
Old 22nd October 2005, 21:07   #65  |  Link
Sirber
retired developer
Sirber's Avatar
problems with "Language". In Martoska, japanese is "jpn" while MI gives me "ja". Any clue why?
Detritus Software
Old 23rd October 2005, 14:13   #66  |  Link
Zenitram
iso639 : http://www.w3.org/WAI/ER/IG/ert/iso639.htm or http://www.loc.gov/standards/iso639-2/frenchlangn.html
In MediaInfo, I use for all containers the 2-character iso639-1 code.
If the container use the 3-character iso639-2 code (like matroska), I translate it in iso639-1 (if possible, 99.99999% of cases ;-) ).
The 2-character code of Japanese is "ja".
So, if you read a DVD or an AVI or a Matroska file, Japanese will always be "ja", not sometines "jpn" and sometimes "ja"!
Old 23rd October 2005, 15:28   #67  |  Link
Sirber
retired developer
Sirber's Avatar
ok, thanks! I will convert
Detritus Software
Old 4th November 2005, 02:01   #68  |  Link
Sirber
retired developer
Sirber's Avatar
Hi
I would need a "releasable" version RealAnime LE alpha 3 is coming to store near you
Detritus Software
Old 4th November 2005, 07:41   #69  |  Link
Elias
MPEG-4 Crazy Lunatic!
Elias's Avatar
Originally Posted by bond
tags are a special issue in mp4 because there is an official tagging standard for mp4, but the power of itunes (which uses a private tagging way) lead to that people use only the itunestagging
and as always private stuff leads to a mess...
i would say there are two good mp4 libs available: the one from mpeg4ip and the one from gpac
mpeg4ip tags in the itunesway, gpac i think in the official mpeg way (but i have to admit i never really tested it so i dunno much about it)
Is there any explanation about this on the Gpac site (I've never found anything similar on gpac.sf.net)? Any commands for MP4Box?
Elias is offline   Reply With Quote
Old 4th November 2005, 12:40   #70  |  Link
bond
i never really tried mp4box' meta options, you might want to talk to jeanlf about this
Ogg Theora | Ogg Vorbis
Old 7th January 2006, 02:55   #71  |  Link
LAIN
RealAnime dev
LAIN's Avatar
I'm a realanime dev and i'v incounter a problème using media info dll. We extract FPS to make sure that the output will be correct.
with few files (that have a fps of 29.96999 that i'v found with matroska shell addon) when i try to find the fps with MI, it give me that :
Video #0 : DivX 5
Aspect : 704 x 528 (1.333) at %fps% fps
i'm unable to find FPS in this file
source is a MKV.
*MediaInfo version : 0.7.0.4
** when the file is extracted, we can have
Thank you
LAIN
よろしく。 <- if you see "???" you need japanese fonts ;)
LAIN is offline   Reply With Quote
Old 7th January 2006, 08:18   #72  |  Link
foxyshadis
ангел смерти
foxyshadis's Avatar
MKV isn't generally supported in mediainfo, sadly. For my own tools I parse the output of mkvverify (mkvinfo would also work, but mkvverify is very compact and gives more info).
Old 7th January 2006, 11:56   #73  |  Link
Zenitram
I did not have time to work well on Matroska, so the support is not good at this time.
But I plan to have a better support soon (maybe next release)
Sorry for the delay.
Old 22nd February 2006, 01:50   #74  |  Link
LAIN
RealAnime dev
LAIN's Avatar
I'v recently downloaded the last version of MediaInfo 0.7.1.0 available on your web site because i have a problem knowing the fps of a file. In MkvInfo it is available but not in MI current release and dll that we use in RealAnime 4.
here is the video section of mkvinfo
| + A track
| + Track number: 1
| + Track UID: 3752893478
| + Track type: video
| + MinCache: 1
| + Timecode scale: 1.000000
| + Codec ID: V_MS/VFW/FOURCC
| + CodecPrivate, length 40 (FourCC: DX50, 0x30355844)
| + Default duration: 33.367ms (29.970 fps for a video track)
| + Default flag: 1
| + Language: jpn
| + Name: [a4e]Lost Universe - 01
| + Video track
| + Pixel width: 696
| + Pixel height: 520
| + Display width: 696
| + Display height: 520
| + Lacing flag: 0
MediaInfo video section :
Video #0
Count : 35
Count of stream of t : 1
Kind of stream : Video
StreamKindID : 0
Inform : Japanese, 1422 Kbps, 696*520 (4/3), DivX 5
UniqueID : 3752893478
Title : [a4e]Lost Universe - 01
Codec : DX50
Codec : DivX 5
Info : (MPEG4) DivX Networks
Url : http://www.divx.com
Bit rate : 1422220
Bit rate : 1422 Kbps
Width : 696
Height : 520
Aspect ratio : 1.338
Aspect ratio : 4/3
Resolution : 24
Language : ja
Language : Japanese
If you want more information here is the full .txt file
mkvinfo : http://www.sobanet.ca/files/mkvinfo.txt
mediainfo: http://www.sobanet.ca/files/mediainfo.txt
LAIN
Old 22nd February 2006, 09:04   #75  |  Link
Zenitram
Yes, I did not have time to work on mkv, sorry.
But a v0.7.1.1 will come in few weeks, and I plan to work well on this missing fps in mkv...
Old 22nd February 2006, 12:12   #76  |  Link
Zenitram
OK, Lain.
I succeeded to find FrameRate for all kind of video track (AVI codec, or Real, or AVC...)
I do some cleanups, and release a new version befor the end of the week.
Old 22nd February 2006, 13:17   #77  |  Link
Sirber
retired developer
Sirber's Avatar
Nice! Even RV? Sweet!!
Detritus Software
Old 22nd February 2006, 21:36   #78  |  Link
foxyshadis
ангел смерти
foxyshadis's Avatar
Oh, zeni, one quick request, in case you have more time; can you also gather the bitrate for audio in mkv? That would be so helpful! =D Or is that still a difficult problem?
Old 24th February 2006, 18:56   #79  |  Link
LAIN
RealAnime dev
LAIN's Avatar
Originally Posted by Zenitram
OK, Lain.
Thank you very much for the FPS
I'd like to post you another problem that I encounter using the version 0.7.1.1 that you'v send to sirber.
When we try to do --> MediaInfo_Open(handle, filename); <-- we have a Acces Violation in delphi... it said that it's in mediainfo.dll ... in the version 0.7.1.0 dev (5.18 mb) that we use tu try was working #1 without any error.
Thank you
LAIN
Old 24th February 2006, 21:23   #80  |  Link
Kurtnoise
Swallowed in the Sea
Kurtnoise's Avatar
I'm testing the last version with my Delphi tool and it works fine...pb with the Handle maybe.
