#501 | Link |
you are probably right, i'll pickup something better when I have the cash if its easy enough to do using DISPLAYCAL
OLED 4k HDR EF950-YAM RX-V685-WIN10 444 RGB 60hz-AMD RX 5700 19.12.2 KODI DS - MAD/LAV 92.17/0.74.1 - 3D MVC / FSE:Off / MADVR 10bit |
#502 | Link |
Hi, did you get my private message reply, none of them seem to be sending for some reason, my sent box its empty and nothing appears on the message thread.
#503 | Link |
I did.
madVR options explained |
#505 | Link |
Hi, my email account got hacked so I had to shut it down, i'm using this as a templ account, anyone know how I can get my email changed on my main DOOM9 account, there seems to be no support section anymore.
OLED EF950-YAMAHA RX-V685-Win101809-4K 444 RGB 60hz-AMD RX580 198.1 KODI DS - MAD/LAV 92.14/0.72.2 - FSE / 3D / DIRECT3D11 / MADVR 10bit |
#508 | Link |
Hi, did you get my recent private message form this new account?
Mclingo ![]()
#513 | Link |
_
I've noticed that with madVR, I have background sound. It's like coil whine, except it is real sound produced by computer.
It means if I use another soundcard that the HDMI (nVidia 1060), for example optical from motherboard, I still have this background sound, and like people mentioned in the past, with NGU, it is amplified. Sound is really coming for speakers and not motherboard. So strange. Without NGU, it is weak but it is here. I don't have that with mpv ou a browser or even powerful games ! |
#515 | Link |
madVR is an unusual power load on GPUs (very spiky) so some GPUs that do not normally whine will when running madVR. Your issue sounds similar. You must have some electrical crosstalk between your audio channels and your GPU.
#516 | Link |
this is a pretty far spread issue i can easily make a recording with that using different soundcards one that totally fixed the issue too.
the AVG user doesn't care about stuff liek this they only care about loud... |
#517 | Link | |
_
I never said the video renderer created sound by himself. I have no doubt there's no sound code in madVR.
But still I'm surprised how a GPU can create disturbance for something which does not seem that connected (optical soundcard from motherboard). And I'm also surprised the noise comes only with madVR. I'm certain you will say madVR code is perfect, but as I don't have this sound with other applications (including GPU stress tests), I have my doubts. Quote:
#518 | Link | ||
GPUs can do what ever they want it it should never effect audio everything else is a hardware flaw. coilwhine on a GPU is a hardware flaw the program in question has nothing todo with that. hearable noise in the audio signal is the same. Quote:
#520 | Link |
As I mentioned before, madVR is a very unusual load on GPUs. A GPU stress test is nothing like madVR. Also, how would 'imperfect' code in madVR cause random noise on your soundcard that changed with the resize algorithm used? And only on your system? It makes a lot more sense that the exact behavior of the GPU power draw, which changes based on the algorithms used and is unique to madVR, is interfering with the audio device.
