Old 21st June 2018, 09:45   #21  |  Link
jpsdr
... I'll see... in the future...
My github.
Old 21st June 2018, 10:55   #22  |  Link
kolak
What bout HDR PQ to HLG conversion based on this paper:
http://downloads.bbc.co.uk/rd/pubs/p...anscode_v2.pdf
which suggests it should be pure math (no tone mapping, etc at leats for 1000 nits masters).
Old 21st June 2018, 14:50   #23  |  Link
jpsdr
I'll take a look later, but will not this just shift the issue from converting [PQ-HDR -> SDR] to converting [HLG-HDR -> SDR] ?
My github.
Old 21st June 2018, 16:46   #24  |  Link
kolak
Well, HDR to SDR is different story as it's difficult conversion and ideally should be done per scene, not global.
HDR PQ to HLG should be way easier (more like Rec.709 to Rec.601).
Old 21st June 2018, 17:15   #25  |  Link
jpsdr
My final purpose (the reason i've made these tools) is to work on HDR to SDR.
My github.
Old 22nd June 2018, 00:02   #26  |  Link
kolak
Starting with something easier (which is still useful) is no harm
Old 22nd June 2018, 10:03   #27  |  Link
jpsdr
I have no needs for PQ to HLG for now. But technicaly, once i'll implement the HLG in the plugins (because for now there is only PQ, my plugins have a HLGMode parameter, not implemented yet), doing something like :
ConvertYUVtoLinearRGB(Color=0,HLGMode=true)
ConvertLinearRGBtoYUV(Color=0)
will do the convertion.
I didn't implement HLG yet, because i've trouble to understand properly how it works. There is several range mode (so i'm a little loss).
But...! Maybe the doc you provided will help me to understand things. But, HLG is not my prority for now.
Ah... Just take a look. The french version and english version of the same release version document don't say the same thing.
French version (R-REC-BT.2100-1-201706-I!!PDF-F) talk of [0:12] range and possibility of [0:1], when english (R-REC-BT.2100-1-201706-I!!PDF-E) talk only of [0:1]...
Nice !
Edit :
Quick look, it seems that PQ has fixed parameters functions, for luminance range up to 10000 cd/mē. It seems that for HLG, the parameters changes according (Lw/Lb) values, when they are fixed for PQ. Meaning i'll have to add these parameters on my plugins, for when i'll implement HLG. I'll also have to add some "WhitePeak" value (at least on plugins using linear data on input), if i want to properly handle both HLG and PQ, because it seems that i can't assume (like i thought), that in linear value, 1.0 = 10000 cd/mē.
Well... I'll see this for later... when i'll do the 0.3 release
My github.
Old 22nd June 2018, 11:40   #28  |  Link
kolak
There are many references to [0,1] or [0,12] in English version.
Is there anything useful in link to HDRTools project provided in the document?
Old 22nd June 2018, 12:38   #29  |  Link
jpsdr
Didn't read properly yet (but retrieved), i'm on something else for now, but there is a big chance it may help me to understand better HLG and this eventualy "whitepeak" information.
Edit :
Read a little more, it will help me. From what i understood (if properly), PQ is "fixed" -> 1 = 10000cd/mē, but HLG is adaptative.
Stop investigating for now, will continue in second time.
My github.
Old 26th June 2018, 15:50   #30  |  Link
jpsdr
I've read doc more carefully, kolak doc helped... HLG is a pain in the ass !!!
I'll implement what i've understood, i just hope i have undersood properly...
My github.
Old 26th June 2018, 18:42   #31  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
That would be amazing, 'cause last time I used Davinci Resolve to convert HDR10 to HLG, but it would indeed be very useful to have HLG working in your plugin.
Broadcast Encoder
Avisynth memes: 1 - 2 - 3
Videotek - Audacity XP
Old 26th June 2018, 20:28   #32  |  Link
jpsdr
And having someone to test/verify also
Otherwise, does anyone know if it's possible to make a script which display, in the frame, the max value of Y for the curent frame (for an YUV video) ?
If yes, what would it be ?
My github.
Old 26th June 2018, 21:44   #33  |  Link
Something like this maybe [EDIT: Below intended for 8 bit only]
Function TestFunc(clip c,Float Thresh_Min, Float Thresh_Max,Bool Debug,String LogFile) {
    c
    Yave=AverageLuma YMin=YPLaneMin(Thresh_Min) YMax=YPLaneMax(Thresh_Max)
    Subtitle(String(YAve,"YAve=%7.3f : ")+String(YMin,"YMin=%3.0f : ")+String(YMax,"YMax=%3.0f"),Align=8)        # Added
    RT_Subtitle("%d] YAve=%7.3f YMin=%3d YMax=%3d",current_frame,YAve,YMin,YMax,Align=5)
    (Debug) ? RT_DebugF("%d] YAve=%7.3f YMin=%3d YMax=%3d",current_frame,YAve,YMin,YMax,name="TestFunc: ") : NOP
    (LogFile!="") ? RT_Writefile(LogFile,"%d] YAve=%7.3f YMin=%3d YMax=%3d",current_frame,YAve,YMin,YMax,Append=True) : NOP
    Return last
FN         = "D:\TestClip.avi"
LOGFILE    = "D:\TestClip.Log"
DEBUG      = True
Thresh_Min = 0.0
Thresh_Max = 0.0
(LOGFILE!="") ? RT_FileDelete(LOGFILE) : NOP    # We Will Append
SSS =   "TestFunc("                         +
        \ String(Thresh_Min,"%f")           +
        \ String(Thresh_Max,",%f,")         +
        \ String(DEBUG)                     +
        \ "," + Chr(34) + LogFile + Chr(34) +
#SSS=RT_String("""TestFunc(%f,%f,%s,"%s")""",Thresh_Min,Thresh_Max,DEBUG,LogFile)   # Alternative
#RT_DebugF("SSS=%s",SSS)
AviSource(FN)
Return Last.Scriptclip(SSS)
EDITED:
EDIT: Alternative to RT_string, StrFmt(Small dll):- https://forum.doom9.org/showthread.p...ghlight=StrFmt
EDIT: Or RT_Stats for 'RT_xxx' funcs:- https://forum.doom9.org/showthread.p...light=RT_Stats
StainlessS is online now   Reply With Quote
Old 27th June 2018, 10:08   #34  |  Link
jpsdr
Tested, and seems there is a problem. I've used your 2.00 beta version.
The message is telling me that Average Plane can only be used within run-time filters.
No log file is created.
My github.
Old 27th June 2018, 10:40   #35  |  Link
That is why its called from ScriptClip() in given code.
AverageLuma can only be called from within runtime environment,
or alternatively, cheat a bit, simulate within runtime filter, must eg current_frame=n, before the call to AverageLuma. (Scriptclip et al, set current_frame at every frame so it is known what frame is current).
For RT_AverageLuma(n=n).will also suffice, where n is accepted as current_frame, but MUST be done for every frame, thats is why Scriptclip is a good idea, unless using eg GScript for next to access frames.
"No log file is created", thats because its already caused an error and exited.
Try the script as given.
MOBILE:
EDIT: Post your failing script.
EDIT: do frame 42 only (untested)
    c
    n=current_frame
    trim(n,-1)
    current_frame=0
    RT_Subtitle("%d] YAve=%7.3f YMin=%3d YMax=%3d",n,YAve,YMin,YMax,Align=5)
    (Debug) ? RT_DebugF("%d] YAve=%7.3f YMin=%3d YMax=%3d",n,YAve,YMin,YMax,name="TestFunc: ") : NOP
    (LogFile!="") ? RT_Writefile(LogFile,"%d] YAve=%7.3f YMin=%3d YMax=%3d",n,YAve,YMin,YMax,Append=True) : NOP
    Return last
DEBUG      = True
Thresh_Min = 0.0
Thresh_Max = 0.0
AviSource(FN)
current_frame=42 /* Simulate runtime */
TestClip(Thresh_Min,Thresh_Max,DEBUG,LOGFILE)
Return Last
EDIT: Oops, would print stats from frame 42 on frame zero, i think(not sure), edited in blue, should work.
EDIT: Oops again, will print frame 0] in stats, well you get the idea anyways I hope.
Alternative, MUST call with n=frame number, or n=current_frame from within ScriptClip.
Function TestFunc(clip c,int n,Float Thresh_Min, Float Thresh_Max,Bool Debug,String LogFile) {
    c
    trim(n,-1)
    current_frame=0
    Return last
Old 27th June 2018, 13:26   #36  |  Link
jpsdr
Thanks, i finaly been able to get what i want.
My github.
Old 28th June 2018, 16:33   #37  |  Link
jpsdr
Do you have, by any chance, an HLG encoded stream you could share ?
My github.
Old 28th June 2018, 18:57   #38  |  Link
videoh
http://4kmedia.org/travelxp-4k-hdr-hlg-sample/
Or google for "hdr hlg sample files". You'll find a lot of them.
Not all have the SEI denoting HLG, but some do.
Old 28th June 2018, 19:18   #39  |  Link
jpsdr
It didn't even cross my mind to google search...
What are exactly HLG SEI information ? Is there some other mastering informations in the H265 spec ? I've tried a search for "HLG" in the T-REC-H.265-201612-I!!PDF-E document, but found no information about such a thing.
My github.
Old 28th June 2018, 19:49   #40  |  Link
videoh
You can google "HLG SEI message". BTW, DGIndexNV notifies this SEI in the DGI file.
