#61 | Link |
Hello,
Help me please I did in II. STRIPS OF FONTS I renamed in the file tblSU_T3_Sub_res.qct Spanish to Russian and launched in TotalMedia Theatre, but it hangs at the first splash screen, that I did not properly help please? here folder JAR: http://www.multiupload.com/OSRDBI8RNV |
#64 | Link |
crl2007
please help, I could not find the word Spanish in these files: FS.QCO langMap_res.qc h.class only found in tblSU_T3_Sub_res.qct but nothing works, where it hides the button Spanish subtitles please tell me if you know? |
#65 | Link |
Are you sure you followed these steps:
f) Open ImgBurn and make an ISO from BDMV and CERTIFICATE folders. It is described how to do it at step 12 from the guide above. g) Insert the ISO in DAEMON TOOLS and decrypt it again with AnyDVD HD. |
#69 | Link |
hello crl2007
I can't find any of the files mentioned in this guide maybe it's a new structure if you have the time to look at this: http://dl.transfer.ro/JAR-transfer_RO-09jul-44d56d.rar the movie has Spanish, English SDH Thank you |
#70 | Link |
Hi crl2007,
thanks for your great guide! Unfortunately I have to edit a compilation of multiAVCHD where I have 5 chapter menu pages. Links between pages were generated wrong and links of chapter points of any other chapter menu page than the first are using the thumbnail chapter time points of the first page. I see that this topic is not covered in your guide but I assume you have enough knowledge seeing what is wrong here. Could you point me to some online tutorial that covers blu-ray menu coding specification? Would be great indeed! I can use BDedit but I don't understand the coding within the menus of certain .clpi's Thanks. |
#72 | Link | |
![]() Maybe you could give me one advice what to look for:
All I see for the moment is in CLIPINF that there are 5 .clpi's numbered from 80011 ... 80015 which obviously represent the five chapter menu pages. When I open the menu details of such a page I don't discover anything that could lead me to some senseful commands. Even the command trace/run doesn't show a menu as I'm always hanging in a loop. Is there possibly another method to rebuild the chapter menu pages completely? |
#73 | Link | |
#74 | Link |
http://forum.doom9.org/showthread.php?t=150511 Step 12 from here.
#75 | Link |
editing menu with strips of fonts
Hi crl2007,
I did everything you said in your guide from point "a" to "g" and nothing menu hangs. I used Any DVD to back up BD, I copied the contents of BACKUP folder where you said, I changed in hex editor in tblSU_T3_Sub_res.qct file word FRENCH into POLISH (same number of letters) I put it back into 00000.jar, made the image of two folders BDMV and CERTIFICATE with ImageBurn, mounted in DEAMON, decrypted again with ANY DVD and as I said, nothing. When I go into subtitles in menu, nothing shows and I can't go anywhere else, I must exit. Please help. Maybe versions of programms used have to be specific, I don't know. Regards, Tom |
#77 | Link |
Again about strips of fonts
Maybe, but when I edited this file back. I mean, I put the word FRENCH again in the same manner everything worked again. I don't know how to do it differently. I overwrite string, put the letter in the 1st line than I press the button which changes letter into hex code and press ok and string is changed. I do the same for every single letter than I save the changes in the file and overwrite it in the jar folder. Next steps are obvious.
Best, Tom |
#79 | Link |
same story
But how could I brake it. Maybe you could give me a hint of how to edit such files. What should I pay attention to? Where is the trick? I do everything as I described in previous post. I just don't have a clue what's wrong with this method. I also used the other hex editor with exactly same result. Please, help.
P.S. Maybe I could put this file (i.e. rapidshare or something) somewhere so you could download it and check it if you don't mind. |
