Old 19th November 2018, 22:09   #181  |  Link
mandeajupanu
ok si i have done it few times but it still not worling...in the status of anydvd it dosent fix nothing
mandeajupanu is offline   Reply With Quote
Old 5th April 2019, 10:45   #182  |  Link
Olligator
How can i change the duration time in a in IG Menu?
Hello, can someone help me. Please.
I want to start later the InEffects of an IG Menu.
At the moment I realize the start time with two IG menus.
I hope someone can help me.
Sorry for my horrible english.
Olligator is offline   Reply With Quote
Old 7th April 2019, 17:38   #183  |  Link
neil wilkes
neil wilkes's Avatar
Originally Posted by ocean View Post
Fix the java checksum after the change, read first post of the thread, create iso and use anydvd version 6.7.5.0:
http://www.oldversion.com/windows/anydvd-6-7-5-0
Why that version in particular?
Just curious really as my current version is the RedFox 8.3.4.0 one
www.opusproductions.com
Multichannel Audio Productions
DVD-Audio/Video Authoring specialists
neil wilkes is offline   Reply With Quote
Old 7th April 2019, 18:53   #184  |  Link
ocean
Hi neil wilkes, read point g of the guide:
versions previous to 6.8.0.0 because 6.8.0.0 doesn't fix java in unprotected discs anymore.
Software AnyDVD HD until version 6.7.9.0 fixes the java checksum, if the bluray structure does not have the AACS folder.
However, changing a parameter in the Windows registry, allows operation even with recent versions such as 8.3.4.0.
Change the registry value allow NonAACSJarFixes from 0 to 1.
You find the value in Computer \ HKEY_CURRENT_USER \ Software \ SlySoft \ AnyDVD \ Settings
ocean is offline   Reply With Quote
Old 10th April 2019, 13:57   #185  |  Link
Olligator
Another Question:
bdedit save the IMG-Menu as *.mnu file.
With which program can I edit this *.mnu file.
With an Hex-Editor I can open, but there are only incoherent data in it.
Thank you.
Old 5th May 2019, 15:28   #186  |  Link
no-one
Thank you.
no-one is offline   Reply With Quote
Old 28th May 2019, 13:00   #187  |  Link
no-one
How to edit menu lionsgate and universal movie by DJ Java Decompiler?
Thank you.
Old 12th June 2019, 16:56   #188  |  Link
ocean
Hi no-one, use the example in the post 175.
Old 20th August 2019, 22:38   #189  |  Link
malimuc
Hi to all!
Hello, can someone help me, please. I have a BD-R serial Game of Thrones (2011). In the jar folder (lb.class) have i change "Nederlands" to Slovenian subtitle language. But after when I created the iso file and ripping with AnyDvd (6.7.3.0) to Hard drive i have this i get this error in 8900.jar file:
Please for help and advice.
Best regards
malimuc is offline   Reply With Quote
Old 21st August 2019, 17:09   #190  |  Link
ocean
Hi malimuc welcome to the forum, try to copy the files from the JAR directory, contained in the backup folder, insert them in BDMV\JAR, and see if you solve the error.
Old 21st August 2019, 21:01   #191  |  Link
malimuc
Thank you for help. Question: When i change files from backup - before or after creating the iso file.
best regards
Old 21st August 2019, 21:37   #192  |  Link
ocean
Before creating the iso file, sometimes it can happen to copy them incorrectly.
Old 22nd August 2019, 13:39   #193  |  Link
malimuc
I did so, but after ripping the movie are without error reporting and movie doesn't start. Immediately stop play on the beginning. Something must happened with the xxxx.jar file, when i change Nederland to Slovenian subtitle language.
Any other advice?
best regards
Old 23rd August 2019, 15:40   #194  |  Link
ocean
Check in 00001.jar besides lb.class also: alp.class, avt.class, bf.class, hl.class, lx.class, mf.class, pn.class, rg.class.
Modified all classes should work.
Old 23rd August 2019, 18:51   #195  |  Link
DeafYakuza
:edit
It's alright.
DeafYakuza is offline   Reply With Quote
Old 23rd August 2019, 21:08   #196  |  Link
malimuc
I am modified all classes and still not working. Always the same error:
Old 23rd August 2019, 21:23   #197  |  Link
ocean
Ok malimuc, greeting DeafYakuza, file 89000.jar must be 7078 byte and not 8142 byte, copy this file from backup folder.
Old 29th August 2019, 22:37   #198  |  Link
malimuc
Can anyone edit class file inside JAR file and change "Nederlands" to "Slovenski" (class files are: agt.class, bdu.class, be.class, lq.class and vt.class)?
Here are link to my JAR file:
https://www16.zippyshare.com/v/eWdlR7Pe/file.html
or:
https://www.uploadship.com/e48827aa60965487
Thank to all who will help me.
best regards
Old 23rd September 2019, 06:29   #199  |  Link
no-one
I try to this but it won't work.
when I use version 6.7.9.0, it will create "sly folder" in jar file. And It can fix menu and play perfectly.
But when I use lated version and edit regedit, Anydvd shows Java Fix but no create "sly folder". And movie shows black screen.
Old 23rd September 2019, 06:39   #200  |  Link
no-one
or:
best regards
1. backup all jar files in jar folder.
2.delete all jar files in jar folder except jar file that you edit menu.
3.If you still found jar too big problem, backup kudu folder in jar file that you edit menu. delete kudu folder
4. create iso
5. use anydvd version 6.7.9.0
6. copy all jar files in backup to jar folder
7. copy kudu folder in backup to jar file that you edit menu.
