Old 29th April 2019, 22:55   #56061  |  Link
tp4tissue
tp4tissue's Avatar
Originally Posted by famasfilms View Post
Was this week's Game of Thrones highly pixelated/blocky for anyone else?
Is there a way to fix that?
there's alot of banding in the dark sky/ gradients.
Ghetto | 2500k 5Ghz
Old 30th April 2019, 00:09   #56062  |  Link
SamuriHL
SamuriHL's Avatar
That episode really requires a proper UHD release. We should see one this summer and we can revisit it then. For streaming it was brutal. I did not run it through madvr though.
HTPC: Windows 10, I9 9900k, RTX 2070 Founder's Edition, Pioneer Elite VSX-LX303, LG C8 65" OLED
Old 30th April 2019, 00:17   #56063  |  Link
nevcairiel
The overall dark setting doesn't really play well with typical encode settings. HDR probably wouldn't really help either, since HDR grading is usually very careful to not do it too dark, since todays TVs screw that up easily. A properly encoded 10-bit SDR video might be nice (to resolve low-light banding), but thats not something anyone does.
Of course a properly graded HDR source woule be nice as well, madVR can map that to our displays just fine. But as said above, TV built-in tonemapping might screw that up easily, so they might be careful to use such dark HDR grading.
Old 30th April 2019, 00:55   #56064  |  Link
katodevin
I ran an amazon version through madvr. It was still really bad. I may be out of the loop, where would a summer UHD release come from? Last I did any research, only season 1 has come out with UHD thus far.
katodevin is offline   Reply With Quote
Old 30th April 2019, 01:01   #56065  |  Link
tp4tissue
tp4tissue's Avatar
If they gave us 20mbit, probably wouldn't have this problem, But I'm guessing they clamped it to account for simultaneous peak bandwidth from millions of viewers.
Ghetto | 2500k 5Ghz
Old 30th April 2019, 01:09   #56066  |  Link
ryrynz
ryrynz's Avatar
Yeah 7Mbps doesn't cut it. I read about the issues before playback and took a look, enabled deband on and it was watchable for me but honestly you cannot really fix a sky with three color bands xD
Really disliking how streaming sites aren't offering high quality. They could easily double their bit rate without any significant issues for consumers IMO.
Someone really needs to push this so the rest follow otherwise we'll get this quality for another 5-10 years..
Old 30th April 2019, 01:13   #56067  |  Link
nevcairiel
Its not about helping consumers. Bandwidth is expensive.
Amazon used to have really high quality encodes, best of all streaming sites, but sometimes in the last 18 months or so they cut it down, so now its just middle of the pack.
Unfortunately one service pushing quality does nothing, since they don't compete on quality. Most content is only available at one service, as such content is the driving factor, not quality.
Can hope they make a high-quality Blu-ray release from this. Perhaps UHD right away, if we're lucky.
Old 30th April 2019, 01:23   #56068  |  Link
hotripper
Originally Posted by katodevin View Post
Just wanted to report in that the new Nvidia driver does not fix stuttering issues with Turing cards (specifically 1660), but may lessen frequency. Was able to watch 2-3 movies since throwing my 1660 back into my system with new drivers (drivers cleaned between swaps). When watching GoT (not even 4k) last night, stutters came back about halfway through. Switched over to the Plex player and finished watching the episode.
Power management set to adaptive in control panel.
Putting my 1060 back into the system. I'd advise against anyone buying a Turing card with the expectation of using it with MadVR/MPC.
I have not read all your posts, but have you tried my workaround?
Set LAV to DXVA2 copy-back
Set Madvr to present 1 frame in advance for Exclusive Mode
It's the only thing that works for me every time.
4790K - RTX2070 - 970EVO - EVGA Supernova 750W Gold - Sony KD55X720E
hotripper is offline   Reply With Quote
Old 30th April 2019, 01:51   #56069  |  Link
katodevin
I really avoid exclusive mode. I'll give it a shot before pulling this card out though. Thanks for the advice. Kinda infuriating that these fancy new cards are having issues with relatively simple video playback. And it is even more infuriating that the issue pops up seemingly randomly.
Old 30th April 2019, 01:55   #56070  |  Link
el Filou
el Filou's Avatar
Sorry for the OT but anyone else reading so many comments from people saying they couldn't see anything in this episode of GoT thought "calibrate your displays!!! "
(well, I bet most people are watching this on TN laptop panels...)
HTPC: Windows 10 1809, MediaPortal 1, LAV Filters, ReClock, madVR. DVB-C TV, Panasonic GT60, 6.0 speakers Denon 2310, Core 2 Duo E7400, GeForce 1050 Ti
Old 30th April 2019, 02:02   #56071  |  Link
hotripper
YES!!! Exactly the issues I was having till I I found the workaround.
TBH I was going crazy thinking I was alone with the issue
Old 30th April 2019, 02:05   #56072  |  Link
katodevin
Yeah, I'm really surprised that more ppl aren't complaining. You and I need to create a private support group for emotional feedback. hahah.
Old 30th April 2019, 02:09   #56073  |  Link
toki
I absolutely agree with this statement.
Edit: the workaround isn't fully correcting the issue over here either.
toki is offline   Reply With Quote
Old 30th April 2019, 02:12   #56074  |  Link
hotripper
Tell me about it.
So far I have counted at least 4 others here with stuttering on turing, as more adopt the card more will arise. Which will, since 10series is all pretty much wiped out except second hand or ridiculous prices
Old 30th April 2019, 03:25   #56075  |  Link
SamuriHL
SamuriHL's Avatar
Sadly, you're probably quite right. sigh
...I may be out of the loop, where would a summer UHD release come from? Last I did any research, only season 1 has come out with UHD thus far.
Best Buy. It's already up for pre-order.
Old 30th April 2019, 03:51   #56076  |  Link
BetA13
cosmic entity
BetA13's Avatar
THANK GOD FOR MADVR !!!!!!!!
That GoT episode was sooo dark, only MADVR could fight it.. :P
Thanks madshi, you saved my day Today.
BetA13 is offline   Reply With Quote
Old 30th April 2019, 05:48   #56077  |  Link
hotripper
GoT banding? ;p LOL Just watched it. Wow that was brutal
Old 30th April 2019, 11:19   #56078  |  Link
mclingo
streaming is getting worse not better IMHO, companies use better logarithms to reduce bandwidth rather than increase quality, its depressing as bluray will be gone in the not too distant future so they'll be no uncompressed outlets and if they start pumping out stuff in 8k they'll never bother to fix the 4k and 1080p streams, they'll just remain sh!te as the average user doesnt care.
Thank god for MADVR which makes it just about watchable, its completely unwatchable otherwise.
OLED 4k HDR EF950-YAM RX-V685-WIN10 444 RGB 60hz-AMD RX 5700 19.11.3 KODI DS - MAD/LAV 92.17/0.74.1 - 3D MVC / FSE:ON / MADVR 10bit
Old 30th April 2019, 11:58   #56079  |  Link
cremor
To everyone having stuttering problems, especially those with RTX or GTX 16xx GPUs:
Try adding your player's exe file to the "Media Player Classic" or "Windows Media Player" profile with NvidiaProfileInspector. This makes sure that the player knows that a video player is running.
cremor is offline   Reply With Quote
Old 30th April 2019, 13:37   #56080  |  Link
clsid
^ An optimized profile
