19th October 2017, 18:22 | #46721 | Link |
i'd like to thx el Filou and who give me some tips!
Now it's not perfect, but now i can play without shuttering hdr 4k movie! I have to test more and more for better result but i wanna say thx! reducing decode CPU and GPU at 4 (both) helped and set also bilinear and dvxa everywhere in madvr settings helped too. Continue with testing! |
19th October 2017, 19:01 | #46722 | Link | |
BTW 480 is like the 580. The 580 is just a little bit faster and lesser heat production than the 480. The 480 is now faster than when it hit the market. Thanks to the driver improvements. This applies to games, not to MadVR. |
19th October 2017, 19:18 | #46725 | Link | |
In comparison, the much older r9 290x that I have has 2816. A video content playing back at 50fps on a 50hz screen has a maximum limit of 20ms to render before frames are dropped. What is your rendering stats, when you fully switch to using madvr, for full-hd to 4k 50hz upscaling?
Core i7 4790K@4.6Ghz - Asus Maximus VII Formula - AMD R9 290X 4GB Crossfire - Windows 10 Pro x64 |
19th October 2017, 19:59 | #46726 | Link | |
19th October 2017, 20:11 | #46727 | Link | |
Ultimately changing to the 550 was a mistake. |
19th October 2017, 20:12 | #46728 | Link | |
Banned
Cant get it to work correctly Thats what it looks like: Full range (0-255) HD ok: HDR to dark/details missing: Limited (16-236) HDR ok: HD to bright/to much contrast/grey vail: How can i fix this? |
19th October 2017, 20:23 | #46729 | Link | |
@madshi
http://s4.toldacuccot.hu/letoltes?si...enshot2_3D.png |
19th October 2017, 20:56 | #46730 | Link | ||
I assume that dedicated deblocking algorithm would be better and could preserve some more detail, but 1-4 drtd / 5-12 or 1-5 rrtd / 6-12 is good compromise for RCA in my opinion.
I'm infected with poor sources. |
19th October 2017, 22:51 | #46731 | Link |
@Madshi @Nevcairiel
Did you get a chance to look at the DVD playback issue with the Klute sample? As far as I can see the issue is still there with the latest LAV+MadVR. Thanks!
Win11 Pro x64 b23H2 Ryzen 5950X@4.5Ghz 32Gb@3600 Zotac 3090 24Gb 551.33 madVR/LAV/jRiver/MyMovies/CMC Denon X8500HA>HD Fury VRRoom>TCL 55C805K |
19th October 2017, 22:54 | #46732 | Link |
Disable XySubfilter. Its conflicting with all the things.
19th October 2017, 23:08 | #46733 | Link |
I tried the internal subtitles or no subtitles, that doesn't seem to make any difference here, the problem is still there (using MPC-BE and restarting the player after each change).
Also why would there be a problem only with a few titles?
19th October 2017, 23:22 | #46734 | Link |
Who knows. Plays perfectly for me in MPC-HC without XySubfilter installed (uninstalling may be required to ensure its not interfering, just unselecting it for subs isn't enough). madshi could reproduce troubles with XySubfilter as it tried to force itself in there, went away without it.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 19th October 2017 at 23:25. |
19th October 2017, 23:50 | #46735 | Link | |
It doesn't make sense anyway, because whether xysubfilter is installed or not, if I select EVR-CP as the renderer in MPC-BE the problem goes away and the menus are absolutely fine, so that suggests a MadVR issue (or a MadVR configuration issue). Installing/uninstalling xysubfilter = no difference Selecting MadVR / EVR-CP = issue / no issue
Win11 Pro x64 b23H2 Ryzen 5950X@4.5Ghz 32Gb@3600 Zotac 3090 24Gb 551.33 madVR/LAV/jRiver/MyMovies/CMC Denon X8500HA>HD Fury VRRoom>TCL 55C805K Last edited by Manni; 19th October 2017 at 23:56. |
19th October 2017, 23:52 | #46736 | Link |
high CPU using madvr
trying to understand why my CPU is getting hammered by MADVR, thought the processing happened on the GPU.
CPU us halved why I choose DXVA NATIVE instead of COPYBACK, is this because this is essentially turning the MADVR scaling tweaks as COPYBACK is required? |
20th October 2017, 00:06 | #46737 | Link | |
Anyway, it plays perfectly for me, and XySubfilter was never installed on my system. madshi could only reproduce it with XySubfilter installed, once he removed it, it was fine. So either you didn't really remove it, or your setup is screwed up even further then that.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 20th October 2017 at 00:09. |
20th October 2017, 00:27 | #46738 | Link | ||||
NGU is very slow on polaris compared to pascal/maxwell or even GCN 1-2. i told you that before and it is confirmed by other user. so it is not an mem issue. Quote:
can you create a folder in the madVR folder called showrendersteps and make me a screen of the OSD. Quote:
it supports software deinterlancing which is not cheap at 1080p and stops you from using madVR IVTC so it is not an ideal solution. |
20th October 2017, 02:30 | #46739 | Link | |
Win7Ult || RX560/4G || Ryzen 5 Last edited by noee; 20th October 2017 at 02:32. |
20th October 2017, 02:54 | #46740 | Link |
you can test it by supersampling 1080p23.
an 960 takes 26-28 ms for NGU sharp high with chroma set to high (NGU low). shown with ShowRenderSteps. maybe it is limited by the comparable slow pixel fill rate of polaris. fp16 texel rates are slow on polaris too maybe this counts for int16 too. it has to be something computer games clearly don't care about. |
