Old 17th April 2019, 08:46   #1781  |  Link
szabi
Originally Posted by LoRd_MuldeR View Post
Yes, quite significant.
I will switch to use it.
Thanks .
szabi is offline   Reply With Quote
Old 22nd April 2019, 16:56   #1782  |  Link
almosely
It would be very nice, if you wouldn't force everyone using your launcher to check for updates after six months even the checkbox "never show auto-update notifications on application startup" is enabled. Maybe there's another checkbox necessary for that six-month-message - but I definitively do not want to be forced to check for updates or to wait for a felt eternity before I am allowed to click the discard button.
almosely is offline   Reply With Quote
Old 27th April 2019, 12:23   #1783  |  Link
rsotome
Just gonna ask about that update thing as well, maybe an option to disable checks. Thank you.
rsotome is offline   Reply With Quote
Old 30th April 2019, 15:26   #1784  |  Link
jlw_4049
This program doesn't accept UHD files as an input?
jlw_4049 is offline   Reply With Quote
Old 2nd May 2019, 17:30   #1785  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
This is just a GUI front-end. It "accepts" whatever Avisynth or VapourSynth script as input that you load
The actual question, IMO, is whether Avisynth or VapourSynth and the particular filters (especially the source filter) that you are using properly support “UHD” material, i.e. 4K resolution + High Dynamic Range (HDR).
I think "classic" Avisynth is out of scope here, as it was 8-Bit only and development is pretty much dead, AFAIK.
But VapourSynth should work fine, as it has supported "high bit-depth" color formats ever since. Maybe Avisynth+ can be made to work too, as it is supposed to add more color formats (including 10, 12, 14 and 16 bits) to Avisynth.
The next big question is, how the encoders, i.e. x264 or x265, deal with “UHD” input. My experience on that field is limited, but you will probably have to use some sort of "tone mapping", if you want to encode as SHD.
Old 2nd May 2019, 17:42   #1786  |  Link
LoRd_MuldeR
Software Developer
Simple x264/x265 Launcher v2.90
https://github.com/lordmulder/Simple...ases/tag/v2.90
Version 2.90 [2019-05-02]
* Updated x265 to version 3.0+18
* Updated x264 to revision 2969 (API v157)
* Updated NVEncC to version 4.36
* Updated build environment to Visual Studio 2017 with Update-9
Old 2nd May 2019, 18:27   #1787  |  Link
jlw_4049
Thanks for the info. I've only ever had experience using AviSynth+. Never really looked into vapour synth.
Is it considered better?
Sent from my SM-G965U1 using Tapatalk
Old 2nd May 2019, 19:10   #1788  |  Link
LoRd_MuldeR
Software Developer
We have a forum rule to not ask "what's best" because this question cannot be answered objectively. The best is what works best for you!
But, according to its author, VapourSynth...
...has been heavily inspired by Avisynth and aims to be a 21st century rewrite, taking advantage of the advancements computers have made since the late 90s. The main features compared to Avisynth are:
  • Multithreaded – Frame level multithreading
  • Generalized Colorspaces – New Colorspaces can be specified at runtime
  • Per Frame Properties – Additional metadata can be attached to frames
  • Python Based – The scripting part is implemented as a Python module so you don’t have have to learn a special language
  • Support for video with format changes – Some video just can’t stick to one format or frame size VapourSynth can handle any kind of change
Old 3rd May 2019, 04:36   #1789  |  Link
jlw_4049
Thanks! So, I can use this in GUIs?
Old 3rd May 2019, 23:50   #1790  |  Link
LoRd_MuldeR
Software Developer
Well, it depends
Simple x264/x265 Launcher, for example, supports VapourSynth scripts as input – provided that VapourSynth is installed. It does not provide any kind of VapourSynth editor though; that is out of scope for this program.
So, if you are looking for a fully-fledged GUI editor for VapourSynth scripts, you should probably have a look at the VapourSynth Editor.
Old 6th May 2019, 20:47   #1791  |  Link
Chouonsoku
I'm having any issue with the latest release where sometimes on running the program and queueing an encode, I get a complaint that VapourSynth is not installed. Closing and reopening the program and queueing the encode again seems to solve the problem. I'm running VS and the launcher in portable mode.
Chouonsoku is offline   Reply With Quote
Old 6th May 2019, 20:51   #1792  |  Link
LoRd_MuldeR
Software Developer
Latest release did not change anything regarding VapourSynth detection. Anyway, try running the program with option "--console" and have a look at the log.
Old 7th May 2019, 00:59   #1793  |  Link
Chouonsoku
[Check for VapourSynth support]
VapourSynth thread has been created, please wait...
VapourSynth Dir: E:/Tools/Simple x264 Launcher v2/extra/VapourSynth
VapourSynth EXE: E:/Tools/Simple x264 Launcher v2/extra/VapourSynth/core32/vspipe.exe
VapourSynth DLL: E:/Tools/Simple x264 Launcher v2/extra/VapourSynth/core32/vapoursynth.dll
VapourSynth 32-Bit edition *not* found!
VapourSynth EXE: E:/Tools/Simple x264 Launcher v2/extra/VapourSynth/core64/vspipe.exe
VapourSynth DLL: E:/Tools/Simple x264 Launcher v2/extra/VapourSynth/core64/vapoursynth.dll
VSPIPE.EXE process encountered a deadlock -> aborting now!
VSPIPE.EXE process still running, going to kill it!
VSPIPE.EXE failed with code 0x0000F291 -> disable Vapousynth support!
VapourSynth 64-Bit edition was found, but version check has failed!
VapourSynth thread finished.
VapourSynth could not be found -> VapourSynth support disabled!
Then I close and relaunch and get this:
VapourSynth version was detected successfully.
VapourSynth 64-Bit edition found!
VapourSynth support is officially enabled now! [x86=0, x64=1]
I did update my VS portable install from here recently too so maybe the issue was just not showing because I was using --skip-version-checks until the v2.90.
Old 7th May 2019, 22:10   #1794  |  Link
LoRd_MuldeR
Software Developer
Then I close and relaunch and get this:I did update my VS portable install from here recently too so maybe the issue was just not showing because I was using --skip-version-checks until the v2.90.
Well, as can be seen from your log, VSPIPE.EXE encountered a deadlock (i.e. did not terminate normally within the time limit) on the first attempt:
The time limit currently is 12 seconds. This choice is kind of arbitrary, yes, but I don't see a reason why the invocation of "vspipe.exe --version" should take longer than about ~1 second – let alone 12 seconds!
If a program takes unusually long to start for no comprehensible reason, then – more often than not – so-called "anti-virus" software was interfering.
Anyhow, coincidentally I did some clean-up and refactoring of the startup code today and also slightly increased the time limit. You can try with the latest TEST build and see if that makes any difference for you...
Old 8th May 2019, 11:18   #1795  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
Maybe other app is blocking vspipe.exe? I have seen similar problem in my thread
https://forum.doom9.org/showthread.p...06#post1862506
https://forum.doom9.org/showthread.p...84#post1872384
Old 8th May 2019, 21:29   #1796  |  Link
Chouonsoku
Yeah, seeing it in the log makes it clear that it's not an issue with the program. I've also noticed VSEdit taking a while to open sometimes. Gonna just add the whole folder as an exclusion in Windows Defender. Thanks for helping me troubleshoot a problem completely unrelated to your software!
Edit: Excluding it worked, Simple launched on the first try and VSEdit is opening faster.
Old 18th May 2019, 19:10   #1797  |  Link
aldix
hello.
i've both avisynth and vapoursynth installed and working, yet, when trying a vs script, the simple 264/265 encoder gives the -1 error, saying there's no avisynth installed. :/
what's up?
aldix is offline   Reply With Quote
Old 18th May 2019, 22:00   #1798  |  Link
LoRd_MuldeR
Software Developer
Originally Posted by aldix View Post
hello.
what's up?
Old 19th May 2019, 01:18   #1799  |  Link
aldix
well, it's like i said. which is why i'm confused...
[2019-05-19][02:16:40] avs [error]: failed to load avisynth
[2019-05-19][02:16:40] x264 [error]: could not open input file `C:\Temp\8E5_python.vpy'
[2019-05-19][02:16:40] PROCESS EXITED WITH ERROR CODE: -1
i'll update with the latest version of the x264 gui tho just in case, and report back whether this changes anything.
further updates:
um. latest simple x264/x265 gui. using latest this (https://github.com/jpsdr/x264/releases) for my encoding, always have been, swapping it out in the
C:\Program Files (x86)\MuldeR\Simple x264 Launcher v2\toolset\x64 folder. does this mean i cannot use tmod anymore? that would be very unfortunate...
[2019-05-19][02:45:34]
[2019-05-19][02:45:36] vpyp [info]: Error: fwrite() call failed when writing frame: 0, plane: 0, errno: 22
[2019-05-19][02:45:36] vpyp [info]: Output 9 frames in 1.82 seconds (4.95 fps)
[2019-05-19][02:45:36] WARNING: Input process exited with error (code: 1), your encode might be *incomplete* !!!
[2019-05-19][02:45:36] FATAL ERROR: The encoder process has *crashed* -> your encode probably is *incomplete* !!!
[2019-05-19][02:45:36] Note that this indicates a bug in the current encoder, *not* in Simple x264/x265 Launcher.
[2019-05-19][02:45:36] PROCESS EXITED WITH ERROR CODE: -1073741795
#update 2:
that sucks. tmod indeed doesn't work at all. whereas regular x264 does. with regular avisynth script it has always worked though. is it something inherent to tmod and there's no hope or what?
thanks!
Old 19th May 2019, 11:34   #1800  |  Link
LoRd_MuldeR
Software Developer
As we can see from your log, the encoder process (i.e. x264.exe) has crashed!
From the exit code -1073741795, which is equivalent to STATUS_ILLEGAL_INSTRUCTION (0xC000001D), we can conclude that x264 crashed because it tried to execute an instruction that is not supported by your CPU. If you get that error with "tmod" build, whereas the vanilla build that ships with Simple x264/x265 Launcher is working, then this indicates that the person who compiled "tmod" build used different compiler settings – settings not compatible with your CPU.
Anything else concerning "tmod" build would have to be discussed with the person who provides those builds. I don't provide or use "tmod" build.
BTW: You can ignore the warning about the input process (VapourSynth) in this case, because when the encoder processes crashes and thus breaks the pipe, then the input process won't be able to write to the pipe anymore, obviously.
