Old 25th March 2008, 15:16   #3981  |  Link
Kal
Thank you nautilus7, always here to help me
I don't need to use xport anymore to demux audio part, eac3to will do that ?
EDIT: I did this :
eac3to.exe emily.m2ts 3: fr.ac3
And I get an error :
This TS/M2TS file seems to be damaged (discontinuity).
Kal is offline   Reply With Quote
Old 25th March 2008, 15:59   #3982  |  Link
nautilus7
nautilus7's Avatar
This is the result of joining the multiple .m2ts files. Xport usually reports a lot discontinuities which don't cause any problems. The same should apply here. Try xport also to be sure, but i don't think it will make any difference.
There isn't any program that can join .m2ts files and take care of audio/video overlaps/gaps. This means it's possible a lot of blu-ray discs with seamless branching to show audio/video desync (caused by discontinuity errors). (Madshi could explain this better)
Proper .m2ts joining will done by eac3to in the future.
nautilus7 is offline   Reply With Quote
Old 25th March 2008, 16:01   #3983  |  Link
Kal
Ok thank you nautilus7. In this case, I will just keep my m2ts files on my HDD and wait for that feature
Kal
Old 25th March 2008, 16:06   #3984  |  Link
Thunderbolt8
noticed that the demuxed truehd track from the fifth element blu-ray (remastered) by eac3to is ~500mb shorter than the one I demuxed with xport. (2,80 vs. 3,36 GB). is this supposed to be normal?
the track is said to have 20 or 24bit (24 bit reported by madflac, 20 bit said by highdefdigest.com). the flac filesize is 2,54 GB
Old 25th March 2008, 16:13   #3985  |  Link
nautilus7
nautilus7's Avatar
I remember in the first pages a discussion about that movie... The decoded truehd track and the pcm were identical. Demux the pcm and compare them.
Is the duration of the track ok?
Old 25th March 2008, 16:27   #3986  |  Link
Thunderbolt8
yes, should be. hm I also remember having see that the flac track from the LPCM track is only ~1.5gb, since the LPCM track is only 16 bit (size: 4,05 GB). is the ending .pcm the right one btw. for demuxing that track? because eac3to is swapping endians and remapping channels 2 times then and the -demux switch doesnt seem to work for .m2ts files
Old 25th March 2008, 17:38   #3987  |  Link
shambles
only thing that comes to mind that would make sense is eac3to stripping the interleaved ac3 track while xport keeps it
shambles is offline   Reply With Quote
Old 25th March 2008, 17:38   #3988  |  Link
madshi
Blu-Ray does not have TrueHD tracks. Blu-Ray only has combined TrueHD/AC3 tracks. xport demuxes them as they are - as combined TrueHD/AC3 tracks. eac3to doesn't do that. Instead it either demuxes the TrueHD part of the track or the AC3 part of the track. eac3to can also demux both the TrueHD and the AC3 part of such a combined TrueHD/AC3 track - but then the TrueHD and the AC3 streams are stored into separate files. Those 500mb difference is due to eac3to stripping the AC3 frames from the demuxed TrueHD track, which xport doesn't do.
The pcm extension is just right if you want to demux the track as it is. eac3to will remap the channels and swap endian twice, but that happens in RAM and is extremely fast. So you shouldn't notice any difference.
The "-demux" switch currently works just fine - but only for movies where there's no combined TrueHD/AC3 track. The "-demux" option has a bug which stumbles over such combined tracks. That will be fixed in the next build. The next build will then demux both the TrueHD and the AC3 parts of such combined tracks into separate files, if you use the "-demux" option.
Old 25th March 2008, 17:39   #3989  |  Link
madshi
Spot on!
Old 25th March 2008, 18:54   #3990  |  Link
Cinema Squid
I wish I had some kind of header documentation myself... The only information I'm getting from the DTS-HD blocks is whether the stream is High Resolution or Master Audio. All other values are taken from the core. This is known to be incorrect sometimes because sometimes the core is only 5.1 but the DTS-HD blocks extend that to 7.1. eac3to cannot properly detect this situation right now cause I don't know myself how to parse the information in the DTS-HD blocks. If you find out how it works I'd be happy to hear from you...
Gotcha. I was curious because eac3to did seem to be able to dig out fairly accurate information from these. For example, the below DTS-HD HR track (with a 48khz DTS 5.1-ES 1536kbit/s core):
>eac3to g:\bdmv\stream\00000.m2ts
M2TS, 1 video track, 3 audio tracks
1: MPEG2, 1080p24 /1.001 (16:9)
2: DTS Hi-Res, 6.1 channels, 24 bits, 3093kbit/s, 48khz, dialnorm: -4dB
3: AC3, 5.1 channels, 640kbit/s, 48khz, dialnorm: -27dB
4: AC3, 2.0 channels, 192kbit/s, 48khz, dialnorm: -27dB
Anyway, if I find anything myself by manual inspection of the header blocks, I'll let you know.
Cinema Squid is offline   Reply With Quote
Old 25th March 2008, 18:58   #3991  |  Link
crazydane
With HDMI bitstream support coming (Intel G45 & Asus HDMI soundcard), and assuming there will be .mkv player support for same, will an option to preserve the original DD+, TrueHD and/or DTS-HD MA tracks be fourthcomming?
crazydane is offline   Reply With Quote
Old 25th March 2008, 19:33   #3992  |  Link
madshi
The "6.1" is coming from the "ES" core. The bitrate information is simply manually calculated by making use of the size of the DTS-HD data blocks. You know, for High Resolution the DTS-HD data blocks always have the same size.
Thanks!
The option is already there! eac3to can demux DD+, TrueHD and DTS-HD MA tracks just fine today.
However, I'm quite sure that Intel G45 and the Asus HDMI soundcard will also allow multichannel PCM output. Which means that FLAC is just as good as DD+/TrueHD/DTS-HD MA bitstream. So I will continue to use and recommend FLAC.
Old 25th March 2008, 23:12   #3993  |  Link
bmnot
First BD remuxd done, everything went great. Used a japanese AVC title that I previously had rainbow frames with when remuxed. With eac3to, everything came out perfect!
bmnot is offline   Reply With Quote
Old 26th March 2008, 01:11   #3994  |  Link
DeepBeepMeep
This tool is getting better day after day! Any plan to remux as well the audio track(s) directly into the mkv file?
This would really saves some time .Thanks !
DeepBeepMeep is offline   Reply With Quote
Old 26th March 2008, 01:54   #3995  |  Link
bmnot
I loaded in a DTheater capture just for fun, tried to demux, and I got this message:
TS, 1 video track, 2 audio tracks
1: MPEG2, 1080i60 /1.001 (16:9)
2: AC3, 5.1 channels, 576kbit/s, 48khz, dialnorm: -27dB
3: DTS, 5.1 channels, 20 bits, 1536kbit/s, 48khz
Extracting primary video track...
Extracting audio track number 2...
Extracting audio track number 3...
Patching bitdepth to 24 bits...
Removing dialog normalization...
Creating file "dtheater.m2v"...
There's a change from interlaced to progressive in the middle of stream.
Old 26th March 2008, 08:18   #3996  |  Link
madshi
That's bad. My MPEG2 handling module explicitly disallows changes from interlaced to progressive. But if D-Theater actually uses that, I might have no choice than to support it. This has nothing to do with the new TS/M2TS support, though. It's a limitation of my MPEG2 code.
Old 26th March 2008, 08:54   #3997  |  Link
G_M_C
Hi Madshi,
I know i've asked this before, and i know i havent followed this thread as well as i did; But have you made it possible to de/transcode (regular) AC3 with libav at this time ?
As i said earlier; I dont have Nero installed, and i try to use as much Open Source software as possible; So i am really interested in a feature like this. And i ask this again because somewhere earlier in this thread it was mentioned that libav's decoding had been improved (afaik).
G_M_C is offline   Reply With Quote
Old 26th March 2008, 09:10   #3998  |  Link
yonta
Originally Posted by G_M_C View Post
Hi Madshi,
It looks like eac3to can decode ac3 with libav.
I converted an ac3 file to a lower bitrate ac3 file with this command line on a pc without nero or sonic decoders.
eac3to.exe 384kbps.ac3 192kbps.ac3 -192 -libav
yonta is offline   Reply With Quote
Old 26th March 2008, 09:15   #3999  |  Link
madshi
Great, that's the kind of feedback that I like to hear...
Yes. eac3to can decode E-AC3, AC3, DTS and TrueHD/MLP with libav.
Old 26th March 2008, 10:54   #4000  |  Link
G_M_C
Thx Madshi for implementing the option
(even if you allready did that a long time ago, and i missed it )
eac3to
