15th August 2010, 01:12 | #4141 | Link | |
Rendering performance for my HD4890 1GB on the 720 H264 file is about 55% resizing up to 1680x1050. So it would make sense that the HD5750 512MB resizing to 1920x1080 is having a much harder time.
I thought performance was better than this though, I have been mostly playing back SD content so perhaps I underestimated just how hard the GPU has to work in order to achieve an upscale to 1920x1080 from 1280x720 using Lanczos4 and Softcubic100. Quote:
*Update* Changed the screen resolution to 1280x720 and resizers to bilinear, GPU is till at 90%, weird considering the screen resolution is now the same as source file. Tested with version 0.11/0.12 and Bilinear upscaling, downscaling and resampling offer smooth performance with GPU at 50% Cranking it up to Lanczos4 and Softcubic100 still offers acceptable performance at around 80% and frames are only dropped on startup. 0.13 is where things get incredibly slow displaying the 720 H264 vid, setting all to bilinear the GPU is still at 90% and frames drop like crazy. Madshi, let me know if you would like a log. Last edited by ryrynz; 15th August 2010 at 09:01. |
15th August 2010, 09:20 | #4143 | Link | |
This would be counter productive as MadVR's purpose is to do this convertion in the most precise manner possible. If you take a look at the screenshots in the 1st page you'll see the kind of quality difference you can expect. You can still use FFDshow for other processing but stay in YV12. |
15th August 2010, 09:22 | #4144 | Link | |
Catalyst 10.6 and MPC-HC 1.3.2099. |
16th August 2010, 02:08 | #4149 | Link |
I have the fullscreen refresh-rate autochange enabled at MPC-HC, so when I play a 23.976fps file, the refresh rate changes from 60Hz to 24Hz when I go fullscreen. Everything ok for now. After being fullscreen and at 24Hz, if i rightclick my mouse to open the menu of MPC-HC then madVR goes to Windowed mode and the refresh rate goes back to 60Hz and never returns to 24Hz, not even if I un-fullscreen and fullscreen it again. It changes to exclusive mode if I leave my mouse alone, but the 24Hz is lost until I restart the player. This doesn't happen with EVR Custom, for example. Any ideas? Bat
Win 11 x64, Geforce RTX 4060 Ti 16GB, TV Sony KD-55X8509C HDMI, Denon AVR-X2700H, Core i7-9700K, 32GB DDR4, Creative Labs Gigaworks S750 7.1 speakers MPC Home-Cinema madVR LAV Filters |
16th August 2010, 04:07 | #4150 | Link |
madshi, I have two feature requests.
1) An option to downsize to half resolution on initial file open when resolution of source file is > resolution of screen. 2) I have mixed feelings about the "Sharpness" option in Haali Renderer. I like the look it provides when upscaling from a regular dvd resolution or files around that resolution to 1920 x 1080. However, afaik the sharpening can increase noise or create other problems can it not? Anyways please share your thoughts on this. Thanks. |
16th August 2010, 04:10 | #4151 | Link | |
16th August 2010, 04:24 | #4152 | Link | |
For EVR/CP/Sync, you can't open the context menu in the first place right? Also notice that going fullscreen with D3D fullscreen mode does not really count as "going" fullscreen as far as autochange concern. I submited a ticket about this to MPC-HC tracker. madshi said that eventually madVR will handle refresh rate itself, so we'll be waiting for that I think.
Spec: Intel Core i5-3570K, 8g ram, Intel HD4000, Samsung U28D590 4k monitor+1080p Projector, Windows 10. |
16th August 2010, 05:35 | #4154 | Link |
What are the differences among all the resizing algorithms in madVR? It has always been hard for me to figure out what will work best for my GPU/CPU and memory combination in terms of sharpness and speed/load of rendering. I have a C2D @ 2.66GHz, Win 7 x64, ATi Mobility Radeon HD 4570, 4GB RAM.
16th August 2010, 05:39 | #4155 | Link |
dansrfe, what is the resolution of your screen, also how much GPU RAM?
What resizing algorithms work on your setup? What is your video source? (if relatively noisy or blocky source then use a softer resizer; if you have a blocky video, do not use lanczos) Last edited by namaiki; 16th August 2010 at 05:43. |
16th August 2010, 06:51 | #4156 | Link |
1920 x 1080. 1GB GPU RAM. So far the default resizer of SoftCubic80 stutters on my setup a bit when in fullscreen mode. My video source are very clean DVD sources that I have ripped to mkv files. Usually I stay around 864 x 360 or somewhere around there based on the A/R of the DVD.
16th August 2010, 07:28 | #4158 | Link |
The one selected by default when madVR is first installed. As for the causes of stutter, I really don't know. Haali Renderer or EVR-CP doesn't cause any stuttering for me though. I really want to get madVR to work as best as possible because all other renderers just have one shortcoming or another.
