26th January 2020, 21:53 | #1341 | Link |
Hello!
I have a modified 8mm projector, which captures one frame at a time. As i think, after capture i will need to create an avi file to feed to Fred's script first. Is it possible to modify script somehow to import sequence right away after capture ? I have tried ImageSource with no luck. |
26th January 2020, 22:08 | #1342 | Link |
"With no luck?"
You'll have to be more specific than that. Please post your script (just the ImageSource line is enough), how the pictures are numbered, and the error message VirtualDub gives you when trying to open that script. |
26th January 2020, 23:29 | #1343 | Link | |
ImageSource Wiki but I have used similar features in VirtualDub and also my NLE, Sony Vegas Pro. The only issues I have had with either of those is that
To avoid gaps, you can re-number the sequence prior to import. |
29th January 2020, 11:27 | #1344 | Link | ||||
The important lines are: Quote:
Hope that helps. |
29th January 2020, 22:44 | #1345 | Link | |
@manono, @johnmeyer, thanks!
27th March 2020, 13:32 | #1347 | Link |
-deleted-
Groucho's Avisynth Stuff Last edited by Groucho2004; 27th March 2020 at 15:19. |
27th March 2020, 14:53 | #1348 | Link |
Thanks G2K4.
I note that x86 version is 5KB, x64 38KB, checked and x64 is static linked (no runtimes required). I also note that old x86 version (that I have) requires runtimes MSVCR71.dll which is I think from VS 2003 (maybe also VS Toolkit 2003). Just observations. Dont know what x64 plugs might require AvsRecursion x64, but I've added to my x64 system32 dll storage folder, and also system32. I'll shout if something goes BANG !
27th March 2020, 15:18 | #1349 | Link | |
Please discard the build I posted before.
Groucho's Avisynth Stuff Last edited by Groucho2004; 27th March 2020 at 15:24. |
27th March 2020, 15:26 | #1350 | Link |
Roger Wilco, over and out.
EDIT: AvsRecursion by Rainer Wittmann (think that might be Kassandro) For:- AvsTimer, RemoveGrain, ReduceFlicker, RemoveDirt.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 27th March 2020 at 15:59. |
27th March 2020, 20:41 | #1351 | Link |
IIRC, AvsRecursion is not needed in RgTools
See My Avisynth Stuff |
27th March 2020, 22:35 | #1354 | Link |
Hi all, I recently purchased a moviestuff Retro-8 Pro scanner and have been transferring films and would like to try out fred's script. I have a pretty good knowledge of avisynth, but am just looking for a little direction on what is the best route to take.
I have been exporting 1080p PNG image sequences of the captured film from the moviestuff software. Would it be wise to clean up the edit in Premiere and then re-export a PNG image sequence which I would then process with Fred's script? Any advice on where to start with a script? I know there is Fred's original script, and then John has posted some modifications as well as some others.... I've been reading through a lot of this thread but it's pretty overwhelming. Thanks |
27th March 2020, 22:46 | #1355 | Link | |
It depends on the footage specifics and what you mean by "clean up the edit in Premiere" What were you planning to do in PP exactly ? What are you doing in PP that cannot be done in the avs script? or what are you doing in PP that would benefit the results of the script processing ? |
27th March 2020, 22:48 | #1356 | Link | |
28th March 2020, 01:59 | #1358 | Link |
Groucho's Avisynth Stuff |
17th May 2020, 04:18 | #1359 | Link |
don't know what super means
I'm trying Minusthebear script on page 64. When I try to run it I get this
AVSMeter 2.9.9.2 (x64), 2012-2020, (c) Groucho2004 AviSynth+ 0.1 (r2772, MT, x86_64) (0.1.0.0) I don't know what 'super' means. (C:\Users\ME\Desktop\Seemtobe working\newtest.avs, line 205) PS C:\Users\ME\Desktop\Seemtobe working> Referencing this part of the script. #DEGRAINING/SHARPENING #................................................................................................................................................................... super_mv = MSuper(cleaned, pel=2, sharp=1) backward_vec2 = MAnalyse(super, isb = true, delta = 2, overlap=4) backward_vec1 = MAnalyse(super, isb = true, delta = 1, overlap=4) forward_vec1 = MAnalyse(super, isb = false, delta = 1, overlap=4) forward_vec2 = MAnalyse(super, isb = false, delta = 2, overlap=4) Any Ideas why? If I comment out those lines it runs. But it's running at 30FPS when I set it to 16 and I only have trim set to 300 but it says 1315 (this changes with different frame input but I can't see a pattern). Where is it getting 30FPS why 1315 frames? I am inputting PNG image files. Thanks for any help on this. AVSMeter 2.9.9.2 (x64), 2012-2020, (c) Groucho2004 AviSynth+ 0.1 (r2772, MT, x86_64) (0.1.0.0) Number of frames: 1315 Length (hh:mm:ss.ms): 00:00:43.833 Frame width: 2048 Frame height: 1600 Framerate: 30.000 (30/1) Colorspace: YV12 Frame (current | last): 461 | 1314 FPS (cur | min | max | avg): 1.729 | 0.099 | 564.0 | 2.991 Process memory usage: 1872 MiB Thread count: 39 CPU usage (current | average): 24.7% | 23.8% Time (elapsed | estimated): 00:02:34.127 | 00:07:19.646 |
