25th December 2007, 00:53 | #2222 | Link |
Hello, I'm having trouble converting a .dtshd 5.1 and 7.1 48/24 track that I have. I have the Sonic Audio Decoder (4.3.0.169) installed but I always get an error when I run the command line.
"The format of the source file could not be detected." Any idea why this is happening? I can play the file fine in Windows Media Player. I can upload the track (it's short--about 2:00) if anyone wants to play with it. By the way, I just downloaded the latest version of this program today. I'm using the GUI, but I could just as easily use the command line version (since I have that too). |
25th December 2007, 01:37 | #2223 | Link | |
But you have a very big delay value, so you'll be able to notice if something wrong. |
25th December 2007, 01:41 | #2224 | Link | |
Anyway, you can upload the track if it's small. |
25th December 2007, 02:10 | #2225 | Link |
Yes, I'm positive it's a DTS-HD file--otherwise it wouldn't have had a .dtshd extension and play correctly.
I'm uploading the 5.1 mix since it's only 20 MB. I'll upload the 7.1 longer mix later if necessary(it's about 90 MB). http://www.sendspace.com/file/f7bw5d EDIT: I'm trying to transcode it to .flac or .wav or even .ac3 if I can get it to work. |
25th December 2007, 02:37 | #2226 | Link |
Your file is a dts-hd track that has only the dts core with no extensions in. This means it's a normal dts file.
Except from the "garbage" it has in the beginning and the end. That's why eac3to can't recognize it. Change the extension to .dts and use latest delaycut (v1.3.0.0) to fix the track (remove the garbage). Then it 'll work. I guess the same applies to the 7.1 track you have. |
25th December 2007, 02:57 | #2227 | Link | |
I'm doing a fast check on audio sync (5 minutes from start and 15 minutes from end). The TrueHD track on Training Day was out of sync. BUT it's out of sync when played back in PowerDVD also. So I guess it's a bad authoring. I hope to go through the whole collection before the end of the year. Then I will move on to the Blu-ray titles. I don't really know how to handle audio delay on movies spread over multiple m2ts files yet. But I guess that's a headache to handle later on. One thing that's bother me though is if I should use 23.976 as timecode or 24000/1001. I can't get perfect smooth playback on some titles (don't know if the timecode provided when muxing the mkvs will make any diffrence). And I'm not sure if it's going to influence audio sync at all (tiny diffrence), My TV (Pioneer LX608) accepts 24p. And the combination of this TV and a nvidia 8600gts (Vista 32) I can output 23, 24, 25, 29, 50, 59, 60. When using 59 (I guess it's 59.97Hz) the audio falls behind (don't know if it's related to the 3:2 pulldown). Choosing 23 (don't know how exact this is but I guess 23.976Hz) results in perfect audio sync but some titles stutters sometimes. Does the timecode I set when remuxing affect this in anyway? Right now I'm starting to believe that 23.976 gives the best result (over 24000/1001) but I'm not sure if it's just my imagination. I know it's the wrong place for this discussion. But it would be great to hear if someone know how the timecode affects audio sync AND smooth video playback. Last edited by rickardk; 25th December 2007 at 03:02. |
25th December 2007, 03:04 | #2228 | Link | |
25th December 2007, 03:04 | #2229 | Link |
I have to ask this, sorry...
Does such thing as 23,976 really exist? Where does it come from? I believe it's 24000/1001(23,9760XXXXX) that is called 23,976 in sort. Nothing more. But maybe i just said a nonsense. |
25th December 2007, 03:07 | #2230 | Link |
v1.3.0.0 is made by madshi (not the original author of delaycut), thus it can be found on this forum, in delaycut thread (use search).
EDIT: here's the link http://madshi.net/delaycut.rar Last edited by nautilus7; 25th December 2007 at 03:14. |
25th December 2007, 03:09 | #2231 | Link |
Don't know. 24000/1001 is the standard for what most titles are mastered at I think. But I guess it's a rounding thing. And that's why I ask. If it will make any diffrence at all on smooth video playback and audio sync.
25th December 2007, 03:22 | #2233 | Link | |
I guess I have a bad understanding in how the frames are handled... Last edited by rickardk; 25th December 2007 at 03:31. |
25th December 2007, 11:23 | #2236 | Link | |||
But audio sync is correct? This could be a software setup related problem. Quote:
You set a timecode when remuxing? How/where? |
25th December 2007, 15:05 | #2237 | Link |
HDConvertToX author
just playing with this tools.. great work!
just to add to wisth list output to stdout (for using with neroaac/lame/oggenc...) parsing of ts files thanks! BHH
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 |
eac3to |
