Old 24th May 2017, 12:25   #861  |  Link
FulciLives
I love this program but as far as I can tell, there is no way to BURN IN subtitles. I would love if you could add this feature. BURN IN subtitles is my preferred method when dealing with a mixed language film (in other words a film that is mostly English but which has some sequence or sequences that are foreign and has forced subs for these parts).
From the reading it seems the program can BURN IN subtitles when working with 3D video but I only work with standard 2D (non-3D) video.
Thanks for a great program that works so well in terms of simplicity as well as quality output!
FulciLives is offline   Reply With Quote
Old 24th May 2017, 22:09   #862  |  Link
pistacho
Originally Posted by iSeries View Post
Hi Pistacho, could AC3 2.0 options be added for video remuxing?
What do you mean? Downmix source AC3 5.1 audio to AC3 2.0?
Why is necessary?
Normally all players can downmix audio to stereo if only two speakers are present (or headphones) and savings in bitrate are not much significant.
pistacho is offline   Reply With Quote
Old 24th May 2017, 22:18   #863  |  Link
pistacho
BURN IN subtitles is not necessary. MKV and AVCHD containers support forced subtitles (flagged forced) as in original Blu-Ray.
Burn in subtitles is only the last resort when player not support other options...
Currently ALL decent MKV and AVCHD players supports forced subs.
Old 24th May 2017, 22:40   #864  |  Link
FulciLives
@pistacho
I realize this but for forced subs that only pop up some-of-the-time I still like the concept of burnt in subs which simply cannot be missed or accidentally turned off etc. but yeah I know, I get what you are saying.
Thanks for the response.
Old 26th May 2017, 13:12   #865  |  Link
snakeman
Some of my BD9 encodes are a bit too large for my dvd9 media! Did I miss something in the readme file. I have a few that are perfect. I can use overburn on one of my machines and they burn fine, but I cannot play them in my software or hardware players.
snakeman,
These are the ones I'm converting from BD50 3D to BD9 mvc 3d
Thanks
snakeman is offline   Reply With Quote
Old 29th May 2017, 09:01   #866  |  Link
pistacho
snakeman,
Thanks
If the conversion has DTS-HD or True-HD (variable bitrate audio) or has enough amount of subtitles remember to use "scan bitrates" button and wait to finish 100% so that the program can calculate the correct bitrate.
Old 29th May 2017, 09:21   #867  |  Link
pistacho
Version 2.7.1 (05/29/2017)
  • Updated: x264 encoder to version 150.2833.
  • Updated: x265 encoder to version 2.4.9.
  • Updated: Mkvmerge to version 12.0.0.
DOWNLOAD => BDtoAVCHD_v2.7.1.msi
Old 29th May 2017, 13:59   #868  |  Link
snakeman
I thought I did, I will try again today.
snakeman
Old 29th May 2017, 22:46   #869  |  Link
snakeman
snakeman
Same thing, Do you have old versions available?
Everything dated before May 12, 2017 shows the correct size!
Oops found the older versions! I will report back.
I have tried as far back as 2.6.7 no luck! It could be the size of the movies I guess.
Thanks for all the help,
snakeman
Old 19th July 2017, 22:05   #870  |  Link
pistacho
Version 2.7.3 (07/19/2017)
  • Updated: MVC tools to Intel Media SDK 2017 R1 (API 1.23).
  • Updated: x264 encoder to version 152.2851.
  • Updated: x265 encoder to version 2.5.1.
  • Updated: Mkvmerge to version 13.0.0.
DOWNLOAD => BDtoAVCHD_v2.7.3.msi
Old 8th August 2017, 11:13   #871  |  Link
pistacho
Version 2.7.4 (08/08/2017)
  • Fixed: In MVC 3D conversions incompatible output formats can be selected by default (depending on saved preferences).
  • Updated: x265 encoder to version 2.5.4.
  • Updated: Mkvmerge to version 14.0.0.
DOWNLOAD => BDtoAVCHD_v2.7.4.msi
Old 1st December 2017, 10:11   #872  |  Link
pistacho
Version 2.7.5 (12/01/2017)
  • Changed: Drop Windows XP support. Minimum version is now Windows 7.
  • Updated: runtime libraries and internal Visual C++ dependencies.
  • Updated: x265 encoder to version 2.6.1.
  • Updated: Mkvmerge to version 18.0.0.
DOWNLOAD => BDtoAVCHD_v2.7.5.msi
Old 1st January 2018, 12:14   #873  |  Link
pistacho
Version 2.7.6 (01/01/2018)
  • Updated: x264 encoder to version 155.2893.
  • Updated: x265 encoder to version 2.6.6.
  • Updated: Mkvmerge to version 19.0.0
DOWNLOAD => BDtoAVCHD_v2.7.6.msi
Old 20th February 2018, 22:56   #874  |  Link
pistacho
Version 2.7.7 (02/20/2018)
  • Updated: x265 encoder to version 2.6.8.
  • Updated: Mkvmerge to version 20.0.0
DOWNLOAD => BDtoAVCHD_v2.7.7.msi
Old 25th February 2018, 19:28   #875  |  Link
robl45
So I mentioned this maybe a year and a half ago, I'm still having the same issue. Sometimes this program works great, other time the video is out of sync as reported by makemkv when I turn it into mkv.
I just did the latest thor movie. completed and then makemkv said their were issues with time sync on the 3d. used dvd fab and no issues reported in makemkv. If I reinstall the video driver that sometimes helps but other times it just isn't doing that movie no matter what. I find most of the times its issues with movies that have subtitles although this movie didn't have subtitles that I needed and still same issue.
robl45 is offline   Reply With Quote
Old 3rd March 2018, 17:47   #876  |  Link
iSeries
Hi Pistacho, for uhd input (mkv output), converting truehd/atmos tracks to flac doesnt seem to be possible. It is for dts-hd ma tracks though. Just wondering why?
iSeries is offline   Reply With Quote
Old 14th March 2018, 18:58   #877  |  Link
pistacho
Does not support UHD input or output at all.
Old 14th March 2018, 19:02   #878  |  Link
pistacho
Version 2.7.8 (03/14/2018)
  • New: In the mpls selection window (Blu-Ray) added an option for preview m2ts using an external player.
  • New: In advanced encoding options added the noise reduction setting for x265 (--nr-intra --nr-inter).
  • Updated: x264 encoder to version 155.2901.
  • Updated: x265 encoder to version 2.7.1.
  • Updated: Mkvmerge to version 21.0.0
DOWNLOAD => BDtoAVCHD_v2.7.8.msi
Old 12th May 2018, 11:24   #879  |  Link
pistacho
Version 2.8.0 (05/12/2018)
  • New: Added support for AviSynth+ (32/64-bit).
  • New: On 64-bit systems with AviSynth+ 64-bit installed, it is used in the 3D-SBS/TAB conversions.
  • Updated: 3D tools to Intel Media SDK 2018 R1 (API 1.26).
  • Updated: x265 encoder to version 2.7.348.
  • Updated: Mkvmerge to version 23.0.0.
DOWNLOAD => BDtoAVCHD_v2.8.0.msi
Old 16th June 2018, 10:17   #880  |  Link
pistacho
Version 2.8.1 (06/16/2018)
  • Updated: x265 encoder to version 2.8.11.
  • Updated: Mkvmerge to version 24.0.0.
DOWNLOAD => BDtoAVCHD_v2.8.1.msi
avchd, bdtoavchd, blu-ray ripper, m2ts, ps3
