Old 23rd September 2017, 20:53   #15141  |  Link
byteshare
ByteShare
byteshare's Avatar
Yes send it.
Okay, I PM'd you with a link.
Old 24th September 2017, 09:54   #15142  |  Link
activoice
Retaining subtitles
Not sure if this has been asked for before and declined...
Can an option be added in the settings to Retain all Subtitle tracks, so that they will all be extracted and automatically muxed when the output is created.
activoice is offline   Reply With Quote
Old 24th September 2017, 12:36   #15143  |  Link
burt123
burt123's Avatar
@ activoice
1st post here...
As far as I know, ALL subtitles are saved into the relevant job folder, but you have to manually add them, if you want them muxed in..there are a couple of different options to do this.
burt123 is offline   Reply With Quote
Old 24th September 2017, 14:57   #15144  |  Link
soneca
Atak, I still have no options on audio tracks with DTS-HD MA sources.
soneca is offline   Reply With Quote
Old 24th September 2017, 16:39   #15145  |  Link
byteshare
ByteShare
byteshare's Avatar
There is an option to Remux Subs in Batch mode. The only problem with this is that if those subs had names (MKV Titles) in the previous file that information is lost.
I manually remux subs after an encode with a batch file for the reason above.
Old 24th September 2017, 20:22   #15146  |  Link
stasi
Pro tip: Never use attachments.
Here is the result of the test.log btw. Ripbot just made an update, thought it was fixed.
ffprobe version N-87294-gec1573f Copyright (c) 2007-2017 the FFmpeg developers
built with gcc 7.1.0 (GCC)
configuration: --enable-gpl --enable-version3 --enable-cuda --enable-cuvid --enable-d3d11va --enable-dxva2 --enable-libmfx --enable-nvenc --enable-avisynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libfreetype --enable-libgme --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenh264 --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs --enable-libxvid --enable-libzimg --enable-lzma --enable-zlib
libavutil 55. 75.100 / 55. 75.100
libavcodec 57.106.101 / 57.106.101
libavformat 57. 82.100 / 57. 82.100
libavdevice 57. 8.101 / 57. 8.101
libavfilter 6.105.100 / 6.105.100
libswscale 4. 7.103 / 4. 7.103
libswresample 2. 8.100 / 2. 8.100
libpostproc 54. 6.100 / 54. 6.100
[avisynth @ 0000000000d63660] FFAudioSource: Audio format change detected. This is currently unsupported. Channels: 6 -> 6; Sample rate: 48000 -> 48000; Sample format: Unknown -> Unknown
(E:\$Temp\RipBot264temp\job1\getinfo.avs, line 4)
E:\$Temp\RipBot264temp\job1\getinfo.avs: Unknown error occurred
Any other format works, except DTS HD MA.
stasi is offline   Reply With Quote
Old 24th September 2017, 20:28   #15147  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
Can you send me some sample to see what is so special about this particular DTS-MA audio. I have many test samples with DTS-MA and FFAudioSource decodes those streams without any problem.
Old 24th September 2017, 20:51   #15148  |  Link
soneca
I tested it with five blu-ray(DTS-MA) and it does not recognize any.
With version 1.19.5 I have no problems.
Old 24th September 2017, 20:55   #15149  |  Link
stasi
Mhm. Original file aborts with that error. A chunk created with DGSplit works fine.
Old 24th September 2017, 21:01   #15150  |  Link
Atak_Snajpera
What is an original file? .m2ts or .mkv?
Old 24th September 2017, 21:03   #15151  |  Link
stasi
MKV Container.
Old 24th September 2017, 21:20   #15152  |  Link
Atak_Snajpera
Looks like damaged audio stream at the very end of file. Does simple remuxing with mkvtoolnix or eac3to works?
Old 24th September 2017, 21:38   #15153  |  Link
stasi
You are right. I created 50MB parts with MKVToolnix. I added random files to Ripbot, and they all work, except the last file.
Edit:
Please check your PM.
Old 25th September 2017, 18:21   #15154  |  Link
soneca
Back to normal, decoding the DTS-MA track again after the last update.
Old 25th September 2017, 19:06   #15155  |  Link
stasi
Works for me, too. NICAudio is back.
Old 25th September 2017, 23:09   #15156  |  Link
Shrekage
After updating all 16 of my encoding servers and my encoding client to 1.21.0 and latest updates, the servers are ALL now giving me this error:
Encoding started...
""\\EC3\Ripbot264temp\tools\avs2yuv\avs2yuv.exe" -seek 0 "\\EC3\RipBot264temp\job285\Chunks\1.avs" -o - | "\\EC3\Ripbot264temp\tools\x264\x264_x64.exe" --crf 20 --fps 30000/1001 --force-cfr  --min-keyint 30 --keyint 300 --frames 1800 --sar 8:9 --level 3.1 --aud --nal-hrd vbr --vbv-bufsize 14000 --vbv-maxrate 14000 --no-cabac --weightp 0 --b-pyramid none  --no-8x8dct  --stdin y4m --output "\\EC3\RipBot264temp\job285\Chunks\1.264" -"
error: failed to load avisynth.dll
y4m [error]: bad sequence header magic
x264 [error]: could not open input file `-'
Encoding terminated.
Connection Closed Gracefully.
I uninstalled AviSynth and installed the batch file for AVISynth+ in your script. I created new encoding jobs as the release notes specify, but still I meet this error, and the encoding servers close the connection.
Shrekage is offline   Reply With Quote
Old 25th September 2017, 23:17   #15157  |  Link
byteshare
ByteShare
byteshare's Avatar
@Shrekage What version does the Encoding Server say AVISynth+ is on?
Old 26th September 2017, 06:44   #15158  |  Link
burt123
burt123's Avatar
I'm getting an annoying random error....
I can queue a job, make adjustments, start the encode, and shortly after it's gathered information, it pop's up an error msg, saying that it can't find that job's "info.txt".....somehow it get's deleted, and the show's over.
This is with the latest version & latest update....
I know I've had this happen before, and pretty sure I was given a "fix", but that was a long time ago
Anyone have any idea's ???
Old 26th September 2017, 08:40   #15159  |  Link
george84
What happened to Advanced Settings?
In Version 1.21.0 two checkboxes have disappeared in Advanced Settings (Use 64bit encoder, Use Avisynth+ MT).
Also I get error message "cannot load 32bit DLL in 64 bit Avisynth".
How can I force use of 32 bit Avisynth?
george84 is offline   Reply With Quote
Old 26th September 2017, 09:46   #15160  |  Link
jandor
jandor's Avatar
Atak,
Put an option (check box) under Settings: >>>> Minimize to Taskbar.
Let RipBot open normally, and at your command you can minimize it to the Taskbar.
Minimizing to the Taskbar is my preference, and I believe it is also that of many users.
jandor is offline   Reply With Quote
