Old 4th March 2010, 12:59   #21  |  Link
longinus525
Finally i can post
I made a icon set for this when this was released(Saturday morning) but i couldnt post because of the 5 days rule
Icon Set (32x32, 24x24 & 16x16)
Here you go :P
http://www.megaupload.com/?d=RA60KGLE
Preview:
longinus525 is offline   Reply With Quote
Old 4th March 2010, 15:52   #22  |  Link
iron2000
Questioning User
Nice one, longinus525!
Can you post it on Mediafire or Stashbox, please?
My ISP don't go well with Megaupload and Rapidshare types.
Thanks
8 Pro x64 | i5-3470 | 8GB ram | GT430 | Xonar DX | MPC-HC x86
iron2000 is offline   Reply With Quote
Old 4th March 2010, 16:35   #23  |  Link
sillKotscha
what's this for?
sillKotscha's Avatar
Originally Posted by Phaser View Post
Here's some more:
DOWNLOAD (size 32)
I really like this one ... possible to do them at 24x24?
thx in advance
latest mix sets: http://soundcloud.com/sill
sillKotscha is offline   Reply With Quote
Old 4th March 2010, 16:58   #24  |  Link
lucamark
Gigibop!!!
Thanks
Download MediaFire
lucamark is offline   Reply With Quote
Old 4th March 2010, 17:48   #25  |  Link
longinus525
Oh thanks by putting the link to mediafire i was going to do it now, but i guess i was late, i also have the .psd template with guidelines for all 3 sizes, guess im going to put them later when i put another button set (p.s. i really think we should have a repository for this things)
Old 4th March 2010, 18:13   #26  |  Link
Phaser
thx in advance
Here it is:
DOWNLOAD (size 24)
I'll do some more stuff when I have the time...
Phaser is offline   Reply With Quote
Old 4th March 2010, 19:32   #27  |  Link
sillKotscha
what's this for?
great, thank you
Old 31st March 2010, 13:23   #28  |  Link
Scoty
Scoty's Avatar
Please more skins.
Gaming-PC: AMD 7700X | RTX 4070 Ti | ASUS ROG Strix X670E-E Gaming WIFI | G-Skill RGB 32GB, DDR5-6000 | Corsair HX1200 | Lian Li Air Mini |
Scoty is offline   Reply With Quote
Old 3rd April 2010, 07:09   #29  |  Link
click2
aka mappy
click2's Avatar
I've been using a slightly toned-down toolbar for a long time now by swapping out the resource image on every update, so it's good to see this feature.
<Dark_Shikari> its linux, I don't really care :: <pengvado> #x264 is not for dancing.
click2 is offline   Reply With Quote
Old 8th August 2010, 11:53   #30  |  Link
wOxxOm
Oz of the zOo
I don't use button bar at all for a few years (actually no menu as well ^.- ), only a timeline slider which could have been skinned manually via resource hack, but alas, even this doesn't work.
Of course one can recompile mpchc and set color values in CPlayerSeekBar::OnPaint yet as I don't have such an environment, I've used hiew to patch bytes directly, so this is my lame attempt at skinning 8:
wOxxOm is offline   Reply With Quote
Old 9th August 2010, 02:01   #31  |  Link
cafevincent
I'm looking for a skin without the volume adjuster. It can't be disabled so I need it to be invisible so nobody uses it. Meaning it should be invisible when it's at 100% volume.
cafevincent is offline   Reply With Quote
Old 9th August 2010, 04:17   #32  |  Link
burfadel
Here's some more:
DOWNLOAD (size 32)
DOWNLOAD (size 32)
I like the crystalblue one too. I would like to see a 'crystal' stop button in red, and a pause button in orange and the step button maybe a nice green or something? At least the pause and stop buttons orange and red to contrast against the play button.
Actually both of Phaser's are excellent, and the bottom one I think should be the new default (even if just for now). The Crystal blue (or crystal blue mod) should be and internal option. Afterall, it doesn't take much file size space to have a few options!
Old 9th August 2010, 08:57   #33  |  Link
Mercury_22
1. Can somebody make the "autohide" option for the this toolbar available in the windowed mode TOO (it's already available in full screen) ?
2. Can the toolbar be made transparent ? or at least changed the color (black) ?
3. I agree Phaser's "Crystal blue" should be add as default
@ Phaser's can you make the center of the Stop button in red and the Play's one in green ? Also can you change the Volume button with the one from the other mod ?
Intel UHD Graphics 750; Win 10 22H2
Mercury_22 is offline   Reply With Quote
Old 12th August 2010, 22:11   #34  |  Link
6205
toolbar
My Simple Gradient toolbar
6205 is offline   Reply With Quote
Old 5th March 2011, 11:37   #35  |  Link
jinsk8r
Just created a new toolbar.
Preview:
Sorry for digging this topic but I think we should create more "toolbars" to refresh old-looking MPC-HC :P
P.s: I'll make some more toolbars, maybe GUI modding|tweaking with Restorator "patch" feature
jinsk8r is offline   Reply With Quote
Old 5th March 2011, 12:34   #36  |  Link
bledd
Not sure about QT but are there more modern looking QT widgets?
Anyway I made a 3 simple toolbars using the GUI fx font:
Download
Also a 16px template:
Download
I prefer size 16px and either square or icon style :P
This should be made the default, makes it look modern and sleek
bledd is offline   Reply With Quote
Old 6th March 2011, 11:17   #37  |  Link
jinsk8r
IMO the icons should be at least 32x32 as our desktop resolutions are very high (1920x1080 and bigger) :\
Old 7th March 2011, 12:09   #38  |  Link
jinsk8r
Black Toolbar:
Preview:
Old 8th March 2011, 11:56   #39  |  Link
jinsk8r
Windows 7 Taskbar Controls (WMP's default)
1. Download this PNG:
2. Use Reshacker or Restorator to replace the df one:
3. Result:
Old 20th April 2011, 07:48   #40  |  Link
Fluffbutt
Originally Posted by Razoola View Post
Im trying the crystal blue ones but they are appearing in black and white in the player.
I have found that if I open the player only(without movie) then they are black and white. As soon as I load a movie they go blue... Maybe a bug in the code?
I've just found out about this whole button thing - very nice!!
Razoola - they are grey until you load a movie becasue they are 'grey-out' as in unusable without a movie loaded.
When you load a movie, only play is blue, then when you press play the rest go blue too - showing that they are now active buttons.
Well, that's what happens here..
Meeow!
Fluffbutt is offline   Reply With Quote
icons, mpc-hc, toolbar
