3rd March 2013, 13:49 | #281 | Link |
Fantasy Codecs writer
Just noticed using the latest nightly builds (6865) can not use EXternal MPC-HC_standalone_filters! I Have disabled the internal filters!
last git 6d45ff5bc6519e53aad536d9156efc51b44d84a4 have this problem too! Last edited by betaking; 3rd March 2013 at 15:08. |
5th March 2013, 06:22 | #285 | Link |
Hi developers. Why you are not reopened ticket 2931. ??
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /Patriot 32Gb@3200 /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215 |
5th March 2013, 10:45 | #286 | Link | ||
MPC-HC Helper xD
5th March 2013, 13:38 | #288 | Link |
Sorry - all ok.
6th March 2013, 07:35 | #290 | Link | |
6th March 2013, 12:11 | #291 | Link | |
One thing related to this that i find rather stupid is that all the forks of VSFilter don't change the name and CLSID of their filters, which results in MPC-HC thinking this is vanilla VSFilter, which has the exact same features as the ISR, and deserves to be blocked. If the xy-VSFilter people would just change the CLSID of the filter (and possibly the same to include xy as well, for good measure), this wouldn't even happen. Additionally, i have no clue why you would want the ISR for some subtitles but not for others (or vice versa). TL;DR: Ask the xy-VSFilter developers to change the CLSID of their filter, so it doesn't collide with vanilla VSFilter anymore.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 6th March 2013 at 12:21. |
6th March 2013, 17:28 | #294 | Link | |
But using different renderers for external/embedded subs is just silly.
MPC-HC 2.1.7.2 |
7th March 2013, 10:23 | #295 | Link |
Broadband Junkie
The main reason why xy-VSFilter has maintained the original CLSID, is to maintain drop-in compatibility with any existing third-part applications or codecs which either manually load or contain workarounds for VSFilter.dll
IMHO, blocking VSFilter.dll in MPC-HC when the ISR is enabled is the correct behavior to have, otherwise you risk problem like the ISR rendering subtitles on top of VSFilter.dll rendering and killing performance. Unfortunately there is a lot of bad advice on the internet, and anybody who sets the non-autoloading version "DirectVobSub" to prefer in MPC-HC will cause both ISR and VSFilter to render subtitles at the same time, even in the current version I tested 1.6.6.6899. This is by far the most common issue I've seen people run into when they attempt to migrate from using the MPC-HC ISR to VSFilter.dll. If MPC-HC really does have a hidden "BlockVSFilter" key in the registry, in many ways I would like if it would also block would also cover "DirectVobSub" set to prefer in the external filters when the ISR is enabled, like it already does for the auto-loading version. This would have a large benefit of fixing what I suspect are a large number of semi-broken MPC-HC subtitle setups in the wild. The users who require this specific behavior would still be able to enable it by disabling the hidden BlockVSFilter registry key. On the other side, it can also still confusing to many users that the poorly labeled "Auto-load subtitles" setting in MPC-HC control is really an "Enable MPC-HC ISR subtitle auto-loading / Disable VSFilter" toggle. I would normally suggest adding informative tooltips, but that would likely confuse users even more. At some point the entire subtitle settings dialog likely needs to be redesigned to more gracefully control whether the internal or potentially one of multiple external subtitle renderers is allowed to load. This entire situation is just going to get more complex once xy_sub_filter using the new subtitle interface is released, with only madVR initially supporting it. Last edited by cyberbeing; 7th March 2013 at 13:30. |
7th March 2013, 10:54 | #296 | Link |
I think it could be useful to have the ability to display more than one subtitles on screen (AFAIK currently this is only possible using two different subtitle renderers, right?).
For example if you are using a teaching video you can have to the original language subtitles and ones in your native language position at a different place on the screen. This way the viewer can hear and see the original language and at the same time see the translation. I'm not saying that this is a common usage but it has practical benefits so why remove it?
Z370M Pro4 | i3-8100 | 16GB RAM | 256GB SSD + 40TB NAS NVIDIA GTX 1060 6GB (385.28) | LG OLED65B7V Win 10 64bit 1803 + Zoom Player v14 |
14th March 2013, 04:34 | #297 | Link |
http://pan.baidu.com/share/link?shar...&uk=3558042035
Can't recognize audio track(AAC), lav splitter is fine. |
14th March 2013, 19:05 | #298 | Link | |
MPC-HC Helper xD
17th March 2013, 20:26 | #299 | Link |
MPC-HC Helper xD
1.6.6 has been released!
After 3 months since the last stable build, we decided to release 1.6.6.
This release has many bugfixes and a few new features. Also, the binaries are digitally signed so you can easily verify their integrity. Highlights of this release:
Also besides the usual localization updates a new Romanian localization has been added. We thank our translators for keeping MPC-HC accessible to our non-English users. You can download the new version here. For the complete changes see the changelog. And if you're interested in looking at commits since the last stable you can see it here. We've had 591 commits by 22 authors.
MPC-HC Links: official nightlies | Trac | GitHub | git log | IRC | Twitter | Facebook Last edited by vBm; 17th March 2013 at 20:47. Reason: added changelog links |
17th March 2013, 21:41 | #300 | Link | |
Does version 1.6.6 correct as planned the subtitle language advanced selection provided by lav / haali splitter broken after mpc-hc 1.6.6.6500 ?
Thanks for your work. |
dxva, media player classic, mpc, mpc-hc |
