21st August 2017, 18:34 | #15042 | Link |
I hope you are not encoding interlaced footage as progressive...
21st August 2017, 19:00 | #15043 | Link |
No no, I don't think so. After all MediaInfo says interleaved, top field first.
Edit: Deinterlacing is super slow to me around 2 fps / sec. For this project I will not deinterlace. Now I will try 2 pass mode, seems faster. First try I make 1 pass mode and locked size (7300 kbps) 2 hours video encoded for 8 hours. Audio encode AC3 first in Vegas, cuz singpost is too slow in frameserver and then laod it in ripbot. The mada***s for second then power goes off when encode was almost complete... Last edited by MAX9; 22nd August 2017 at 06:04. |
22nd August 2017, 00:15 | #15044 | Link |
Hello Atak, I tested again using the same material and in version 1.19.5 does not freeze, the detection and the cut are much faster than in version 1.20.0.
I continued testing with version 1.20.0 and it worked. On the first test it did not work and on the second it worked. Sources for the test: Video ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings, CABAC : Yes Format settings, RefFrames : 4 frames Codec ID : 27 Duration : 5 min 1 s Bit rate mode : Constant Nominal bit rate : 30.0 Mb/s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 29.970 (30000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : MBAFF Scan type, store method : Interleaved fields Scan order : Top Field First Bits/(Pixel*Frame) : 0.483 |
22nd August 2017, 12:41 | #15045 | Link | |
Summary 1) Do not resize in vegas nor in ripbot264 anamorphic 1440x1080 to 1920x1080. Less pixels to encode = faster encoding 2) Do not use 2-pass. Use Constant Quality mode (CRF20). Single pass is always faster than two passes. Besides you do not have to guess "optimal" bitrate for you video. In Constant Quality mode encoder dynamically adjust bitrate needed for specific footage. Ps. Writing "2 fps / sec" makes no sense because it means 2 frames per second per second.
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 22nd August 2017 at 12:46. |
22nd August 2017, 13:18 | #15046 | Link |
OK, but the first thing I try is to encode in everything default and the final result is displayed 4:3. I even try to add --sar 4:3 in AviSynth menu, but show error or must be add to profile code?
I use 1 pass mode beacuse i need defined size of the file. 2 fps / sec I mean that is the speed it encode. |
22nd August 2017, 13:51 | #15047 | Link | ||
After encoding mediainfo should show Display Aspect Ratio: 16:9 Quote:
It is like saying that my car's speed is 100 kph/h
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 22nd August 2017 at 13:56. |
22nd August 2017, 15:03 | #15048 | Link | |||||
This is what I get: And this is commands i get when i just add file from frameserver Quote:
Ok I try to encode just one raw file and everything is like you say: automatically add --sar 4:3 but through frameserve something goes wrong Quote:
22nd August 2017, 17:55 | #15050 | Link | |
@MAX9
Yes, you are right frameserved .avi has wrong --sar value like you said. I will have to check what is happening under the hood. I've also noticed that hanging is most likely cause by ResampleMT. I guess I will have to restore old method in next update. Quote:
22nd August 2017, 23:55 | #15051 | Link |
Atak, in any future version could come back with the option(.ini) to minimize to the taskbar?
For the tray it is annoying to check the tempo of the encode unless the status was shown when the cursor is on top. |
23rd August 2017, 15:48 | #15052 | Link |
Is there any way to have the encoding client shut down the servers, without shutting down the client? I am running a client that is NOT encoding, and I wish that machine not to shut down, but have the servers shut down when encoding finished
23rd August 2017, 16:57 | #15054 | Link |
Croping does not change anything in this case. Still --sar 1:1 will be used.
23rd August 2017, 21:43 | #15056 | Link |
@Atak
After one major update (can't remember which) when the main PC freezes, or restarts, generally everything unexpected happens when I restart the program it doesn't see the finished chunks in temp folder to continue from that point, and restarts the job, massive waste of time
E5 2697 v2 @ 3.0GHz on P9X79 Deluxe 24GB Xeon E5-2680 v2 @ 3.1GHz 16GB Sony Vaio VPC-F13Z1E/B |
24th August 2017, 10:20 | #15057 | Link |
Something weird is happening to me. Since the last update, if I choose in AviSynth to resize the content to HD-Ready, the "info.txt" file in the job directory will be deleted. and I'll get the following error: --------------------------- Application Error --------------------------- Exception EFOpenError in module EncodingClient.exe at 0002418E. Cannot open file "E:\Temp\RipBot264temp\job1\info.txt". The system cannot find the file specified. --------------------------- OK --------------------------- If I change it back to no resize, the file will be created and everything is fine. |
24th August 2017, 10:36 | #15058 | Link |
Most likely result of buggy ResampleMT plugin. Make sure that you have video=Spline36Resize() in your script instead of video=Spline36ResizeMT()
30th August 2017, 16:26 | #15060 | Link |
Is there any way to increase the CPU utilization of the encoding process when using the denoise option MDegrain (SLOW) seems like it is slow because it is not multi-threaded. (on that machine, even with DE enabled and all 16 encoders targeted to that machine, only about 60% utilization occurs...)
