20th May 2007, 23:14 | #1161 | Link |
OR simply stop supporting drm crippled music.
FairUse Did its job if you were tricked into these services/online stores. Then there was a way to get your music drm free. But by now you should know better even with the lawsuit dropped it looks like the creator won't be coming back anytime soon and as the digital music stores/services and microsoft continue to update their software FairUse will become more and more outdated when dealing with the updates. |
21st May 2007, 06:58 | #1162 | Link |
cdeviney (and hicux): If you look at the other posts in the forum (look back a few pages), you will see that it /is/ possible to revert to FU4WM-friendly components, but simply using system restore or the built-in tools Microsoft gives you will not work (obviously).
You should still be able to use the newer version of Yahoo! Unlimited, as the rollback won't touch those components, however. If not, just be glad it lasted for as long as it did. |
21st May 2007, 17:35 | #1165 | Link |
WalterK: The ultimate goal, of course, is to get rid of the DRM completely, from end-to-end, but for now, the only way to get most mainstream music online is through a DRM-enabled store. I agree that non-DRM'd content should be purchased whenever available. It seems that Viodentia will not be coming back, (or Monkeyboy, for that matter...no one ever remembers him...), but until then, we can all gather round in a circle and sing Kumbaya.
23rd May 2007, 11:26 | #1167 | Link |
Suspended for forum rule violations
When doing a properties on music in urge it says they are 129kbps so that's where I got my info. I was inside windows vista RC1 and using media player. i installed the urge thing just to see it. did not sign up. doing properties on music it says 129kbps. if when downloaded they are better then 128k that's cool then.
24th May 2007, 02:05 | #1170 | Link | |
"Extraction in progress on "Indiv03.key" 11.0.6000.6324 -- Please wait. Phase 0 : Blocks: 1340 Large 0 Small, Errors: 0,1 Candidates: 4,3,2 Failure - Unable to identify RC4 and AES internal keys." |
25th May 2007, 13:36 | #1173 | Link |
Question: I want to do all of my FU4WM stuff on a Virtual Machine so that I don't have to worry about messing with my Windows Media Player files (it also allows easy backup of your entire subscription account/fles/keys, etc for multiple PCs). I'd like the VM drive image to be as small as possible, so I have a question:
Is FU4WM Windows XP-only? Can I install WMP10 beta on Windows 2000 or something with a smaller footprint and still use FU4WM? |
26th May 2007, 00:18 | #1174 | Link |
I think it's interesting how much credit people give Viodentia. Not that he isn't the man for creating this, but he even says in his first post that FU4WM is just a GUI for DrmDbg. Sure the updates to the program foiled Microsoft's patches, but it's really the codebase from DrmDbg that made it all possible. Monkeyboy is responsible for the latest fix, enabling us to use 11.0.57 and before.
I wonder what "lark" is up to these days P.S. I'm curious as to why the files in my %ALLUSERSPROFILE%\DRM folder are version 11.0.6 when my ibx is 11.0.57. What's the disconnect here? |
26th May 2007, 15:19 | #1175 | Link |
CZroe it might work in windows 2000 but i am not sure.
It was listed as being Xp only. Secondly you can install a small version of XP on a virtual machine say an image about 350mb or less. How? Simply use nlite (google search) and have your original windows installation CD, you can then pick and choose what will be taken from the orginal cd and windows updates to be put on the image. After creating simply mount the image with daemon tools or burn to a cd and install on your virtual machine. Note Nlite does not work with Win9X. |
27th May 2007, 02:34 | #1176 | Link |
I'm not sure if this has been brought up yet, but after I installed Zune, my undrm'ing process wouldn't work (and this was caused because of Zune)... so I just uninstalled Zune, uninstalled WMP and everything else, then reinstalled WMP, no Zune this time, and it works... only thing is, I'd love to have Zune accessible so I can play music from my HDD on my X360... but if I have to use my iPod... that really doesn't bother me, just was wondering if there's a way around this.
30th May 2007, 05:42 | #1178 | Link |
I was using FairUse to remove DRM from many albums in my library when it stopped working after I updated my system. Now I would like to determine which files in my library are still protected with DRM. Does anyone know how to search for WMA files that are still under DRM?
30th May 2007, 05:47 | #1179 | Link |
schil: WMP can tell you which files are still protected. Go to the songs menu item in your library and enter "Protected:yes" (minus the quotes) in the search box. This will list all of your protected files.
Another way is to use FairUseCommander, a program that works with FairUse4WM to batch convert protected tracks. If the checkbox is selected, it will find for you and que up your protected files to be converted. It's quite handy. If you want to know how to revert your system to be able to unDRM again (it's really simple), or just want a copy of FairUseCommander, drop me a private message. |
