3rd October 2006, 20:32 | #361 | Link |
Mr. Sandman
Another mirror can't be a bad thing:
http://www.webalice.it/f.corriga/misc/FU4WMver13.zip However he's right, the 2nd post link doesnt work.
4th October 2006, 01:41 | #363 | Link |
Mr. Sandman
Im at home with flu so im actually quite polite...
But im much less polite when im stressed by my job. Everyone has his own crappy day... However more mirrors are welcome since i dont know how much time i can keep it up...
4th October 2006, 01:53 | #364 | Link |
MAGIK
Mirror - Version 1.3
4th October 2006, 04:05 | #366 | Link |
-9020 error...Please help.
I'm kind of a newbee here but I was hoping someone could help me with this one.
I am using FairUse4WM v1.3 and amd getting an error when trying to remove the drm. The DrmClien.DLL version is 10.0.0.3802 The IndivBox.key version is 10.0.0.3930 After I play a song and close WM I get an error... "Unhandled situation -9020 while Creating Windows Media instance." I tried this on a bunch of songs (all of which I own) but always get the same error. I downloaded a few samples from ezdrm.com but I always get the warning that the song requires a different private key. Is there something I need to do in addition to running FairUse4WM? I was able to get this to work at work (don't remember the file versions - yes I downloaded songs at work) without a problem but can't get it to work at home. I've tried different songs but cannot get it to work. Please help...Thanks |
4th October 2006, 05:11 | #368 | Link | |
Per this post, I was going to re-individualize to see if the keys could be extracted as secondary keys, but I haven't fully decided on it, as I can't re-download these particular files or get licenses for them again. Do you have files you could re-download and re-acquire licenses for? If so, you could re-individualize and try FU4WM again. Back up your C:\Documents and Settings\All Users\DRM folder before re-individualizing, in case you need to restore it later. After you re-individualize, try to unDRM your files first, before acquiring any new licenses. If it doesn't work, then try acquiring new licenses. You could also try dropping the files into the list in FU4WM, right-clicking and getting the key info, and then using that with drm2wmv, but it won't work for me (no private key found for the files). |
4th October 2006, 07:08 | #369 | Link |
using ver. 1.3 to convert, i get following:
UNABLE TO DECRYPT: Error writing 8948 bytes (155) at offset 1499136 in file ... i tried new keys for files, no luck. when i logged on to a certain service, it first updated wmp11. ideas? i tried to undrm files i had just dloaded. Last edited by blutach; 4th October 2006 at 07:21. |
4th October 2006, 09:22 | #370 | Link | |
I'm still in problems with a few of my audio files with 1.3: Properties of the files claim they are unrestricted and therefore not "one-play"-files. They however, work fine in WMP. It's only happening to a few files from the same album, and I have not had problems with files bought from other stores. Error is "... does not appear to be licensed to you" Last edited by odyssey; 4th October 2006 at 09:28. |
4th October 2006, 18:03 | #375 | Link |
FairUseWM saves the day!!
One of my clients PC had a motherboard with leaking capacitors. After about an hour his machine would start to flake out.
Over the past year he spent hundreds of dollars purchasing music via his online service. Since he used WMP10 I tried to backup his license and restore it on his new system....surprise it didn't work. So thanks to viodentia amazing FairUseWM, my client was able to recover the music he paid for and save himself hundreds of dollars. What a classic example of this tool's ability to protect my clients fair use rights. Thanks viodentia! Keep up the good work we are all behind you. |
5th October 2006, 03:25 | #376 | Link |
Thanks UsedUser for your reply -
I'm still a bit confused though. I was hoping I could just find the keys and convert the files but I guess nothing in life is easy. All I want to do is back up MY music in its original format in case my machine dies. I believe I have the licenses on my machine since I can play the songs. I can't redownload them unless I contact them (Walmart.com). I was hoping to get this to work without having to download the songs again. I really don't want to update my WMP just in case I can still remove the DRM with the version I have now. I individualized with the files from ezdrm.com, do I need to continue doing this each time? I got a copy of drm2wmv but I'm not really sure how to use it. I looked at pages and pages in the forums and it's not really that straightforward. I'm not sure I want to screw around with the files in my DRM folder because if I hose them up, I'm really screwed. If you or anyone else has any other suggestions in solving this "Unhandled situation -9020 while Creating Windows Media instance." error, I would really appreciate it. Thanks |
5th October 2006, 17:44 | #379 | Link |
Incredible Program
Because of it, myself and two other friends are paying members of Yahoo! Unlimited.
DRM makes online music very unappealing. They don't get that. Is it possible to have FairUse4WM remember the file path in its next version? Hate to seem whiny, but that really is the only flaw with the program. Thanks. |
