26th March 2014, 14:30 | #321 | Link | |
Note: On the discs in question PDVD/TMT uses the pop up menu to allow you to return to the menu. Last edited by ddjmagic; 26th March 2014 at 14:34. |
26th March 2014, 15:00 | #322 | Link |
Just to clarify here - 8/8 of the sample discs I have posted contain a selectable Pop Up menu in PDVD/TMT, only 2/8 have a selectable Pop-Up menu in demo player (both are HDMV)
Without the Pop-Up menu there is no way to get back to the menu or select features of any of these discs once the movie has started. |
26th March 2014, 15:26 | #324 | Link | |
It is selectable and works perfectly on all HDMV discs I have tried. It would save having to keep restarting the disc after testing each aspect of the menu. A couple questions on compiling the latest source - Any particular version of Eclipse needed? or will the 'Standard 4.3.2' be OK? Do I get the latest libbluray source from the Videolan git? |
26th March 2014, 21:11 | #328 | Link |
More Samples.
A few samples (it's actually quite difficult to find a disc that fails to load at all )
Cabin in the Woods (US Region A) Gets stuck in BD_EVENT_NONE/BD_EVENT_IDLE loop and never loads a menu. Part 1 Here Comes The Boom (US Region A) Gets stuck in BD_EVENT_NONE/BD_EVENT_IDLE loop and never loads a menu. Part 1 Part 2 Note: On both of these discs samples I had to blank a bunch of trailers to save space/time, so hopefully they are still OK (they still load to a menu in TMT) Now a couple of cool menus that load perfectly if anyone wants to look/play around with - Django Unchained (US Region A) Part 1 Mrs Doubtfire (US Region A) Part 1 Note: There is no movie/features files, just enough to show the menu. Also I am still using the last build of libbluray as I failed at trying to compile the latest source Last edited by ddjmagic; 12th April 2014 at 18:58. |
27th March 2014, 11:10 | #330 | Link | |
Is that the correct procedure to update the jar file? This is the error I get - Screenshot Last edited by ddjmagic; 27th March 2014 at 11:14. |
8th April 2014, 16:29 | #334 | Link |
Yes it's a lot better There is an option in crank to turn on menu animations and that generally works quite nicely. Crank so far is the only BD i've come across that uses image scaling. Those 2 samples you posted above, I couldn't get either to work with powerdvd, maybe missing files or something.
8th April 2014, 16:42 | #335 | Link | |
I'll take a look and see if I can find out where it went wrong and post fixed samples |
8th April 2014, 18:20 | #338 | Link |
I've had a look a the "Here Comes The Boom" sample and it looks like 00033.m2ts & 00034.m2ts are missing, if you add a couple of blank files it should then work.
Not sure why Cabin in the Woods sample doesn't work (it does in TMT, but not PDVD) |
8th April 2014, 18:50 | #339 | Link | |
Same error for evr dll also. It seems like the full path to the file is needed so it can be registered succesfully. Last edited by nautilus7; 8th April 2014 at 18:53. |
