Old 13th May 2005, 14:00   #61  |  Link
planet1
... space nerd ...
planet1's Avatar
@ SeeMoreDigital
You can play the raw .cmp & .h264 streams with e.g. mplayer.
for .mp4 -> .avi - "Extract Video to AVI file" (mpeg-4 asp only):
mp4box -avi 2 filename.mp4
2 = TrackID (video)
the funny thing is -avi also works for mp4 with avc
(mp4box should refuse to do that imho - since it cant do it correctly and also uses fcc=xvid)
@Kurtnoise13
afaik QCP Files (.qcp) should be listed in the audio import section only.
planet1 is offline
Old 13th May 2005, 14:13   #62  |  Link
planet1
... space nerd ...
planet1's Avatar
Originally posted by Kurtnoise13
@Planet1 : could you try this one please and tell me if all it's ok.
fixed !
so what was the problem ?
regarding that Note - mp4box seems to extract subs correctly:
mp4box -ttxt 5 mummy2.mp4
5 = TrackID (sub)
http://gpac.sourceforge.net/auth_mp4box.php
apparently two options:
-ttxt TrackID : dumps text track to TTXT XML format.
-srt TrackID : dumps text track to SRT format.
for chapters you'd better ask bond a.k.a the mp4-guru
planet1 is offline
Old 13th May 2005, 14:31   #63  |  Link
planet1
... space nerd ...
planet1's Avatar
@Kurtnoise13
it would be nice if you could complement the video muxing section with a "framerate option" because mp4box always uses 25.00 fps for raw video
switch e.g.: -fps 23.976
planet1 is offline
Old 13th May 2005, 14:44   #64  |  Link
SeeMoreDigital
Life looks better in UHD
SeeMoreDigital's Avatar
Originally posted by planet1
.for .mp4 -> .avi - "Extract Video to AVI file" (mpeg-4 asp only):
2 = TrackID (video)
So you are saying .MP4 ASP to .AVI de-muxing is possible via command line?
Cheers
SeeMoreDigital is offline
Old 13th May 2005, 15:15   #65  |  Link
planet1
... space nerd ...
planet1's Avatar
yeah that transmuxing is possible
planet1 is offline
Old 13th May 2005, 16:49   #66  |  Link
Kurtnoise
Swallowed in the Sea
Kurtnoise's Avatar
@Kurtnoise13
Force Frame-Rate option should do the trick (right click on Import Options in Video box).
@neo_anderson: with a Text Editor.
Kurtnoise is offline
Old 13th May 2005, 17:08   #67  |  Link
Koti
Always trying
Koti's Avatar
Awesome work - finally can make a Mp4 file with multiple audio , subs and chapters.
Small snag here , force frame rate option shows but will not allow selection ( check box will not tick and open frame rate value for changing to needed setting )
(Edit) other issue , on my PC i have to select show commandline just to get the GUI to show itself below the output file box ( I cannot see options / mux line ) Once thats selected I can see all the GUI fine but the command line still will not show unless I enable program to run in fullscreen , WinXP Corp - 1600x1200 res Ty
Koti is offline
Old 13th May 2005, 17:14   #68  |  Link
planet1
... space nerd ...
planet1's Avatar
confirmed
but I must admit - a pretty well hidden setting
planet1 is offline
Old 15th May 2005, 12:34   #69  |  Link
Enrico Palmeri
Re: YAMB 1.2
[QUOTE]Originally posted by Kurtnoise13
[B]A new release available...
bugfixes:
- output file extension for muxing.
- some warnings weren't updated.
- import audio options partially debugged.
Add:
- mp4box stout redirected in log tab.
- extract A/V from AVI file.
- extract A/V in raw format.
- extract A/V in new mp4 file.
- Movie Info box to help you to find the right track for extracting.
- Subtitles Conversion.
- keep all MPEG-4 system info option.
- Edit manually the command line.
- Overwrite an existing output file option.
You have just added very interesting features. Do you have any plan to add the possibility to play the files in a viewer like Mplayer. for example, in order to seek the edit points, similar to virtualdub?
Regards
Enrico
Enrico Palmeri is offline
Old 15th May 2005, 16:27   #70  |  Link
Kurtnoise
Kurtnoise's Avatar
Re: Re: YAMB 1.2
Yes I have but not with MPlayer...But I need to test that on different PC because it crashes my WS. And I don't know why...
Old 15th May 2005, 19:02   #71  |  Link
Enrico Palmeri
Re: Re: Re: YAMB 1.2
Great!
We will see sooner or later
Old 16th May 2005, 13:19   #72  |  Link
bond
ok cleaned up the thread, lots of new threads created
guys, plz dont use this thread for discussions not directly related to the yamb tool!
Ogg Theora | Ogg Vorbis
bond is offline
Old 16th May 2005, 15:42   #73  |  Link
bond
Concerning different video input files : I tested with some samples. It works pretty well but only with mp4/3gp files. AVI, MPEG files doesn't seem to be supported. So, I don't think that I'll add this feature in the next version.
Kurtnoise13, this problem is now fixed in the latest mp4box version, meaning its now possible to mux multiple video streams (eg from .avi) into .mp4
will you add this possibility to your gui?
bond is offline
Old 16th May 2005, 15:44   #74  |  Link
Bluedan
Bluedan's Avatar
Don't have enough time for extensive testing, but it looks very promising.
v1.2.1 comes bundled with MP4box from 19-04-2005.
Latest binary on Celtic_Druids site is from 15-05-2005.
Has anyone tested this combination?
Jean LeFèvre has made a lot of changes...
I'm probably misconfused...
Bluedan is offline
Old 16th May 2005, 15:59   #75  |  Link
Kurtnoise
Kurtnoise's Avatar
yes...I'm improving the mux part to choose different A/V input files.
Old 16th May 2005, 16:03   #76  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
Latest MP4Box fixes the multiple audio streams bug too.
Sharktooth is offline
Old 16th May 2005, 16:05   #77  |  Link
SeeMoreDigital
I've just tried Celtic_Druid's new 15 May 2005 build of MP4Box.exe with YAMB 1.2.1.... and I can confirm muxing more than one AAC stream (I tried 6No) works perfectly now
Cheers
Old 16th May 2005, 16:08   #78  |  Link
bond
some points:
1) i cant set the options for the audio tracks anymore
2) would be great if the set options could be remembered (eg show commandline)
3) extraction of subs would be nice if possible in the extract tab:
5 = TrackID (sub)
indeed, you can extract subs from .mp4 with mp4box
of course when you extract to .srt you will loose all the funky animation and color stuff, which might be set in the ttxt stream
well it seems that with the -info switch mp4box can display the chapternames and times, so there is indeed a way to dump the chapter info from a mp4
the latest binary is available from today, 16.5
the only problems that could be caused are when the commandline switches are changed, but normally they dont change and also when jeanlf changes some of them he leaves the old ones in, so its backwards compatible
bond is offline
Old 16th May 2005, 17:09   #79  |  Link
Kurtnoise
Kurtnoise's Avatar
which audio format ?
for import options or other things ?
Done.
I don't think so, maybe I'm wrong...because it seems that chapters are not stored like text tracks or A/V streams. Check out the SMD example above, you can see that we have not the track ID concerning the chapters. Only the Name...
Old 16th May 2005, 17:14   #80  |  Link
bond
all
hm, more others, cause the import settings should maybe better always be set to the default i think!?
the chapters are not related to any trackid!
either you have chapters for the whole file or none
and mp4box can dump them nicely (names and times, what else do you need?), as smd's sample shows
bond is offline
