Old 1st September 2005, 10:13   #241  |  Link
Kurtnoise
Swallowed in the Sea
Kurtnoise's Avatar
Also, when started with multiple monitors side-by-side, it always starts in the middle of the two, ie, half on one and half on the other.
@foxyshadis & Koti : Could you test this build and tell me if it's ok. Thanks.
Kurtnoise is offline
Old 1st September 2005, 11:04   #242  |  Link
SeeMoreDigital
Life looks better in UHD
SeeMoreDigital's Avatar
The "Add" button does not work for me
Cheers
SeeMoreDigital is offline
Old 1st September 2005, 11:37   #243  |  Link
Kurtnoise
Kurtnoise's Avatar
I know...I disable some functions/buttons. I just want to know if the app appears in the right place. That's all...
btw, some new options work (in Extract/Options tab).
Old 1st September 2005, 12:25   #244  |  Link
SeeMoreDigital
Yes I noticed some of these... I like information provided in the "By Tracks" option: -
Great to see the PAR and bitrates listed... very useful. But is there any reason why the bitrate can't be displayed under the "Global" option too?
Cheers
Old 1st September 2005, 12:56   #245  |  Link
Kurtnoise
Kurtnoise's Avatar
Why ? because by default mp4box doesn't provide this info. You need to specify the trackID to have it. If you want to have it also in "Global", ask to Jean Lefeuvre to add this trick directly in -info command line.
Old 1st September 2005, 13:05   #246  |  Link
SeeMoreDigital
I see....
Do you know whether support for VOBsubs has been improved yet?
Just being able to add/remove AAC audio tracks and/or create chapters without YAMB/MP4Box.exe crashing would huge!
Cheers
Old 1st September 2005, 14:02   #247  |  Link
Kurtnoise
Kurtnoise's Avatar
mmmh I just checked the sources and I haven't seen some code about this format. Maybe I'm dumb...
Old 1st September 2005, 16:25   #248  |  Link
SeeMoreDigital
My comment was with respect to .MP4 files containing VOBsubs!
Currently, if you generate an .MP4 encode with VOBsubs using Nero Recode2, you are unable to add/remove AAC audio tracks and/or create chapters without YAMB/MP4Box.exe crashing....
Cheers
Old 2nd September 2005, 05:47   #249  |  Link
Koti
Always trying
Koti's Avatar
still opens in the middle for me - the view/edit cli box does stay on the primary moniter tho.
Koti is offline
Old 2nd September 2005, 07:55   #250  |  Link
Kurtnoise
Kurtnoise's Avatar
So...it's not a bug. Thanks for testing.
Old 5th September 2005, 13:08   #251  |  Link
Synergy37
Hey when I mux an AVC MP4 and SRT subtitles nothing appears when I play it back in Quicktime. Is this a SP MP4 only program?
Synergy37 is offline
Old 5th September 2005, 13:31   #252  |  Link
SeeMoreDigital
Try re-muxing your .MP4 to .MOV using QT7 Pro and playing it again!
Cheers
Old 5th September 2005, 14:08   #253  |  Link
Synergy37
Alright so I re muxed it to a mov file and then it just played a green screen. This wouldn't work for me anyway because I need it to be in AVC format for my psp. Isn't there just a simple answer why it's not woring, like I am missing a file?
Old 5th September 2005, 15:58   #254  |  Link
bond
quicktime only supports ttxt when being placed in .3gp. its nonsense, but thats the way qt handles it
Ogg Theora | Ogg Vorbis
bond is offline
Old 5th September 2005, 19:01   #255  |  Link
Kurtnoise
Kurtnoise's Avatar
Why would you like to use this player ? There are some others good players you know...
@Bond : I think that when we mux a srt file with mp4box into a mp4, this tool transforms the srt file in ttxt format.
Old 5th September 2005, 20:08   #256  |  Link
bond
indeed, did i say something different?
bond is offline
Old 5th September 2005, 22:29   #257  |  Link
Kurtnoise
Kurtnoise's Avatar
nope...but your answer speaks about 3gp whereas Synergy asks something for mp4. Anyway, it's not important.
Old 26th September 2005, 20:34   #258  |  Link
fight2win
What's in a name dude !
fight2win's Avatar
kurt, can u please give a link for latest build of yamb?
fight2win is offline
Old 26th September 2005, 20:39   #259  |  Link
SeeMoreDigital
Try looking at the very first page of this thread....
Old 27th September 2005, 10:25   #260  |  Link
fight2win
fight2win's Avatar
is there any new build after 1.3 alpha v1?
