18th April 2004, 23:33 | #81 | Link |
Lots of runtime error 13, mods seem to have got over these, am getting this also on LotR extended versions, fellowship and two towers.
Can someone post how they managed to fix this pls or what versions of other software you are using/changed to using? cheers ears |
19th April 2004, 07:58 | #82 | Link |
i have located and fixed most of the runtime errors. The one that happens when 'processing sst files', has been particulary difficult to fix and has resulted in a complete re-write of that function. When finished I will advise.
22nd April 2004, 18:08 | #85 | Link | |
Re: Error 13 under NuMenu4U
23rd April 2004, 04:17 | #87 | Link |
Call me lazy...
...but I really appreciated the old IfoUpdate-like integration into NuMenu4u. When I was done with Scenarist, being able to just click a few buttons in NM4U and have it automagically merge and update my files to create the finalized VIDEO_TS folder was nice.
Please bring that back! |
23rd April 2004, 13:07 | #89 | Link |
Germanicus
servus...
A couple of things: - is it possible to make more than one menu mit NuMenu4U? Sometimes, I wanna have german and englisch menus but I donīt want spanish - stop NuMenu4U; is it possible to stop all processes with one click? If you make an mistake and want to stop, NuMenu4U continues with dvddecrypter or CCE - small Menus. I just made K19 with DIF4U and Numenu4U. NuMenu4U opens correct, but after opening it want to close immediately (do you want to close; are you sure?... ) After pressing yes, it doesnīt remember that I have a (small 30mb) menu. So I have an movie with 4.37 GB plus x (the menu files), which isnīt writeable.
cya fourtyfour |
24th April 2004, 01:03 | #91 | Link |
Latest Build now available:
Bug Fixes: Correction to the GPRM figure (this was causing a mismatch error); Drop-frame is now correctly reported in the script; Compensation for 0.4s Scenarist error; Rewritten sst analysis routines - each cell is now analysed, so vsrip is now run multiple times; Fixed extra PGC's being created in the script; Additional check is now performed on the sst, a comparison is made to the original VOB, to check that there is no sst error; Correction on NTSC titles where the sub display was being set before the scene time - this gave a import crash when linking buttons; Removed one of the dummy detection routines - it was flawed; Aspect Ratio now correctly determined; Updated the ifoupdating routine for Video_TS.ifo Enhancements Assets in Scenarist are now imported into folders for better clarity; A large amount of data has been stripped from the script - better import speed; Alteration to conversion rule in scenarist - better clarity of button edges, and highlight contrast and colours now seem almost perfect; AC3 files now checked for corruption and fixed prior to import; Each bitmap is now analysed, and if no image is present (ie a full blue screen) then this sub is removed from the script; Setting a menu threshold value of 0 will now process every VOB (if it exists) - This is the start of format conversion routines Auxillary Files upgraded to latest versions. Small improvement to the GUI NB For the moment it is undetermined how good the new ac3enc.dll is.It is reported as being more compatible than the previous version, but nevertheless the option of AC3 re-encode has been removed. If the menu has PCM audio this will still be processed. Zeul |
24th April 2004, 11:19 | #93 | Link |
Germanicus
servus...
Number: 9 Description: Subscript out of range EXE Name: NuMenu4U EXE Path: C:\Programme\DVD\NuMenu4U EXE Version: Version 1.4.7 Call Stack (lowest level first) MainForm::NewProcessSST (line 75) Thatīs what I get with newest version an BadBoys 2 RC2 LogFile: 24.04.2004 12:18:20 Defaultsettings 24.04.2004 12:18:20 vts_tree_parent= K:\VIDEO_TS 24.04.2004 12:18:21 vts_tree_child_oversize= VIDEO_TS.VOB - 33MBchk1 24.04.2004 12:18:21 vts_tree_child_oversize= VTS_01_0.VOB - 471MBchk2 24.04.2004 12:18:21 vts_tree_child_undersize= VTS_02_0.VOB - 0MBchk3 24.04.2004 12:18:21 vts_tree_child_undersize= VTS_03_0.VOB - 0MBchk4 24.04.2004 12:18:21 vts_tree_child_undersize= VTS_04_0.VOB - 0MBchk5 24.04.2004 12:18:21 vts_tree_child_undersize= VTS_05_0.VOB - 0MBchk6 24.04.2004 12:18:21 vts_tree_child_undersize= VTS_06_0.VOB - 0MBchk7 24.04.2004 12:18:21 vts_tree_child_undersize= VTS_07_0.VOB - 0MBchk8 24.04.2004 12:18:21 vts_tree_child_undersize= VTS_08_0.VOB - 0MBchk9 24.04.2004 12:18:21 vts_tree_child_undersize= VTS_09_0.VOB - 0MBchk10 24.04.2004 12:18:21 vts_tree_child_undersize= VTS_10_0.VOB - 0MBchk11 24.04.2004 12:18:21 2 24.04.2004 12:18:21 avisynth= 2.5.4.0 Maybe it helps Regards Edit: Looks good on my other problem with stopping numenu4u on short menus. Great job man
cya fourtyfour Last edited by fourtyfour; 24th April 2004 at 11:50. |
24th April 2004, 14:00 | #94 | Link |
Tried reencoding the menu of Resident Evil Pal region 2.
I'm getting this error when "processing SST Files & Analyzing bitmapes" Number: 9 Description: Subscript out of range EXE Name: NuMenu4U EXE Path: C:\Program Files\NuMenu4U_newesttt EXE Version: Version 1.4.7 Call Stack (lowest level first) MainForm::NewProcessSST (line 75) I could send you all the "stuff" if you want? (ifofiles, logfiles and so on..) |
24th April 2004, 14:14 | #95 | Link | |
Retired
24th April 2004, 20:39 | #97 | Link |
Germanicus
servus...
What I found in D_Video_TS\SUBTITLES Hope this is what you want. 005_01_-1.sst 005_01_-2.sst 005_01_Normal-0.sst 005_01_Normal-0_0001.bmp 005_01-Normal-0_0002.bmp 006_01.sst 006_01_-1.sst 006_01_-2.sst 006_01_Normal-0.sst 006_01_Normal-0_0001.bmp 006_01_Normal-0_0002.bmp v5_c1.ifx v5_c1.sub v6_c1.idx v6_c1.sub I also got an error while using NuMenu4U via DIF4U. But it only happend once. If I should get this error again, Iīll let you know.
cya fourtyfour |
25th April 2004, 00:45 | #99 | Link |
Wewkiee
Well.. im happy to report. Matrix 1 (R1) now process without error and loads into scenarist 3.0 perfect and compiled (2.6 wouldnt import the script, although afaik numenu is being developed on 3.0)
...yeah...but...why on earth would I compare apples with apples? |
