6th April 2007, 12:31 | #21 | Link |
This will help in concluding if the patched firmware is safe:
- desolder the falsh - read it with external programmer, compare with original MC08 firmware - solder it back - flash by software the patched firmware i can provide - desolder the flash -read it again and compare with the original dump to see if any other region changes except the few bytes patched. Consider that i can do it myself as soon as i've time, probably tomorrow. From the assembler side, an help could be in finding a vendor specific CDB that can dump firmware by software. On xboxhacker thread there are info about the CDB table with relative function address. btw, here is the original SD-S802A MC08 firmware with part 3, 6 and 7 blanked, like the buffalo SD-H802A fw upgrade. http://www.sendspace.com/file/sleyls don't flash this (atm), but use only for dissassembling or comparing with your own flash dump. Last edited by Geremia; 6th April 2007 at 13:02. |
6th April 2007, 13:11 | #22 | Link |
Just a little update: I'm currently analyzing the checksum functions etc and I'm making progress.
Things I've figured out:
This whole checksum algo starts to make more and more sense to me now. I'm not there yet but its promising. arnezami Last edited by arnezami; 6th April 2007 at 13:31. |
6th April 2007, 13:58 | #23 | Link |
hehhe, i got lost there with all that clearing of column xors.
ROM:002F0AC4 ldi:8 #0xCF, r9 ROM:002F0AC6 extsb r9 ROM:002F0AC8 add r14, r9 ; r9 = (r14, 0xCF) ROM:002F0ACA ldi:8 #0, r4 ROM:002F0ACC mov r9, r5 ROM:002F0ACE ldi:32 #CP_r4_to_@r5_till_r5plus_r6minus1, r12 ROM:002F0AD4 call:D @r12 ; clears from (r14, 0xCF) to (r14, 0xDE) ROM:002F0AD4 ; column1 xors are at DC, is partially cleared, remain last byte ...... ....... ROM:002F01C8 ldi:8 #0xD4, r0 ROM:002F01CA extsb r0 ROM:002F01CC add r14, r0 ; r0 = (r14, 0xD4) ROM:002F01CE st r0, @(r14, 0xFC) ROM:002F01D0 mov r9, r4 ROM:002F01D2 ld @(r14, 0xFC), r5 ROM:002F01D4 call:D CP_@r4_to_@r5_r6len ; copy the cleared area (r14, 0xCF) to (r14, 0xD4), 0x10len ROM:002F01D4 ; column xors area was from DC to EB, now cleared till E3 ?!?! I'm sure that arnezami will figure it out clearly |
6th April 2007, 14:07 | #25 | Link | ||
Maybe the best and easiest way to do this is change this: Code:
002F0DB0 MOV R7,R4 Code:
002F0DB0 LDI:8 #$00,R4 This function is used both at booting and before flashing (correct?) so there will be no discrepancies (like being able to flash but not being able to boot anymore). Does this make sense? Regards, arnezami PS. Quote:
6th April 2007, 16:27 | #27 | Link | ||
You don't need to byteswap this particular firmware file before you disassemble it. In the thread on xboxhacker, I give link to source code of FR disassembler. It's not as nice as IDA Pro (primarily no automatic commenting and function tracing), however it works and it is free. Code:
hostname:~/src/firmware/SD-S802A/tmp$ ./disfr Binary file to disassemble : SD-S802A-MC08_nokey.bin Offset : 0x00200000 TBR register value [FFC00]: Swap bytes order (y/N) ? N Done. hostname:~/src/firmware/SD-S802A/tmp$ less SD-S802A-MC08_nokey.bin.txt Code:
[...] 002F0AC2 A444 ADD #$04,R4 002F0AC4 CCF9 LDI:8 #$CF,R9 002F0AC6 9789 EXTSB R9 002F0AC8 A6E9 ADD R14,R9 002F0ACA C004 LDI:8 #$00,R4 002F0ACC 8B95 MOV R9,R5 002F0ACE 9F8C 002F 0198 LDI:32 #$002F0198,R12 002F0AD4 9F1C CALL:D @R12 002F0AD6 C106 LDI:8 #$10,R6 002F0AD8 CBFA LDI:8 #$BF,R10 002F0ADA 978A EXTSB R10 [...] Quote:
6th April 2007, 16:41 | #28 | Link | |
Coder
disfr isn't work on my xp. ("The system cannot execute the specified program.") IDA pro work, but the file (SD-H802A.bin) has wrong byte order. Last edited by Pelican9; 6th April 2007 at 16:54. |
6th April 2007, 17:11 | #29 | Link |
I slapped together a quick byteswapper for that purpose earlier in that thread. Link to source code
Someone else built distfr for Windows in this post. Maybe that will work for you. It's probably obvious by now that I don't have a readily available Windows system to build on (And probably won't have until I figure out how to install Parallels on AppleTV, but that's a subject of a different post in a different forum). If it helps at all, I believe that any of the things that I write in C are compilable under Windows using either cygwin or mingw, if not using the more mainstream development tools. |
6th April 2007, 17:45 | #30 | Link | |
Coder
I've just written a swapper too. :-) That windows build was which didn't work. |
6th April 2007, 19:20 | #31 | Link | |
At booting, only fwpart 1,2 and 4 will pass trought this function, while at flashing only part 1, 2, 4 and 5. About dissassembling, the fw is byteswapped only in the flashrom if you read with external programmer. If you got fw from my link or from the buffato SD-H802A, it does not need byteswapping, it's ok like this, and it's how the CPU sees it. The CPU works in bigendian scheme, and the flash is mapped at address 0x200000. I'm using IDApro set to FR 32bit family, CPU FR65E but it should be the same if you set FR50 or FR30. Just make sure to load the bin in ROM at address 0x200000 |
6th April 2007, 19:27 | #32 | Link | |
Right? arnezami |
6th April 2007, 20:26 | #33 | Link |
Yes, i was too curious and i've tried already (my girlfriend can wait )
modified the bootloader on an original fw, xors and sums compensated, flashed without errors. then made a fw with this patched bootloader and a patched mainFW where only xors were correct, sum was wrong. Flashed, got error. Ths was weird, so i made an original fw with a modified bootloader which had sum and xor not correct, to see if it give error. Surprise, no flashing errors, this means that the bootloader is not checked and not flashed !?!?! This is why my first bootloader patch of some days ago didn't work...the patch was probably correct, the problem is that the bootloader is not flashed i've to take a look at the 3B 05 writebuffer comand, maybe the bootloader has another way to be flashed. |
7th April 2007, 11:13 | #34 | Link |
By being able to modify the firmware, is it now possible to do backups from a genuine HD-DVD to a HD-DVD-Recordable without the need to find any of the private/proseccing keys from the software application?
I mean a hack like the original xbox360 hack. Read all the "unreadable" portions of the disc and write them at specific section of the recorable disk. Then direct the drive to read those specific bytes and make "software player" think that everything is like a normal situation. |
7th April 2007, 11:33 | #35 | Link | |
What would be needed is to let the drive detect that is has a recordable inside. If so the Volume ID retrieval command should get its Volume ID from a different place (a place on the recordable we assigned ourselves to let the Volume ID be stored). In addition we would have to make sure the software player sees the recordable as a prerecorded disc (there may be checks to see this). But looking at Geremia's last post we can't overwrite the bootloader itself so there is still quite a lot of work to do in order to do these kinds of complex changes to the drive. Not being able to overwrite the bootloader also limits our ability to "stealthen" the patched fw. But if it all works it would mean that an (encrypted) recordable movie would work on all software players and would even play on the xbox 360 itself. I'm not sure if its possible now (or if it will stay possible in the future) to play unecrypted movies on the xbox 360. But if not this would be the solution to that too. All without knowing any of the AACS Keys (Device/Processing/Media/Vuk/Host Private keys etc.) . Thats pretty spectacular... In essence this is a kind of "bit-by-bit copy" attack (with only a slightly difference to the orginal disc) This would be a cool project . If some people stick their heads together (possibly at xboxhacker since xbox 360 owners would greatly benefit from this and they have already done this with the dvd player) this could be done in reasonable time I think. But this does not allow you to do anything with the video/audio on the disc (like demux/recompress whatever). Its just for backup and playback. Does that answer your question? Regards, arnezami Btw: I think I now know enough to recalculate the 16 byte checksum values . More on that later... [edit] Hmmmm. Maybe not . Looks like I really need to go into the Hash function (or identify it). Damn it. Last edited by arnezami; 7th April 2007 at 13:10. |
7th April 2007, 12:17 | #36 | Link | |
I mean; M$ could benefit from such feature when your fw patch is released =) When you connect a hacked XBox to XBoxLive, it gets revoked. Isn't that done in the firmware? |
7th April 2007, 13:56 | #38 | Link |
This seems to be way the 16 byte checksum is calculated for each fw part (if I didn't make any mistakes ):
The "Rand 16 bytes" are the ones right after the ToshSams string (in the current fw). The "XOR columns" is the endresult of XOR-ing the columns of an fw part without the SUM correction value (the first 4 bytes of the fw part) and without the (proposed) checksum values themselves (the last 16 bytes of the fw part). The output should be the same as the 16 bytes at the end of the fw part. If not the flashing will fail. Still trying to figure out what hash/one-way function is used and how it is used. Regards, arnezami Last edited by arnezami; 7th April 2007 at 14:16. |
7th April 2007, 16:01 | #40 | Link | |
In addition I can think of a couple other commercially pressed HD-DVD disks that were reported to not utilize AACS: "Running Scared" in Germany, and "Nature's Colors". To the best of my knowledge, these titles are currently playable by Xbox 360 with an HD-DVD add-on. |
