Old 18th August 2019, 09:31   #21  |  Link
real.finder
Originally Posted by Taurus View Post
Your zippyshare link gives a "403 forbidden..."
Thanks for fixing this!
mediafire link https://www.mediafire.com/file/v0kk4...0/vhs.mp4/file
See My Avisynth Stuff
Old 18th August 2019, 10:43   #22  |  Link
Taurus
Taurus's Avatar
Originally Posted by real.finder View Post
Thank you
Taurus is offline   Reply With Quote
Old 18th August 2019, 17:34   #23  |  Link
szabi
Originally Posted by FranceBB View Post
That's only because I had to output an XDCAM since I was at work, which is why I upscaled it.
Cheers,
Frank
Hi
I did not know as much about resizing.
I use "LanczosResize" since 15 years, "Bilinear" was used before.
Additionally "Spline64Resize" was a new one for me.
Concerning the TV upscale mine in on halfway because it was release in 2013.
Many thanks for the detailed information.
Originally Posted by Emulgator View Post
Hi szabi !
Got the details of the portal back.
1280x720x50fps, MPEG-4 AVC + AAC.mkv, as preview.
https://www.sendspace.com/file/kekbk3
As h.264 +.ac3 muxed into .MTS would be ready for use on AVCHD / .m2ts on BD.
May I kindly ask to post your script?
I give it a fast try
LWLibavVideoSource("D:\Downloads\tdk vhsc-sample.avi")
QTGMC(tv_range=false)
edgesidebleed(0,0,0.01,0.1,-0.01,false).edgesidebleed(0,0,0.01,0.2,0.01)
YAHR3(depthV=0,lumaonly=true)
DeHalo_alpha(rx=2.0, ry=1)
last.sBlackerPixel(DeHalo_alpha_2BD(rx=3.0, ry=1),64)
AutoAdjust(input_tv=false,output_tv=false).SmoothLevels(preset="pc2tv")
#~ Prefetch(threads=8) #slower!
https://www34.zippyshare.com/v/iR6ho2Sz/file.html
not perfect but it's good start so you can play with filters parameters or add another filters
May I ask why "LWLibavVideoSource" are used instead of simple "Avisource"?
I do not find info on "edgesidebleed" and "sBlackerPixel" What are they doing?
I found this on YAHR3: Y'et A'nother H'alo R'educing script
Others are documented on wiki.
Can you help me with that two?
Thanks for the sample, both of you.
regards
szabi
szabi is offline   Reply With Quote
Old 18th August 2019, 21:09   #24  |  Link
real.finder
Originally Posted by szabi View Post
Hi
regards
szabi
LWLibavVideoSource cuz Avisource said that I don't has the decoder for the video
"edgesidebleed" in Advanced Denoising.avsi, sBlackerPixel in DDComb.avsi (see my signature)
edgesidebleed = edge side bleed fix
sBlackerPixel is helper function for Dark Pixels Preserve/Protect since dehalo filter can kill these Pixels
Old 20th August 2019, 13:15   #25  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
va=DirectShowSource("E:\_VID\Szabi\tdk vhsc-sample.avi")#.AssumeFieldBased().AssumeBFF() LWLibavSource made framedrops on CDVC ! Lavfilters worked !
aa=DirectShowSource("E:\_VID\Szabi\tdk vhsc-sample.avi")
AudioDub(va,aa)
ConvertAudioTo16bit()
SmoothCurve(HQ=true, interp=100, limiter=false, debug=false, screenW=1280, screenH=768, \
Ycurve="0-15;20-22;80-80;127-127;180-170;245-218;255-235", \
Ucurve="0-16;100-100;127-127;140-145;255-240", \
Vcurve="0-16;100-100;127-127;140-145;255-240")
#ChromaShiftSP(x=-2.0,y=1.0) #you choose what you prefer, I stopped here)
SetMTMode(2)
TempGaussMC_beta2(EdiMode="NNEDI3", tr2=3, sharpness=1.8)
SetMTMode(5)
Stab(range=1, dxmax=4, dymax=4)
#DeHalo: you choose what you prefer, I stopped here)
MedSharp2(str=2)
Lanczos4Resize(960, 720, 10, 4, -10, -6).AddBorders(160, 0, 160, 0, color=$000000)
Old 21st August 2019, 14:28   #26  |  Link
szabi
Hi
You are right it was told already, pardon.
Do you plan to add these to the external filters on wiki?
Emulgator
Thanks for the script.
May I ask why "TempGaussMC_beta2" is used instead qtgmc?
"DeHalo" and "MedSharp2" not listed on wiki but there are similar.
However I do not find what "SmoothCurve" and Y-U-Vcurve doing?
Regards
szabi
Old 21st August 2019, 19:34   #27  |  Link
Emulgator
Emulgator's Avatar
After trying some versions of QTGMC I had better results, less artifacts with TGMC_beta2 in my VHS projects.
You got to find the DeHalo algo that suits you best, there are many of them, I wasn't going to tailor all I know of.
MedSharp2 you will love as nice sharpener though.
Y is getting your blown-out hilight details back, U and V are tweaking some of the poor U and V values back in.
If chroma suits you ? You got to decide. I don't know how the jackets of the gents looked back then,
it was just my guesswork from gazing at the histogram and wanting some U and V over 127 back in.
A Viszontlátásra !
Old 31st August 2019, 14:32   #28  |  Link
szabi
Hi
Many thanks for information.
Regards,
üdv
avisynth, repair, restore, restoring, vhs
