17th April 2012, 10:03 | #7421 | Link | |
Broadcast streams are encrypted
Any idea how I am able to detect what multiAVCHD (or better AVSinfo.exe) "donīt like" in these streams? realcams |
17th April 2012, 11:19 | #7422 | Link |
AVSinfo
It's been a long time since I last used multiAVCHD so I can't be of much help (I too wish Dean would start working on it again).
AVSinfo.exe is not really needed. It can be deleted or renamed to something else (I chose BVSinfo.exe). AVSinfo.exe is located in the "tools" folder of multiAVCHD. |
17th April 2012, 23:59 | #7423 | Link |
Thank you BZ. I renamed the AVSinfo, but then x264 and avs4x264 was crashing. But then I downloaded a copy of FFMS2, and moved the exe and the updated dll file into the tools directory, and x264 no longer crashes when I go to preview. It will also encode now. I had no luck without FFMS2 and your idea to rename AVSinfo. Thank you!
18th April 2012, 07:53 | #7424 | Link | |
FFMS2 and x264
Hi RanmaCanada,
thanks for that idea. What in detail did you update from FFMS2? Made same and updated the three files contained - FFMS2.avsi - ffms2.dll - ffmsindex.exe to the \tools folder. But no change, x264 is still crashing. Many thanks and kindest regards realcams (Germany) Quote:
23rd April 2012, 12:53 | #7425 | Link |
I searched this thread for this answer, but could not find it. Can I use multiAVCHD to add an audio track to an already authored BDMV but not touch the existing menus? If not, what tool can I use to do this or what other tools do I need to use with multiAVCHD to do this?
24th April 2012, 19:39 | #7426 | Link |
audio gain
I'm having trouble with audio gain on a 6 channel AC3 file.
(it's a 720p .ts file) I add the gain in db's within properties and click 'change' to save the setting but the authored files are not any louder.. I've tried selecting//de-selecting 'eac3to' Anybody know what I'm missing? Thanks |
25th April 2012, 00:57 | #7427 | Link |
On another project I'm trying to combine HD & DVD content into one BD disc.
The authored output is fine except the title thumbnail for the dvd file is blank on the menu screen. Anybody know how to fix it? Is there a setting I'm missing? Thanks. here's what the log said: [17:11:52] Creating title thumbnails for 1 titles (SLI)... [17:11:55] Using user defined title image at 600 sec (00:10:00.000) for title #1! [17:13:00] Failed to extract title thumbnail for title #1. Last edited by nikknightt; 25th April 2012 at 01:18. |
25th April 2012, 17:09 | #7428 | Link |
Wow can't wait to try this out tonight, any ETA doing a 1:1 copy when compressing from about 40GB to 25GB? I've been told to save the 50GB to HDD first then compress correct? Cuz I did it before and it took 30hrs. using DVDFab lol
EDIT: Well looks like I'm never gonna find out cuz tsMuxer stops working and is crashing multiAVCHD, do I need tsMuxer? Can I remove it? Last edited by laz305; 26th April 2012 at 11:37. |
27th April 2012, 16:31 | #7429 | Link | |
But essentially, to change the audio tracks without altering the menus, most of the options in multiAVCHD don't apply or do anything at all. All you have to do is throw your BDMV folder on the program, switch to "re-author mode", look at the audio streams for the title you are interested in, remove/add what you want, and push START. Pretty fast too. (end of worst user's guide to multiAVCHD) |
28th April 2012, 21:56 | #7431 | Link |
ok I'm totally lost, I am trying to do Bridesmaids and when it loads there are 168 compilations and says it's gonna be 30hrs. long and 200GB. Are you saying I have to sit there for hours and blank out over 140 compilations?
29th April 2012, 00:28 | #7432 | Link | |
You should be using BD-RB, it will allow you to blank titles and audio that you don't want and will do full backups to BD-25, BD9 and BD5. http://forum.doom9.org/showthread.php?t=143716 |
29th April 2012, 00:53 | #7433 | Link |
Omg Ty so much am trying it out now. Will post back tomorrow with my results. Yeah 3-4hrs. I can deal with but DVDFab has been taking 20-30hrs.
EDIT: Woke up and it failed with an error after 13GB Last edited by laz305; 29th April 2012 at 14:49. |
30th April 2012, 21:29 | #7434 | Link |
Well this is strange. I was using multiavchd just fine a month ago, but now suddenly when I go to start the app it fails to start properly. The loading screen comes up, but then I get this weird calculator/spreadsheet icon on my task bar and nothing else. I mouse over the icon and it says "multiavchd v4.1 (build 770)". When I click on the icon nothing happens. There is no visible window on my desktop. I tried uninstalling and reinstalling. Nothing changed. I am running Windows 7 (64bit).
Anyone have any thoughts what might be causing this? Other than some windows updates, I can't think of anything that has changed since I last used the program without incident. |
1st May 2012, 21:32 | #7437 | Link |
Ok I am trying to turn my Tranformers 3 into an .mkv file and when I select either MKV (Xvid) or MKV (AVC) it creates an AVCHD folder. What am I doing wrong plz? Dam I knew it was too good to be true, I thought it was too easy lol
1st May 2012, 22:22 | #7438 | Link | |
NY Frame of Mind
"Talk to me Goose" |
2nd May 2012, 14:25 | #7439 | Link | |
4th May 2012, 11:34 | #7440 | Link |
Suspended for forum rule violations
Change font type for menu in MultiAVCHD?
Is there a way to change the default menu font type listed in MultiAVCHD?
Trying to use a different, not listed, font but it doesn't show up. Any workaround? Regards |
