Old 7th November 2008, 14:36   #1621  |  Link
Lucky you. I figured out a quick fix that seems to work OK for these streams. I'll release it ASAP.
Guest is offline
Old 7th November 2008, 15:20   #1622  |  Link
Version 1.0.6
* Added support for all POC order count types.
* Made a hack for transport streams which have PES headers split across transport packets.
http://neuron2.net/dgavcdec/dgavcdec.html
Guest is offline
Old 7th November 2008, 17:03   #1623  |  Link
Snowknight26
Topic title still states 1.0.4.
Snowknight26 is offline
Old 7th November 2008, 18:32   #1624  |  Link
lchiu7
It just depends on how much stuffing they add.
Since the files are not pristine rips from HD-DVD or BR but in fact from UHF transmissions, could this be from dropouts in the transmission stream? Watching these streams I can occasionally see video glitches which must be present in the video stream since I always watch captured streams, not the live ones.
lchiu7 is offline
Old 7th November 2008, 18:55   #1625  |  Link
No, there are no errors at the time the silliness occurs.
Guest is offline
Old 8th November 2008, 04:55   #1626  |  Link
lchiu7
Out of interest when this silliness occurs, does it impact the demuxing of the audio versus handling the video frames. I ask because how hard would it be to have an option that tells the program when such errors occur to continue demuxing the audio while not guaranteeing the quality of the data in the dga file.
Slightly selfish but my main purpose of the program is to demux the audio - I don't normally load the dga file into Virtualdub or avisynth since something like MeGui is okay with handling the file with DirectShow
Thanks
lchiu7 is offline
Old 8th November 2008, 05:12   #1627  |  Link
A split PES header is not an error. It is a legal construct. I wan't handling it properly. It is fixed. Your audio should be fine.
Are you saying that you still have a problem?
Guest is offline
Old 8th November 2008, 06:03   #1628  |  Link
lchiu7
No - timing error in the responses. I hadn't seen you had released 1.06. Downloaded it and it went through the entire video file (the one with the extract I uploaded) with no errors. Winamp was able to play the aac file fine and output the wav file I need.
Thanks a bunch for that - really appreciated.
lchiu7 is offline
Old 8th November 2008, 13:14   #1629  |  Link
Ah, good. Thanks for pointing out the problem and for your other useful contributions.
Guest is offline
Old 27th November 2008, 20:54   #1630  |  Link
kebulek
kebulek's Avatar
neuron2: I just had a 1-2s glitch in my HD stream and DGAVCIndex 1.0.6 did it unwatchable for 12 seconds (still image with many blocks). :-( Is this DGAVCIndex's fault or just bad stream?
Sample with glitch (10MB):
http://rapidshare.com/files/168005722/hd-sample.ts.html
It's .PVA demuxed by Mencoder, and then muxed to .TS by TSMuxeR.
Note to everyone - please do not download this file before Neuron2, because rapidshare said "Your file has been saved and can now be downloaded only 10 times." :-( Thank you.
kebulek is offline
Old 28th November 2008, 07:32   #1631  |  Link
new_age
SW & FW developer/modder
new_age's Avatar
Any idea what can I do to properly decode h264 stream when I get this error message
Sure. Get a recent Nvidia card and use DGAVCDecNV, which plays it flawlessly. Looks like a libavcodec issue.
Oops, I edited your post instead of replying. Sorry.
new_age is offline
Old 28th November 2008, 09:29   #1632  |  Link
Comatose
new_age: when posting about a problem like this, you should include a sample...
Comatose is offline
Old 28th November 2008, 10:04   #1633  |  Link
new_age
new_age's Avatar
You're right. Then I need some help. How can I cut from the h264 file properly?
new_age is offline
Old 28th November 2008, 10:23   #1634  |  Link
Comatose
I guess if DGAVCIndex doesn't work, then you can mux to ts and use h264ts_cutter or mux to mp4 and use Avidemux.
Comatose is offline
Old 28th November 2008, 10:53   #1635  |  Link
new_age
new_age's Avatar
I've put the sample here:
http://rapidshare.com/files/16817012...2_err.zip.html
Please do not download except Neuron2 because it can be download only 10 times.
new_age is offline
Old 28th November 2008, 11:15   #1636  |  Link
bob0r
Pain and suffering
bob0r's Avatar
unzipped:
http://files.x264.nl/00002_err.264
bob0r is offline
Old 28th November 2008, 11:29   #1637  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
So why do you use rapidshare??????? I can't understand why people are so addicted to rapidshare?????
Atak_Snajpera is offline
Old 28th November 2008, 11:54   #1638  |  Link
new_age
new_age's Avatar
off/flame:
Because I don't know any other filesharing site!!!!!!! Do you understand that?????
new_age is offline
Old 28th November 2008, 12:18   #1639  |  Link
kebulek
kebulek's Avatar
OK here is the same sample:
http://uloz.to/996704/hd-sample.ts
It's Czech filesharing server, so copy those four red digits a click on the green button "--> Stáhnout soubor <--".
I hope it will work... And if there is a better filesharing, let me know - thanks.
kebulek is offline
Old 28th November 2008, 12:18   #1640  |  Link
Atak_Snajpera
have you ever heard about Google? (rhetoric question)
END OFFTOPPIC !!!
