19th June 2008, 08:51 | #3801 | Link | |
ffdshow/AviSynth wrangler
And since you have to decode it at full resolution scaling it down afterwards only increases CPU load - and you can already do that using ffdshow's Resize & Aspect filter, anyway.
now playing: [artist] - [track] ([album]) |
19th June 2008, 11:00 | #3802 | Link | |
Distortion is indeed a side effect, but it does improve decoding speed. The mplayer man page for instance, and google, have explanations about the lowres decoding option found in lavc. |
19th June 2008, 14:18 | #3803 | Link |
Errr... so you're implying that David Huffman is to Variable Length Coding as Reimar is to MPEG2? (Sorry, I really genuinely don't understand that comment of yours...)
19th June 2008, 14:32 | #3804 | Link | |
Software Developer
You don't need to explain how MPEG-2 decoding works to Reimar, because as an MPlayer/Codec developer he should be very familiar with it...
19th June 2008, 15:08 | #3805 | Link | |
Thanks for clearing that up...
20th June 2008, 03:06 | #3806 | Link | |
What he asked for is controlled by AVCodecContext.lowres, which certainly works for MPEG2. I think it might already be exposed in the UI too. |
20th June 2008, 11:09 | #3807 | Link |
Posts: n/a
Hi all,
There's a bug in ffdshow (reported at http://sourceforge.net/tracker/index...41&atid=867360 ) that makes some of the software I'm running unusable. I was just wondering if this bug was fixed in any of the nightly builds? If not, is it something that might be fixed in the future? Thanks. |
20th June 2008, 21:20 | #3811 | Link |
Broadband Junkie
It works here as well. Use "Specify horizontal and vertical size" > only change the vertical size > make sure Aspect ratio is set to "no aspect ratio correction".
I'm assuming you're using YV12 and YUY2 with VMR/EVR? With those color spaces VMR/EVR will sometimes use odd internal resolutions (which seems to be a built-in restriction) yet it will still display at your desired resolution. Last edited by cyberbeing; 20th June 2008 at 21:23. |
20th June 2008, 21:21 | #3812 | Link |
Maybe those are anamorphic encodes? Check your PAR settings. Because it should work.
MPC-HC 2.2.1 |
20th June 2008, 22:37 | #3814 | Link |
At the end of the month if no regressions are reported.
MPC-HC 2.2.1 |
20th June 2008, 23:51 | #3815 | Link |
Software Developer
Apparently the "Cubic Blending" deinterlacer doesn't deinterlace at all or it fails horrible to remove combing artifacts (which I think isn't possible with that method)
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 21st June 2008 at 00:09. |
21st June 2008, 05:19 | #3816 | Link |
Guys, is it possible to make "custom" OSD display as list?
if the video resolution is small, OSD will got truncated if display all in one line like this i hope this feature request isn't too hard for devs Last edited by Yong; 21st June 2008 at 05:21. Reason: typ0 |
21st June 2008, 09:26 | #3818 | Link | |
So my question was about the part I did not know: why it would not be possible to export this functionality via ffdshow (seems I was mistaken to assume you knew about this libavcodec feature). |
21st June 2008, 10:42 | #3819 | Link | |
Kid for Today
the "cubic blending" doesn't do anything whatsoever, and the "linear blending" is very blurry. the best deinterlace I've found so far is the PS "blending" script in MPC...but it only works w/ EVR or VMR9 Seb.26 told me that it's using a very simple script, but because noone is willing to add new features to ffdshow......it's not gonna happen anytime soon. ffdshow is so great, but it's got a few annoying bugs that noone will ever fix I guess for instance....when using Avisynth scripts, very often Reclock says "no video stream found", I stop/press play again, and it's fine... Last edited by leeperry; 21st June 2008 at 10:52. |
21st June 2008, 11:02 | #3820 | Link | |
I assume that those deinterlacing problems exist for a long time already, and they are no recent regressions. So they won't hold back a beta. But anyway, I am no C++ programmer, and I don't really care about deinterlacing functionality.
MPC-HC 2.2.1 |
