10th April 2009, 09:50 | #8741 | Link |
sidekick
It's probably not the best place to ask, but what am I supposed to do with 23,975 mkvs? I think they don't play stutterfree on Popcorn Hour and what I'm doing righ now is to demux all streams and mux it new with mkvmerge while changing fps in the container to 24000/1001 --> no judder on PCH. I guess changeto23.976 would lead to the same effect.
But what about the audio? is the difference neglectable? or should I use changeto23,976 to the audiostreams? is there a quality loss when changing fps to the DTS stream? Edit: I did some math: 2h movie = 7200s 0,001 frames difference for 1s --> 7,2 frames in total. 1s ---- 23,976 frames xs ---- 7,2 frames x = 0,300s = 300 ms hm, 300 ms is quite a bit. Should be noticed at the end, I think 25-50 ms is noticable... I looked into some remuxed videos and didn't see such difference at the end of the movies.... Am I missing something? maybe mkvmerge did changing the fps for both, video and audio? (which would be great btw)
greets, kurt. Pioneer PDP-427 XA | Popcorn Hour NMT C-200 | Sony STR-DB 840 QS | Canton Ergo 91 DC Last edited by kurt; 10th April 2009 at 12:28. |
10th April 2009, 10:21 | #8742 | Link | |
Remember we are talking about the same source encoded with ac3 (supposed well encoded) and dts (Surcode). Better bass and rear separation? The bass never is a problem for a encoder. The rear separation must be in the source.
10th April 2009, 19:50 | #8743 | Link |
Nero Audio Decoder Link Broken
When I test eac3to, the message regarding Nero Audio Decoder says:
"Nero Audio Decoder (Nero 7) is not working correctly http://www.nero.com/eng/store-blu-ray.html" When I try to access the link http://www.nero.com/eng/store-blu-ray.html, the page that comes up says nothing about the Nero Audio Decoder. Can someone tell me the correct path to find the Nero Audio Decoder eac3to wants? Thanks, Tom |
11th April 2009, 07:06 | #8745 | Link |
A dts file created from surcode will most definitely sound better than a core ac3 file if the source is the same. Such as a lossless audio track, like true hd. Remember, there is no magic way the studios have to encode an ac3 file. The same could be said of dts. Surcode outputs the same dts file as a studio would(if not very, very, close)
11th April 2009, 12:09 | #8746 | Link |
HDConvertToX author
@madshi
since eac3to (ffmpeg) is unable to decode correctly aac SBR and so want use nero decoder, would be possible to add support for Monogram AAC decoder (from radlight) ? it's free/gpl so, when aac sbr is to decode, check nero, else monogram, else ffmpeg thanks BHH
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 |
11th April 2009, 13:04 | #8747 | Link |
Hey Now!
@madshi
I am having issues with w64 madshi. same as tabasuna51 is. also when I use a w64 in tsmuxer it will give a error after a minute or so. Roman tried a large w64 that he created then used tsmuxer and it works fine for him. He suggested it may be a header error. This only happens using DTS-ma converted to W64. true-hd to W64 does not give a error but the w64 file seems small. link http://forum.doom9.org/showthread.ph...78#post1272478 Last edited by jamos; 13th April 2009 at 00:55. |
11th April 2009, 13:10 | #8748 | Link | |
Hey Now!
13th April 2009, 00:53 | #8749 | Link |
Hey Now!
Is it correct to have a w64 file be less size than the original true-hd file?
thats what I am getting when I convert a true-hd file to w64 using eac3to. When I convert the true-hd file to pcm it is 7 gig. compared to the original 2 gig. true-hd file (which seems correct). |
13th April 2009, 19:49 | #8750 | Link |
Mh, Strange.
eac3to gives Warnings on a lot of 23.976Fps 1080p x264 MKV/M2TS M2TS, 1 video track, 2 audio tracks, 1:27:08, 24p /1.001 1: h264/AVC, 1920x800 23.976p (12:5) 2: DTS Hi-Res, German, 5.1 channels, 24 bits, 3018kbps, 48khz (core: DTS, 5.1 channels, 24 bits, 1509kbps, 48khz) 3: DTS, English, 5.1 channels, 24 bits, 755kbps, 48khz [v01] The video bitstream is encoded in a non-standard framerate. <WARNING> But the Video is surely encoded in 23.976FPs (trough AVS with DGIndex/Decode). All other Tools/Palyser shows me correct 23.976Fps. Whats wrong there? |
13th April 2009, 19:59 | #8751 | Link | |
Posts: n/a
13th April 2009, 20:03 | #8752 | Link |
ah ok thank you
But some x264 Files with 23.976fps are working without Warnings but other Files not ? Found this Post by Madshi http://forum.doom9.org/showpost.php?...postcount=8111 |
13th April 2009, 21:17 | #8753 | Link | |
BluRay Maniac
14th April 2009, 01:42 | #8754 | Link |
hi madshi, just to report...
"Bitstream parsing for track 3 failed" msg reported when running eac3to (3.15) on an mkvtoolnix/mkvmerge(2.6.0)-created .mkv file for a muxed VobSub track (3) created with BDSup2Sub 3.1.0 (i.e. idx/sub file pair source) (other/first 2 tracks are h.264 720p video and DTS audio) .mkv file plays just fine with ZoomPlayer using VSFilter Last edited by magic144; 14th April 2009 at 06:13. |
14th April 2009, 23:03 | #8757 | Link | |
In all the phase 1 codecs, DTS 1.5 Mbps outperformed every other codec. It outperformed DD 448kbps by a pretty substantial margin, and also outperformed (barely) DD+ 448 kbps. Unfortunately, DD 640kbps was not tested. However, from some trends that you can identify throughout that data, DD640 should be very close to DTS 1.5M, maybe exceeds it, maybe not. All performance measurements were done by ABX testing, by the way.
- SomeJoe |
15th April 2009, 18:24 | #8758 | Link |
i have a 6.1 DTS track from a PAL DVD (25 fps) and want to sync it to a Blu-ray (23.976 fps), what are my options for lossless conversion?
suppose i have no special encoder installed, i bet my only option would be the eac3to slowdown and conversion to PCM/WAV? if i would have the Surcode DTS encoder i would be limited to 5.1 iirc? just for a later possible case for a 5.1 track, would the reencoding with the Surcode DTS Encoder result in a lossless conversion or not? (in relation to the already lossy compressed DTS source) |
15th April 2009, 18:50 | #8759 | Link | |
eac3to.exe yoursourcedts.dts output.wavs -slowdown -r8brain You will get 7 mono waves (when its dts es 6.1 discrete, but only 5.1 output when its dts es matrix) That will provide a "very" conversion from DTS ES 6.1 25fps to 23.976Fps Also i wouldnt use Surcodode DTS Encoder. Its a low quality and outdated encoder. And you cant encode dts es 6.1 with surcode DTS Pro Series is a certified Reference Encoder from DTS labs and outputs perfect quality. But you can remux your Video to 25FPS lossless with MKVmerge. Then you can use your untouched 25fps DTS Track without any Conversion. But ist not possible to timestrech Audio without reencoding. Last edited by ACrowley; 15th April 2009 at 18:56. |
15th April 2009, 19:14 | #8760 | Link |
btw how do i get the 6.1 discrete (according to the packaging) track off the DVD? DVD Audio Ripper only shows 5.1 (direct demux option)
what would the -r8brain option in eac3to do, i believe itīs a better quality conversion or something like that, if yes whatīs the difference to the standard eac3to conversion method? and whatīs a "very" conversion? iīm still learning sorry for going on your nerves can i use the Wav64 or PCM option in combination with r8brain to remux later with tsmuxer? tsmuxer canīt handle mono wavs afaik? |
eac3to |
