5th October 2007, 17:21 | #21 | Link |
madFlac v1.2 released
http://madshi.net/madFlac.rar Code:
* bugfix: channel mapping was specified correctly |
5th October 2007, 17:25 | #22 | Link | |
6th October 2007, 16:45 | #25 | Link |
madFlac v1.3 released
* property page added * option for limiting output to max 5.1 channels added |
7th October 2007, 08:36 | #26 | Link | |
Ofcourse you can acces the Options whne you click Filter Options/"Source File :customized Graph" in Zoomplayer or in mpc its in "Play/Filters" Its marginal, but maybe you can make the Decoder visible as "madflac" for Dshow Playback so that the Decoder is listed in the Filter/Graph Optiones so we can acces the Options from there ...would be more obvious And i have a 6.1 FLAC File reencoded from DTSHD 6.1 with latest eac3to. eac3to info is DTS HD "6.1" 24 and .wavs Output is 7 mono waves But Madflac Info on 6.1 Flac 7.1 CH I made a few Tests and all Flac Files reencoded from dts (hd) 6.1 are 7.1 in madflac Properties. I Dont know if its only a wrong info or madflac decodes them wrong as 7.1 Last edited by ACrowley; 7th October 2007 at 08:58. |
7th October 2007, 14:08 | #27 | Link | |
7th October 2007, 20:12 | #28 | Link |
madFlac crashes for me
Could it be because of my old CPU (no SSE)?
MPC-HC 2.2.1 |
7th October 2007, 20:45 | #29 | Link |
Can you post the crash report? At least in which dll it crashed? If it's inside of libFlac.dll then it might be SSE related. Honestly I'm not sure which version of libFlac.dll I'm using. You could try replacing that libFlac.dll (which is distributed with madFlac) with a SSE free version to see if that fixes the problem.
7th October 2007, 20:45 | #30 | Link | |
moitah.net |
7th October 2007, 23:24 | #31 | Link |
I am happy to report that Moitah's compile of libFLAC.dll works fine
MPC-HC 2.2.1 |
8th October 2007, 09:23 | #32 | Link |
@Madhsi
I simply mean that in mpc for example for AC3 the Decoder apperas as AC3 Filter, or for x264 its CoreAVC or ffdshowVideoDecoder etc You can click on the Decoder to enter Options. Thats what i mean for madflac too because the Decoder appears not as madflac as like as AC3 Filter for example....but its marginal , forget it |
8th October 2007, 10:39 | #34 | Link | |
9th October 2007, 08:21 | #37 | Link |
Ouch. Didn't test madFlac on Vista64 yet. But I've already had trouble with installing the simple "Dump" filter (MS filter which ships with GraphEdit) on Vista64! So it seems that installing 32bit DirectShow filters on Vista64 is a general problem. I'll look into this later. Can't promise a specific date for a fix, though.
9th October 2007, 12:07 | #38 | Link |
This is just for playing flac without a container, yes?
I have lots of working 5.1 flacs but as soon as I put them in an mka and mkv and use ffdshow, the sound breaks up every few seconds. Can I ask what people are using to decoder flac inside a mkv container? |
9th October 2007, 12:15 | #40 | Link |
The Vista problem might be because of UAC. Try disabling that. And of course register the filter with admin privileges.
MPC-HC 2.2.1 |
