14th August 2010, 01:10 | #21 | Link | |
Now, we have to get ArcSoft to fix their stupid decoder, and this won't be a problem. Not everyone has the DTS tools at their disposal... I'm surprised they did a true mono track. The studios usually try to up-convert everything to 5.1 or something. Or, at least using the mono track on the left and right creating 2-channel mono. Since they stuck with the mono, I'm glad to see they did it right. Rik |
14th August 2010, 08:19 | #24 | Link | |
Suppose you have two flac files. File A was encoded straight from the source. File B was encoded after adding noise to the source. You'll want file B because it's bigger and you believe it to be better quality. Difference in filesize after compression doesn't directly translate in audible difference. See LossyWAV. Lossless compression will work much better after preprocessing with it, but it's transparent on most sources with the defaults, let alone higher quality settings. |
14th August 2010, 17:08 | #25 | Link |
Banned
I was illustrating that the lower quality file (24/96) vs. the higher quality (24/192) has a higher percentage because the 24/192 does not use all of its dynamic range. When you resample it in half, it gets a more economical use of it when you losslessly compress it. And that in the case of my core vs. lossless files, the opposite is holding true, so therefore to the ears my lossless is much better. There were also obvious compression artifacts heard with the core file. When you losslessly compress something that has already been lossily compressed, it sees that it was compressed and it means it can compress lossless even more. I may not be wording it nicely, I'm not good at that.
Take a CD, rip a track to wav. Compress the wav with flac. Note the percentage. Compress the wav with a lossy format you feel is transparent. Take that lossily-compressed track and decompress it into a wav. Now compress that wav with flac, and note the percentage. It WILL be lower. Take a bmp, rar or zip it. Compress the bmp to jpg. Save that jpg back to a bmp, compress that bmp with rar or zip. Yea, the bmp that came from the jpg should be smaller! Also, with the noise debate, like it or not, vinyl has a lot of noise, but the fidelity is superior to CDs. Noise makes up part of the sound. They argue that there are frequencies on vinyl that are pointless because you can't hear them, but sound affects sound even if you can't hear it, so to me it is necessary to keep as much from the master recording intact as possible, even if its noisy. I was in my car at a red light, and a semi was sitting next to me. I had my windows partially open. I have a loud exhaust. Well the sound of his engine, which was very low in frequency, resonated with my exhaust note, and the way the windows were open, to make my car sound like it was idling half the speed it really was. I couldn't hear what sound from the truck was doing this. It was out of my audible range. Last edited by ramicio; 14th August 2010 at 17:14. |
14th August 2010, 17:26 | #26 | Link | |
14th August 2010, 17:55 | #27 | Link |
what you can do is demux the file DTS-HD MA file created by dts master suite with tsmuxer, then it becomes readable by eac3to. in a second step apply a delay of -21ms to that demuxed track so that the track will have exactly the same length as the original created file (seems to be a bug? of tsmuxer when demuxing such tracks)
14th August 2010, 19:06 | #28 | Link |
Banned
What precision? What does that even mean? You can't get back data from a lossy source because it tosses it out. If it didn't it would be called lossless. No matter how good your encoder and decoder is, you lose information. If you can't tell the difference between a lossy and a master, perhaps you have low end to average sound equipment, which would be most onboard sound out there. There are a few that feautre the x-fi, and are probably more onboard with good codecs behind them, but most are crap.
14th August 2010, 19:40 | #29 | Link | ||
I won't press you on your opinion, but you can't generalize that simply because it compresses better the quality will audibly worse. That's why I linked the LossyWAV page. Preprocessing with it can bring down the bitrate of the resulting flac by 20 to 40 percent and people are generally unable to ABX the difference, hence for most people on most samples it will be inaudible. Quote:
Random noise being introduced at playback doesn't make it higher fidelity, it makes it lower fidelity. I'm not saying that Vinyl is bad, I have several records myself and enjoy them. The noise adds a certain flair, but still fidelity is how well the input is reproduced and Vinyl is worse at that than CDs. The noise you hear when you play it back wasn't present in the master (mostly), it is an artifact introduced by the playback device. There aren't any frequencies on Vinyl that can't be on CDs. On average a Vinyl record will be able to reproduce frequencies between 60 Hz and 18 kHz, maybe a bit more when it's in perfect condition. The dynamic range is about 12 bit under perfect conditions. Basically that means everything that can be deliberately put on Vinyl, excluding noise added at playback, can be perfectly contained on a CD which supports frequencies up to 22 kHz with 16 bits dynamic range. You can like the noise, you can argue that in some cases the Vinyl was made from a better master, but technically it's sound reproduction quality is inferior. Precision refers to the bitdepth the samples will have after decoding. Due to the methods used in lossy compression you can decode the files to more or less arbitrary bitdepths. If you have an AAC file and you decode it to 16 bit PCM that's one representation of its content; by decoding it to 24 bit you'd get a more accurate representation. |
14th August 2010, 19:41 | #30 | Link | |
Now run it through eac3to a couple of times to encode to AC3 and decode back to PCM: Code:
eac3to.exe orig_track.wav inter_track.ac3 eac3to.exe inter_track.ac3 new_track.wav |
14th August 2010, 20:22 | #31 | Link | |
Banned
Both waves are a 10 khz sine wave. Top file format is 24/192. bottom is 24/44.1. So you're saying a cd will sound better on a sole reason of having no noise? That's 10 khz. Less than half the total frequency a CD can reproduce. They become square waves at that point and sound bad. I know musical instruments don't produce their audible frequencies that high, except cymbals, which is the one thing that annoys me when listening to CDs. The cymbals sound artificial. CDs are fine for rap music or electronic stuff that is supposed to sound artificial. That's why I prefer to listen to my classic rock on 24/96 vinyl rips. Oh, and there's the turntable with lasers as a pickup. That would be the ultimate for someone who can afford it, as there would be no noise, and quite possibly the closest you can get to a master recording. |
14th August 2010, 20:32 | #32 | Link |
This discussion is off-topic, however, I'll add something: one can't hear the digital sound: this will be converted to analog, and according to the D/A-converter in use, the "steps" will be attenuated.
Besides, the discussion vinyl vs. CD has its own topic. I own a medium price and quality LP-player, also a very good CD-player, medium class AVR and old-fashioned loudspeakers (not the type that has 2" tweeters and generates the basses through cunning reflexions) and the CD sounds better than the LP (on the same album), in every aspect, including the noise in the quit passages in classic music. |
14th August 2010, 20:48 | #33 | Link | |
Banned
14th August 2010, 21:03 | #34 | Link | |
Banned
1. the eagles - hotel california - 01 - hotel california 1.wav: This is the basis. I downsampled to 48 khz, kept it 24-bit. 2. the eagles - hotel california - 01 - hotel california 1.flac: This is the basis FLAC. 73.8% 3. the eagles - hotel california - 01 - hotel california 1.ac3: This is the first ac3 encode. 448 kbps, with eac3to. 4. the eagles - hotel california - 01 - hotel california 2.wav: This is decompressed from the eagles - hotel california - 01 - hotel california 1.ac3. 5. the eagles - hotel california - 01 - hotel california 2.flac: This would be the FLAC from the eagles - hotel california - 01 - hotel california 2.wav. 72.8% 6. the eagles - hotel california - 01 - hotel california 2.ac3: This is compressed from the eagles - hotel california - 01 - hotel california 2.wav @ 448 kbps. 7. the eagles - hotel california - 01 - hotel california 3.wav: Decompressed the eagles - hotel california - 01 - hotel california 2.ac3. 8. the eagles - hotel california - 01 - hotel california 3.flac: FLAC from the eagles - hotel california - 01 - hotel california 3.wav. 71.9% This all is the reason why EXE files or JPG files don't compress much when you archive them in a ZIP or RAR. You get much better compression if you were to compress the source code of said EXE, or a BMP. |
14th August 2010, 21:11 | #35 | Link | |
14th August 2010, 21:15 | #36 | Link | |||
They'll most likely both sound the same. Even if the first recording was made at 16 bit I'd still claim that. Higher bitdephts and samplingrates are beneficial for processing, so if you plan to do that recording higher can't hurt, but for listening it's a waste of space, especially if you record from a vinyl. Everything outside the bounds I've listed in my previous post is caused by dirt in the groves, wear of the groves and other imperfections of the playback system. If you can actually hear a difference it's likely that something went wrong during recording. You could downsample and dither your high resolution track to 16 bit 48 kHz. An ABX test could then establish if there is an audible difference, assuming the playback hardware isn't to blame (I remember reading about one such case where the soundcard introduced artifacts at certain samplerates). Even with samples specifically created for that purpose people are hardly able to ABX 16 bit from 24 bit and 48 kHz from 192 kHz under controlled conditions, so I don't buy that recording a Vinyl with a dynamic range and noise floor way above and beyond what the medium can provide will help. Quote:
Let's say you actually take your 10 kHz sine wave and put it on Vinyl and CD. You rip both, the former you record to 24 bit 192 kHz and the latter you upsample to that (or you downsample the former, doesn't matter). If you now compare both recordings to your master the CD will be closer to it because it didn't have a boatload of artifacts introduced during pressing and reading. Vinyl is analog, but the groves are neither pressed nor read with infinite precision. The values I've given are real live limits verified through extensive testing. Again, I'm not saying you shouldn't enjoy Vinyl. All I'm saying is that when it comes to fidelity it is inferior to CD. I recommend you go over to Hydrogenaudio and take a look at their wiki pages about Vinyl, especially the FAQ and the Myths section. By the way if you actually have samples where the difference between 16 bit 48 kHz and 24 bit 192 kHz is audible and you can reliably identify them by ABX tests the people there will be very interested in you and your samples. Last edited by nurbs; 14th August 2010 at 21:18. |
14th August 2010, 21:21 | #37 | Link | |
Banned
This started as a help thread because I wanted the lossless. I wasn't asking for anyone's opinion on if the lossy would be a neglible difference. Rik was helpful, and he didn't present any opinion on why I wanted the lossless. For that I thank him. I'm not telling anyone they should buy a huge hard drive and have an entire music collection in lossless, as I do. If you like what you have and like to listen to it, great! For me I enjoy the best quality I can get. For video, I don't care as much, as long as I don't see compression artifacts I'm satisfied. Transcoding video takes a long time, this is why I don't care. Audio is different story and to transcode things takes me little time. I myself can tell a huge difference between DVD-Audio @ 24/192 and the same album on CD. Last edited by ramicio; 14th August 2010 at 21:26. |
14th August 2010, 21:55 | #38 | Link | ||
I'm not arguing that you should prefer CD to vinyl. That's just personal preference. I'm with you - I love records. I was just saying that your graphs with their stair steps are misleading. Again I never offered an opinion on lossy vs lossless. That's for you to decide. I was just suggesting that decoding a lossy track and then seeing how it compresses with FLAC isn't necessarily a useful metric to judge audio quality because other factors can come into play. |
14th August 2010, 22:07 | #39 | Link |
Banned
Dude, it's called lossy for a reason. You CANNOT keep information on lossy compression. This is why it's called LOSSY. It doesn't matter what sound format I used for this. To encode a 16 bit file into ac3 and have it decode to a 24 bit just shows there is loss and it needs the extra info of 24 bits to give you the info instead of rounding it. Even at 24 bits you still lost info. If you downconvert to 16 bits it will just round off the numbers. You weren't the one to tell me to just grab the lossy, with no help, it was in post #4. For me, lossy compression is fine for my iPhone, where there is not a lot of space, but for my pc, its lossless. I really hate mp3, even at 320 it sounds bad. I like AAC. At 320 it sounds damn good, and way better than mp3@320. I don't need crazy quality for my phone, I have nice Bose earbuds, but earbuds are limited in quality, and whenever I listen to music with it, the environment isn't quiet. The thing I really don't like about CD is the way they compress it. If you look at the same song on CD, vs a captured vinyl, or if you're lucky a DVD-Audio, like every sound on the CD will be at peak volume. I have witnessed a few CDs that do sound awesome, and their waveform is quieter and more natural.
14th August 2010, 22:49 | #40 | Link | |
