Old 30th March 2007, 06:14   #41  |  Link
tchaikovsky
Hi, Olivier
Sorry for WMEA did not work for you. I posted my test note about evo files encoding on WMEA's blog after replyed your mail. I wrote a little test note(I'm not sure which word it better) and linked a longer WMVHD clip (longer than the mail that replayed to you) in that post.
I have no Vista to do the test for you, so, I think it might help...
-= WMEA =- Your fast, easy, batch windows media encoder
-= WMEA Blog =- The blog about this app and some other news
tchaikovsky is offline   Reply With Quote
Old 30th March 2007, 11:33   #42  |  Link
olivierdb
Hi Moz,
You posted 2 methods on the WMEA blog:
First is more complex, WinDVD8, EVODemux, GraphEdit, Avisynth2.57 and WMEA is needed.
1. Demux EVO to mpv & mpa
2. Using GraphEdit make two filter graphs, write 2 Avisynth script.
3. Make sure WMP can play your 2 avs files, then load separate video & audio avs to WMEA, start encoding job.
Second is easier, WinDVD8, EVODemux, Elecard MPEG-2 Decode Pack 3.0, AC3filter1.11 and WMEA is needed.
2. Make sure your mpv & mpa can be played by WMP correctly, then load mpv & mpa to WMEA, start encoding job.
However, neither of them work at present! ... at least, not under Vista!
In the first case, there is an issue with WMEA accepting seperate video and audio AVS and WMEA ends up "Not Responding".
In the second case, (where I don't see why you would need WinDVD8) only the audio is converted. The video is totally neglected! I also tried playing back a VC-1 file in WMP 11 after having installed the Elecard MPEG-2 Video Decoder, but it doesn't play! I even tried the Elecard AVC plug-in for WMP, but that didn't work either!
I've also been wondering, do all HD-DVD EVO files contain all 3 following formats or just ONE of the 3: MPEG-2 HD, VC-1, and H.264/AVC ?
olivierdb is offline   Reply With Quote
Old 30th March 2007, 17:30   #43  |  Link
tchaikovsky
I know your EVO is VC1/DTS, that test note is a demo for EVO encoding, not a guide, so, I think it might help, but... It seems totally useless for you. Throw it away...
I'd like to do some tests if you give me a link that can download your EVO clip
Old 30th March 2007, 23:24   #44  |  Link
olivierdb
Moz, The clip is >8GB total! I have extracted the first few minutes into a clip of 250MB. Please find here:
http://www.sendspace.com/file/thsg41
P.S. I recommend you start downloading just before going out for lunch or something!
Old 31st March 2007, 11:24   #45  |  Link
DarkNite
Almost Silent Member
DarkNite's Avatar
One. Including all 3 would take ~3 times the space, and would be completely unnecessary.
Rethinking the "Why?" chromosome.
DarkNite is offline   Reply With Quote
Old 31st March 2007, 13:32   #46  |  Link
tchaikovsky
...I can't access that server directly, It will be very slow if I access that server via a proxy, would you please upload that clip to mydatabus? Thanks in advance !
Old 31st March 2007, 19:48   #47  |  Link
jubilex
I used the following script:
cscript.exe "C:\Program Files\Windows Media Components\Encoder\wmcmd.vbs" -input "C:\Path to my AVS file\sourcefilename.avs" -output "C:\test.wmv" -v_codec WMV9 -v_mode 2 -v_bitrate 6000000 -v_keydist 30 -v_buffer 10000 -v_quality 100 -v_preproc 1
I don't know about the errors, but v_mode 2 is constant quality one-pass, so the bitrate parameter would be ignored -- the v_quality is used instead, and since you have that set as 100, the file will be huge (but nice looking!). For HD CQ, I use quality of 95 or 96. You only use the bitrate parameter if you are doing cbr or vbr (v_modes 0, 3, and 4).
jubilex is offline   Reply With Quote
Old 31st March 2007, 19:49   #48  |  Link
jubilex
By the way, my typical parameters for a 5.1 sound CQ encode are:
-v_bframedist 1 -v_bdeltaqp 1 -v_mslevel 1 -v_codec wvc1 -v_keydist 3 -v_mode 2 -v_quality 96 -v_mmatch 0 -v_msrange 0 -v_performance 20 -v_loopfilter 1 -a_codec wmapro -a_setting 384_48_6_24
Old 31st March 2007, 20:46   #49  |  Link
olivierdb
@DarkNite: Thank you for your answer. I guess VC-1 is the prefered format.
@jubilex: Thanks for your feedback. I'll make some tests with your parameters.
@tchaikovsky: Here is the link. I don't think it's any faster than sendspace because it took me another 2 hours to upload!
part0001.evo
Old 3rd April 2007, 13:53   #50  |  Link
olivierdb
@jubilex: A big thank you: your parameters produced awesome results! I just had to change the audio settings to: -a_setting 192_44_2_24 because I got an error!
Maybe I didn't have to change the bit rate, but I think InterVideo Audio Decoder only produces 2 channels output?
Old 5th April 2007, 14:04   #51  |  Link
olivierdb
When encoding to WMA Pro using WMCmd.vbs, does any one know which version of WMA Pro is being used? Is it version 9 or v10?
Old 5th April 2007, 15:33   #52  |  Link
buzzqw
HDConvertToX author
runnign cscript wmcmd.vbs -a_formats and wmcmd.vbs -a_codecs you will have the answer
anyway...
Microsoft (R) Windows Script Host Versione 5.6
Copyright (C) Microsoft Corporation 1996-2001. Tutti i diritti riservati.
Audio Codecs:
CBR Audio Mode :
	[0] WMASTD : Windows Media Audio 9.1
	[1] WMSP : Windows Media Audio 9 Voice
	[2] WMAPRO : Windows Media Audio 9.1 Professional
	[3] PCM : Nessuno (PCM)
Peak Bit Rate-Based VBR Audio Mode :
	[1] WMAPRO : Windows Media Audio 9.1 Professional
Quality-Based VBR Audio Mode :
	[2] WMALSL : Windows Media Audio 9.1 Lossless
BHH
AutoMen: The Mencoder GUI
AutoWebM: supporting WebM/VP8
Old 5th April 2007, 15:54   #53  |  Link
olivierdb
Grazie mille, buzzqw.
Just FYI - you don't have the latest version (v5.7 supports WMA Pro 10).
Old 6th April 2007, 04:49   #54  |  Link
zambelli
Doom9ing since 2001
zambelli's Avatar
5.7 is the version of Windows Script Host.
Buzzqw has WMF SDK 9.5 (WMP10) installed, while you are probably running Vista. That's where the codec difference comes from.
Wmcmd.vbs is version-agnostic as far as WMA Standard and Pro are concerned. It'll use whatever is on the system.
zambelli is offline   Reply With Quote
Old 6th April 2007, 07:14   #55  |  Link
buzzqw
HDConvertToX author
yep... i am now working on win2003 server so no wmp11... iirc...
BHH
Old 6th April 2007, 10:16   #56  |  Link
zambelli
Doom9ing since 2001
zambelli's Avatar
I'm not endorsing it, but a few people have figured out ways to install WMP11 on W2K3:
http://www.neowin.net/forum/index.ph...st&p=588446611
The post I linked sounds the easiest and without unnecessary .INF editing and whatnot.
I haven't tested it myself... So if you decide to try it, proceed cautiously.
Old 6th April 2007, 10:24   #57  |  Link
olivierdb
Good morning Zambelli!
I've got people getting errors with wmcmd.vbs and I don't understand the meaning of the errors they are getting!
Would you be able to help. The post is here.
Thank you. You're the expert!
Old 7th April 2007, 07:08   #58  |  Link
zambelli
Doom9ing since 2001
zambelli's Avatar
I tried this today and I can confirm that it works. Once again - I want to stress that this is completely unsupported by Microsoft - but if you really need to get v11 codecs on a Server 2003 system, here's how you can do it:
1. Install Service Pack 2 for Server 2003. If that's not an option, change the registry value HKLM\System\CurrentControlSet\Control\Windows\CSDVersion from 100 to 200, then follow the remaining instructions, and after install change back to 100.
2. Copy wmfdist11.exe to a local drive. You can extract it from a WMP installer (wmp11-windowsxp-x86-enu.exe) with WinZip/WinRAR, get it from the full WM Format 11 SDK, or just search the Internet for a download location.
3. Right click on wmfdist11.exe, pull up its properties. Under the “Compatibility” tab, select “Run this program in compatibility mode for” and set it to “Windows XP”.
4. Run wmfdist11.exe. WM Format 11 runtime installs.
5. Change "CSDVersion" back to 100 if you changed it in the first step.
That's all. If you want WMP too, follow the same steps for wmp11.exe, though it's not necessary to install the player if you just want the codecs.
Old 3rd May 2007, 02:56   #59  |  Link
shaolin95
OK guys, for a noob here. :-)
I got an avi file encoded from a vc-1 using VirtualDub and want to mux it (combine it) with a wma audio from the same movie.
I thought it was a matter of loading both in this app but somehow I started to get two separte files istead of a combined one.
Any help appreciated. :-)
shaolin95 is offline   Reply With Quote
Old 3rd May 2007, 04:22   #60  |  Link
shaolin95
Originally Posted by crypto View Post
You should put video and audio into one avs and use the audiodub (video, audio) command.
You can also encode video and audio seperately and mux wmv and wma using the Windows Media Stream Editor from the WME9 package.
BTW, I tried the media editor and it told me it can only do one type of file....
