#1 | Link |
Dreambox guide
New guide on dreambox and direct mpeg2 sat stream capture on doom9 : http://www.doom9.org/DigiTV/dbox-howto.htm And here is the thread for comments & questions. /klona |
#2 | Link |
Digital+
I've read your guide and the dreambox is really the box of my dreams ;-) (well, maybe if it could play divx...)
I am right now subscribed to Digital+ over hispasat, and my (rented to the company) receiver has an HD so I can program captures (to the small internal HD only, of course) but the software is really horrible, I cannot extract the streams (so I am limited to one language, for example), the capacity is very small, the programming capabilities are abismal, the machine is really noise... should I go on? :-) The thing is, I would love to change to one (or maybe two, if I can share the card!) dreamboxes... do you know if they will work with my satellite and subscription card? should I change to Astra sat? (it would be possible on my house, but a little expensive). I have no ethernet cabling near where the box should be, but I suppouse I could connect using wi-fi... Thank you very much, and congratulations for your great guide. |
#6 | Link |
Hello I have read your Dreambox guide but I need some basic information: I am having a lot of problems setting up a Dreambox 500S receiver. In setup I get the message "Found no LNB with
DISEqc 1.2 enabled. Please go to Satellite Config first, and enable DISEqC 1.2" I only have one LNB and pointing to one Satellite and I suspect I have some LNB setup configuration problems. If I do a Transponder scan I get the message "All known transponders have been tried but no lock was possible. Verify antenna/cable setup or try another satellite/network" Can you please give me some basic guidelines to setup one Satellite and one LNB (non motor)? I used another receiver to test that I am indeed receiving the transponder signals from this particular satellite fine. Thanks. Muhith |
| Thread Tools | |
| Display Modes | |
