28th February 2013, 22:14 | #17841 | Link | |
28th February 2013, 23:29 | #17842 | Link |
make sure output 0-255 is set everywhere... madVR, ffdshow, LAV, whatever else you use in your setup.... also make sure you ouput 0-255 via HDMI... Instead of trying to make a custom resolution work, you can simply apply this hack http://blog.metaclassofnil.com/wp-content/uploads/2012/08/NV_RGBFullRangeToggle.zip (you have to reboot for the changes to have an effect)
1st March 2013, 07:57 | #17843 | Link |
madVR also includes a tool to set RGB Full Range over HDMI, its a small stand-alone tool included in the madVR zip, no need to use something third-party, works perfectly for me
1st March 2013, 10:45 | #17844 | Link | |
Hope that clearify it. I apologize for the confusion. PS. Printscreen doesn't work with madVR anymore? And MPC-HC/BE build-in screenshot taking does not capture madVR stat, so how do you guys do it?
Spec: Intel Core i5-3570K, 8g ram, Intel HD4000, Samsung U28D590 4k monitor+1080p Projector, Windows 10. |
1st March 2013, 11:14 | #17846 | Link | |
I still hope for an answer from madhsi and/or Nev about why deinterlacing times change massively when different scalers are used. Disable overlay and you can take screenshots as normal.
TV Setup: LG OLED55B7V; Onkyo TX-NR515; ODroid N2+; CoreElec 9.2.7 |
1st March 2013, 12:19 | #17847 | Link | |
Is this a bug or a feature, being able to control lip-synch from within madVR? |
1st March 2013, 13:54 | #17851 | Link |
Madshi,
could you please consider a function (that can be enabled or disabled) that whenever a given number of frame drops occur the OSD automatically appears? The reason is to be sure everything is going the way it should without having to manually check with ctrl+J now and then. Plus sometimes when the number of dropped frames is not massive I find difficult to be aware of the situation if not by hitting ctrl+J. Thanks!
Raven RVZ01 * i7-4790k * 16GB RAM * Zotac GTX 970 4G * SSD 850Evo 500GB * Blu-Ray Burner Slot-In * PSU SFX 80+ Gold 450Watt * Windows 10 64bit * MPCHC+MadVR+SVP * Panasonic 50" VT30 ^^ |
1st March 2013, 14:10 | #17852 | Link | |
Just FYI, since I have a GTX580 I can use minimum values for queueing and buffering and I still have a perfectly smooth experience with that. Even if I do increase everything to the maximum values, I never encountered lip-sync issues. Last edited by iSunrise; 1st March 2013 at 14:13. |
1st March 2013, 14:12 | #17853 | Link | |
Also, it would be hard since switching from exclusive to windows always produce dropped frames(there may also be other instances of where dropped frames are normal) so you'd have to find a way to not count those. |
1st March 2013, 14:23 | #17854 | Link | |
In exclusive mode hitting ctrl+J I get no single frame drop, the same goes while playing videos with appropriate settings. The option could of course be configurable, like "if more than x consecutive frame drops occur than...
1st March 2013, 14:37 | #17855 | Link |
I realize I was clear enough, I meant going from fullscreen exclusive to not fullscreen windowed. I usually get around 20-30 dropped frames that way, which is way more than when things go wrong(but not more then when they go really horribly wrong).
My point was that for the moment before your conciousness realize that something is wrong, the problem isn't bothering you since you're not aware of it even if it was wrong. |
1st March 2013, 17:34 | #17856 | Link | |
1st March 2013, 19:17 | #17858 | Link |
Having recently had a problem getting madVR .086 to run I would suggest extracting each new version to its own folder. I would then run the uninstall.bat of the old version before running the install.bat of the new version. You can then delete the old version folder if you are happy things are working correctly.
1st March 2013, 19:18 | #17859 | Link |
I don't know if it's the right way, but I just run the uninstall.bat from the old folder and then the install.bat from the new one and never had any problems. I do add the version at the end of the folder name though so it's never in the same folder, but I would assume deleting all the old files before putting the new ones in would provide the same result.
Edit: ...so pretty much what the guy who was faster than me said. |
