6th August 2009, 18:56 | #4401 | Link |
whats about that error:
- Error in attempt to multiplex: MUX_00226.meta - This is not an EBML file (id=0/440786851 [17:54:09] - Failed to build structure, aborted i've rebuild 1 BD and no errors appears, but after the 2st one, allways appears that error |
6th August 2009, 21:19 | #4402 | Link | |
6th August 2009, 21:21 | #4403 | Link | |
6th August 2009, 21:46 | #4405 | Link | |
Where else would I need to change the PID of the secondary video stream and audio streams? Only in the clpi file? I took a look there, do I need to replace all occurences in the clpi file? Bye |
6th August 2009, 23:29 | #4409 | Link | |
According to TSMuxer there are two video tracks and three audio (ac3 640 6C, ac3 224 2c and e-ac3 dd+ 192 2c) The original has (True HD 6c, spa, spa, eng 224 2c, ita, por, por, deu, tur, then the PGS and finally E-AC3 DD+ 192 2c) |
7th August 2009, 01:33 | #4410 | Link | |
Not trying to stir the pot....just wondering if there's some logical reason why this question never gets answered here.... Anybody? |
7th August 2009, 02:17 | #4411 | Link | |
Webmaster
7th August 2009, 05:00 | #4412 | Link | |
7th August 2009, 05:04 | #4413 | Link | |
I can't fix something unless there is some consistency. Last edited by jdobbs; 7th August 2009 at 05:10. |
7th August 2009, 09:13 | #4414 | Link | |
Hello jdobbs,
Your program is very well designed! But we will have the opportunity to translate this program in the near future because many do not use your program because he does not understand. Do not make the same mistake with DVD Rebuilder. All communities expect a possibility of translation, it is still not too late to develop the multilanguage your program. Thank you in advance to take this message because your program is really great Quote:
7th August 2009, 09:30 | #4415 | Link |
well tried again over night with the same result using v0.25.04 beta just like DK results but still get
----------------------- [21:48:52] BD Rebuilder v0.25.04 (beta) - Source: PIRATES2_DEU - Input BD size: 39.35 GB - Approximate total content: [03:22:44.610] - Target BD size: 22.46 GB - SHUTDOWN at completion enabled [21:48:52] PHASE ONE, Encoding - [21:48:52] Extracting A/V streams [VID_00002] - [21:48:52] Reencoding: VID_00002 (1 of 13) - [21:49:05] Extracting A/V streams [VID_00014] - [21:49:11] Reencoding: VID_00014 (2 of 13) - [21:50:03] Extracting A/V streams [VID_00022] - [21:50:12] Reencoding: VID_00022 (3 of 13) - [21:51:16] Extracting A/V streams [VID_00019] - [21:51:31] Reencoding: VID_00019 (4 of 13) - [21:56:20] Extracting A/V streams [VID_00021] - [21:56:41] Reencoding: VID_00021 (5 of 13) - [22:02:21] Extracting A/V streams [VID_00010] - [22:02:47] Reencoding: VID_00010 (6 of 13) - [22:10:11] Extracting A/V streams [VID_00012] - [22:10:38] Reencoding: VID_00012 (7 of 13) - [22:15:55] Extracting A/V streams [VID_00017] - [22:16:19] Reencoding: VID_00017 (8 of 13) - [22:22:46] Extracting A/V streams [VID_00016] - [22:23:26] Reencoding: VID_00016 (9 of 13) - [22:36:35] Extracting A/V streams [VID_00013] - [22:37:52] Reencoding: VID_00013 (10 of 13) - [22:49:00] Extracting A/V streams [VID_00018] - [22:51:22] Reencoding: VID_00018 (11 of 13) - [23:55:12] Extracting A/V streams [VID_00020] - [00:02:10] Reencoding: VID_00020 (12 of 13) - [03:12:06] Extracting A/V streams [VID_00001] - [04:15:45] Reencoding: VID_00001 (13 of 13) - Encode failed. Retrying. - Encode failed. Retrying. - Reached retry limit. Aborting. [04:19:01] - Failed video encode, aborted ----------------------- [08:52:26] BD Rebuilder v0.25.04 (beta) - Source: PIRATES2_DEU - Input BD size: 39.35 GB - Approximate total content: [03:22:44.610] - Target BD size: 22.46 GB - SHUTDOWN at completion enabled - Resuming from previously started job. [08:52:31] PHASE ONE, Encoding - [08:52:31] Reencoding: VID_00001 (13 of 13) - Encode failed. Retrying. - Encode failed. Retrying. - Encode failed. Retrying. - Encode failed. Retrying. - Reached retry limit. Aborting. [08:57:51] - Failed video encode, aborted ----------------------- [08:59:14] BD Rebuilder v0.25.04 (beta) - Source: PIRATES2_DEU - Input BD size: 39.35 GB - Approximate total content: [03:22:44.610] - Target BD size: 22.46 GB - SHUTDOWN at completion enabled - Resuming from previously started job. [08:59:16] PHASE ONE, Encoding - [08:59:16] Reencoding: VID_00001 (13 of 13) - Encode failed. Retrying. - Encode failed. Retrying. - Reached retry limit. Aborting. [09:02:35] - Failed video encode, aborted for some reason the frames don't match up : 042710 / 042717 i have cross checked this and it is the same on all atempts i have made i have now used three different 2-disc editions of potc-dmc and get the same result with only the main feature disc the bonus disc backup no problem so i'm confussed as to why this is happening i have used every version of bd going back to bd v.2009 and i'm only having trouble with potc curse and potc dmc p/s have installed all up todate drivers and codec's [Options] RESIZE=0 MODE=0 TARGET_SIZE=23000 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP=all TRELLIS=1 COLOR_BOOST=0 RESIZE_1080=0 DTS_REENCODE=1 AC3_REENCODE=1 AC3_640=1 KEEP_HD_AUDIO=0 AVCHD=0 REMOVE_WORKFILES=0 AUDIO_TRACK_LIMIT=1 SUBTITLE_TRACK_LIMIT=1 CUSTOM_TARGET_SIZE=23450 ENCODE_QUALITY=5 [Paths] SOURCE_PATH=E:\ WORKING_PATH=C:\WORK\ thanx again for any help By-Tor |
7th August 2009, 13:58 | #4417 | Link |
@By-Tor
Whe BD Rebuilder fails in an encode, I need to see what is causing the failure in X264. In the BD Rebuilder folder there is a file called LASTCMD.TXT. It contains the last X264 command line executed. Open that file and cut the command to the clipboard. Then open a command windows (CMD.EXE) and paste the command. When it runs you should be able to see an error message from X264 when it fails. If you can report that it may help find a solution. |
7th August 2009, 16:50 | #4419 | Link |
Just thought I'd let you know, there's an issue when trying to encode on Dual Nehalem systems. All works fine unless you have field based VC-1.
If you try to encode field based VC-1 it doesn't like having the hyper-threading on. If you turn off hyper-threading and let the system just see the physical cores then it encodes them fine on high quality, but if you turn it on then it just fails to encode those files, sometimes it'll do the first pass but never the second(it works if you set it to BD-25 and fast encode for BD25) I suspect it's to do with the number of cores as it has no issue with single i7 systems |
7th August 2009, 18:08 | #4420 | Link | |
thanx for getting back |
