6th March 2018, 16:37 | #15622 | Link | |
ByteShare
Have you tried manually starting the encoding servers from the encoding clients a few times? |
6th March 2018, 21:23 | #15624 | Link |
Fist and foremost to Atak_Snajpera regardning Windows 10 and RipBot264, but IF anyone else can help, Iīm MORE then glad!
I have had RipBot264 and it has worked fine for several years now on Windows 7, but had a crash here and was forced by HW and so on to install Windows 10 Pro. After installation I tryed RipBot264 and it ALLWAYS crash somewere in the middle of Pass 2 so the next screen I see it that H.264 or H.265 has crashed (see attached Picture). After I Close that popup screen, RipBot264 remuxes the Movie and it usualy is around 40~ mins, NOT the hole Movie. (https://imgur.com/a/Tpnjr)[QUOTE] Please help!!! Last edited by MaistroX; 6th March 2018 at 21:36. |
6th March 2018, 22:46 | #15625 | Link | |
ByteShare
[QUOTE=MaistroX;1835669]Fist and foremost to Atak_Snajpera regardning Windows 10 and RipBot264, but IF anyone else can help, Iīm MORE then glad!
I have had RipBot264 and it has worked fine for several years now on Windows 7, but had a crash here and was forced by HW and so on to install Windows 10 Pro. After installation I tryed RipBot264 and it ALLWAYS crash somewere in the middle of Pass 2 so the next screen I see it that H.264 or H.265 has crashed (see attached Picture). After I Close that popup screen, RipBot264 remuxes the Movie and it usualy is around 40~ mins, NOT the hole Movie. (https://imgur.com/a/Tpnjr) Quote:
7th March 2018, 12:31 | #15628 | Link |
@MaistroX
x264/x265 crashing may suggest that your CPU or/and memory are not stable! @MerolaC https://forum.doom9.org/showthread.p...36#post1827936
7th March 2018, 17:51 | #15630 | Link | |
Thx, I will look into IF itīs stable @normal Clock!
Is there a way to get RipBot264 to use all (or be able to set) CPU Power on ex a Ryzen 1800X, as Itīs now it uses not more then 40%->65% max? See attached Pictures Regards MaistroX Quote:
7th March 2018, 18:26 | #15631 | Link |
DE mode. In your case 2 servers will be enough.
https://forum.doom9.org/showthread.p...50#post1831550
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 7th March 2018 at 18:29. |
7th March 2018, 18:54 | #15632 | Link | |
Was that info a answer to my question? 😉
I only use one PC here so is DE mode still an option? Regards MaistroX Quote:
7th March 2018, 20:05 | #15633 | Link |
7th March 2018, 21:49 | #15634 | Link |
When doing batch job and setting it to autocrop and the movie is without black bars to crop, then it output this in the avs script: video=Crop(video,0,0,-0,-0), not sure if it hurts performance in anyway, just look a bit odd to even write the line.
8th March 2018, 02:52 | #15635 | Link |
Posting Images
For those of you trying to post images on this site, it will not or ever get approval. You need to place the image on a online image repository and then paste the link in your post so it will show.
I use photobucket. You can create a FREE account and then upload your images to this repository. After uploading you can copy the "Direct Link" and paste that "link" in your post or you can copy the IMG code and paste directly. So to help explain this a little better, here is a YouTube LINK for a quick tutorial. It is a little bit old, but you should be able to find the same functionality in the latest version. Hope that helps those of you trying to display your images / screenshots. |
8th March 2018, 20:59 | #15636 | Link | |
Just Tryed DE Mode , and it direct getīs me this error ->
"FFVideoSource: Failed to open '\\RWDA-2018\TBOEM_2017-Test-1-005.mkv' (C:\Temp\RipBot264temp\job4\Chunks\getinfo.avs, line 7) getinfo.avs file here -> http://s000.tinyupload.com/?file_id=...94132656792224 How to fix this? Regards Quote:
9th March 2018, 12:14 | #15637 | Link | |
\\RWDA-2018\RipBot264temp\job4\video.mkv You will have to show me step by step what you do exactly (video would be very helpful!)
9th March 2018, 16:28 | #15638 | Link |
ByteShare
x265_x64.exe error
Trying to help a friend but not sure what is causing this since I've never had this issue, just FFMPEG issues:
https://cdn.discordapp.com/attachmen...00/unknown.png These are the settings used: Code:
--preset slow --profile main10 --multi-pass-opt-analysis --multi-pass-opt-distortion --output-depth 10 --aq-mode 3 --aq-strength 0.55 --me 3 --subme 3 --rc-lookahead 50 --no-strong-intra-smoothing --no-constrained-intra --deblock -1:-1 --psy-rd 2.0 --no-sao --bitrate 1125 |
9th March 2018, 18:58 | #15639 | Link |
Check CPU and memory stability. You must be 100% sure that it is not an OC issue.
