4th October 2018, 08:19 | #61 | Link | |
Thanks, huhn. That makes sense. I have great results enabling that option. Good natural colors without oversaturation.
4th October 2018, 14:13 | #62 | Link |
off topic WINDOWS 1809 issue - you cant make the task bar black that I can find, you can get it very dark grey but not black, this unfortunately means that even if you hide the task bar to stop burn in on OLEDS there is still a line of grey pixels along the bottom of the screen which are there all the time, this is bad for OLEDS.
The only fix i've found so far is to install CLASSIC SHELL where you can set the task bar as fully black, not ideal.
LG OLED EF950-YAM RX-V685-RYZEN 3600 - 16GBRAM - WIN10 RX 5700 - https://www.videohelp.com/software/madVR/old-versions |
4th October 2018, 16:12 | #63 | Link | |
4th October 2018, 16:14 | #64 | Link | |
4th October 2018, 16:48 | #65 | Link | |
However, this also happens with my Samsung TV so i've pretty much ruled Mt TV and AVR out of the equation. I'm probs going to have to re-image my HTPC but I'm really reluctant to do that as its a 3 day build at least as its also a server with 12 disks in it - but also, if I dont know what is causing it, if it comes back I'll be back to square one and 3 days down. I was hoping MADSHI had an AMD contact but because there are only a couple of people with this problem, and thats its defeatable, he's not really got time to look at it, which is fair enough. I was just hoping that with the way it manifested itself it would be obvious to someone what was going on. Thanks for your interest though
4th October 2018, 16:55 | #66 | Link | |
EDIT: Yea something's very wrong here. I went back to madvr 0.9.17 and I'm seeing the same problem so it's not the latest test builds. I'm getting the exact same output from the tone mapping option as I do with passthrough. Doesn't matter what I change on the tonemapping option.
HTPC: Windows 11, AMD 5900X, RTX 3080, Pioneer Elite VSX-LX303, LG G2 77" OLED Last edited by SamuriHL; 4th October 2018 at 17:05. |
4th October 2018, 23:53 | #67 | Link |
Ok, got some help from madshi on this. First, the assumption that 100 nits with HDR turned on would automatically be dark was wrong. There is simply no way to know what the TV is going to do. In my LG C8's case, it cranks up the brightness. Second, he gave me some excellent source material to show what's going on with. One is his 10000 nit color test pattern (32 bit players only) and the other is the spear in BvS. HDR tone mapping is *DEFINITELY* active and working. And with those 2 different source materials it's a huge difference. WAY more detail in the spear scene and even his test pattern with tone mapping enabled in madvr. Now I'll have to play some more tomorrow.
5th October 2018, 09:59 | #68 | Link | |
5th October 2018, 11:39 | #69 | Link | |
5th October 2018, 14:24 | #70 | Link |
Your questions are very difficult to answer because it depends on a lot of variables. And I'm not entirely sure myself what looks "best" at the moment. Now that I have scenes which definitely show the differences it's a matter of sitting and testing. I'd start by using a target nit close to your TV max. For oled between 700 and 800. Then the restore details you'll have to play with. With hdr on I prefer a higher setting. Also make sure to turn on the color gamit option in the trade performance options. I highly recommend testing it on the BvS spear scene as you will see quite clearly what's happening with the picture with those options.
Sent from my Pixel XL using Tapatalk
5th October 2018, 14:28 | #71 | Link |
That doesn't mean the option is entirely useless. Even if your TV is tone mapping you could benefit. Think about it this way... Your TV tone maps when the movie is above the limits of the TV. In theory, and I stress the theory part of this because as madshi said we don't actually know what the TV does internally, if you make it closer to the TV parameters the internal tone mapping should have less to do. Try what I recommend in my previous post and see what happens. It'll become very clear if there's a benefit or not.
5th October 2018, 14:34 | #72 | Link |
i tried it, it seemed to made no difference I could see, should I try a different value than 400 nits, what else can i try / change?
5th October 2018, 14:52 | #73 | Link |
What scene did you try it on? In motion it's hard to see the benefits clearly. Paused in the right scene the impact becomes crystal clear. I typically target about 800 nits.
5th October 2018, 15:04 | #74 | Link |
just what I had available, interstellar 4K HDR, the bit when they visit the cloud planet, coming down through the clouds, thought that would be good to show any highlights that were brought out.
My TV does 400 nits max at 2%, drops off horribly after that.
5th October 2018, 15:35 | #75 | Link |
Then keep the target nits at 400. As for the scene, it might be a good one to show or it might not. If you look at the AVS thread, there's a post from april that has a few of the test scenes that they're using to evaluate the changes in each test build. One of them is what they call the green spear scene from BvS and that's the one I used to see exactly what kind of differences I get from madvr tone mapping vs pass-through. I would recommend that. Or madshi's 10000 nit color test pattern. For that you'll have to install a 32 bit player if you don't have one, and then install his filter. I will tell you that is an amazing test pattern to see the differences. As soon as I loaded that up my mind was blown.
5th October 2018, 15:41 | #76 | Link |
my chain is still 32 bit as KODI DS was always more stable in 32 bit, it might be ok now, just havent tried it. I have a look at those test patterns then.
5th October 2018, 15:48 | #77 | Link |
just had a go at MADSHIs test patters. Ran this installer, nothing seemed to happen, opened one of he files with MPC-HC which has MADVR set as renderer, "failed to render", i'm trying this over an RDP connection from work to home, i'll try it again when i get home later.
5th October 2018, 16:07 | #78 | Link |
out of interest, why dont NVIDIA provide 23,976 native like AMD, is this hard coded into the architecture or something, seems really odd they've ignored this for so long, it would surely solve lots of CRU and driver issues?
5th October 2018, 16:18 | #79 | Link | |
For example, you may have an RGB value of R(668) G(668) B(668). This is white to be shown at exactly 400 nits. madVR might tone map this to R(519) G(519) B(519). This is white to be shown at exactly 100 nits. Dynamic tone mapping is supposed to show the 400 nits white as close as possible to 400 nits to reduce compression whenever possible based on the brightness of the scene. Increasing the brightness of any value would destroy the intent of the original HDR grade. So the 100 nits white should also be shown at 100 nits. No HDR content would be graded to 100 nits. I don't know how the display would know to make this brighter. The image only gets darker to preserve detail, never brighter, unless the display is butchering the source. Like I said, some screenshots would be helpful. Many will be confused by your results and probably won't know what to look for.
5th October 2018, 16:26 | #80 | Link | |
Quote: "You can get a slightly wider color gamut when 'Color Gamut' is set to wide, but this isn't recommended for normal content because the colors will be over saturated."
