17th March 2013, 21:54 | #41 | Link |
Wilbert, are all entries in CVS current (or have you updated wiki only on some things).
Will get to the CHM very soon, about to up RT_Stats v1.10 right now.
18th March 2013, 11:07 | #42 | Link | ||
18th March 2013, 11:22 | #43 | Link |
Point of note, the Pictures folder in v2.6a4 setup FilterSDK is still missing (was missing and noted in this thread for 2.6a3)
so will not appear via html docs (I added it from CVS for 2.6a3 CHM). DirectshowSource.htm has been updated since 2.6a4 release on CVS. Shall post here other anomalies as I find them.
18th March 2013, 17:21 | #44 | Link |
Linkchecker (brilliant) as posted previously in this thread has moved to GitHub from SourceForge,
latest version v8.4, homesite here:- http://wummel.github.com/linkchecker/ EDIT: Tip, sort the results by filename/url before you export the html. DirHTML (by Eric Nitzsche, there are several by same title) is updated to v4.871 (portable and setup $ver), http://dirhtml.home.comcast.net/~dirhtml/ Given a directory of files, will create an HTML table of links to those files. We use it in CHM help to create a table pointing to all contained files so that you can visit every file without following link after link, going around and around in circles. Can also point it a directory of eg mp3/mp4 etc files, and it will result in a clickable table of links to those mp3/mp4's (real handy).
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 19th March 2013 at 14:06. |
18th March 2013, 21:36 | #45 | Link |
Is there now no Wavsource.htm in docs. It is referenced in "\advancedtopics\importing_media.htm" ?
here bad local links Code:
bad path (../ missing) and wavsource.htm NOt exist. "\advancedtopics\importing_media.htm" "corefilters/wavsource.htm" "../corefilters/wavsource.htm" "faq_yv12.htm" "corefilters/directshowsource" "corefilters/directshowsource.htm" "imagesource.htm" "imagewriter" "imagewriter.htm" "English/syntax_userdefined_scriptfunctions.htm" "../../../docs/english/syntax_internal_functions_boolean.htm" "syntax_internal_functions_boolean.htm" "English/syntax_userdefined_scriptfunctions.htm" "../../../docs/english/syntax_internal_functions_control.htm" "syntax_internal_functions_control.htm"
19th March 2013, 21:34 | #48 | Link | |
Missing in FilterSDK in avisynth Setup.
"C:\Program Files\AviSynth 2.5\FilterSDK\Pictures" Perhaps yours exists from an earlier version of Avisynth that did install it. EDIT: Have just renamed avisynth dir, and reinstalled, it aint there. It should have "compiling" and "debugging" plugins pics in it. EDIT: below what I wrote in an edit to LigH, earlier in this thread. Quote:
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 19th March 2013 at 21:54. |
19th March 2013, 23:15 | #51 | Link |
How bout wavsource.htm as noted in post #45, I have fixed the other errors in htm's but dont
know what to do about that one for the CHM.
20th March 2013, 20:07 | #53 | Link |
Magic, thanx.
21st March 2013, 14:31 | #54 | Link |
New Version "Avisynth_v2.6.0a4 & FILTERSDK-HELP.chm_20130321.zip" see 1st post (or sig)
Bad local links in Alpha4 FilterSDK docs (fixed in CHM) Code:
file:///C|/Program%20Files/AviSynth%202.5/FilterSDK/TwoFiveFastInvert.htm Below should be 'htm' AviSynthTwoFiveSDK.html IntegerSSE.html TwoFiveInvert.html MMX.html file:///C|/Program%20Files/AviSynth%202.5/FilterSDK/DataStorageInAviSynth.htm "../corefilters/convert.htm" "../Docs/English/corefilters/convert.htm" "../corefilters/layer.htm" "../Docs/English/corefilters/layer.htm" "../corefilters/crop.htm" "../Docs/English/corefilters/crop.htm" "../faq.htm" "../Docs/English/faq.htm" file:///C|/Program%20Files/AviSynth%202.5/FilterSDK/VideoInfo.htm "../../docs/english/corefilters/separatefields.htm" "../Docs/English/corefilters/separatefields.htm" "../../docs/english/corefilters/weave.htm" "../Docs/English/corefilters/weave.htm" EDIT: I just left the unreferenced "syntax_internal_functions_multithreading.htm" in situ. I removed the unreferenced .css files from Docs. Only avisynth.css is used.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 21st March 2013 at 17:10. |
21st March 2013, 15:44 | #56 | Link |
Fixed. You're such a task master!
21st March 2013, 15:55 | #58 | Link |
Yes, there are quite possibly more, I dont look at the bad external links, and Doom9 and the wiki all bar
access to the LinkChecker. (EDIT: Perhaps a D9 username and password would get around that, never tried it) There were only two files added since a3, Echo.htm and Preroll.htm. DirectShowSource.htm was updated on CVS (EDIT: since a4). Doing a decompile into your Avisynth directory should I think fix the links and update DirectShowSource.htm to same as the CHM.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 21st March 2013 at 16:30. |
21st March 2013, 16:20 | #59 | Link |
In CHM Table Of Contents (LHS) when in "Version History/Avisynth 2.6" (English/twopointsix.htm)
when you click on "here" (<a href="corefilters/convert.htm" target="main">here</a>") it brings up convert.htm (internal CHM version) in separate Internet Explorer, no idea why. Not a big problem really. EDIT: In titlebar: mk:@MSITStore:C:\Program%20Files\AVSEdit\help\english.chm::/Docs/english/corefilters/convert.htm Think maybe problem is with "main" window: (engsdk.hhc, CHM contents file) Code:
<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML//EN"> <HTML> <HEAD> <meta name="GENERATOR" content="Microsoft® HTML Help Workshop 4.1"> <!-- Sitemap 1.0 --> </HEAD><BODY> <OBJECT type="text/site properties"> <param name="FrameName" value="right"> <param name="WindowName" value="main"> <param name="Window Styles" value="0x27"> <param name="ImageType" value="Folder"> <param name="Font" value=",8,0"> </OBJECT> Code:
[OPTIONS] Auto Index=Yes Compatibility=1.1 or later Compiled file=engsdk26.chm Contents file=engsdk.hhc Default Window=main Default topic=Docs\english\index.htm Display compile progress=Yes Error log file=engsdk.log Full text search stop list file=engsdk_stoplist.txt Full-text search=Yes Index file=engsdk.hhk Language=0x409 English (United States) Title=Avisynth v2.6a4+ Manual & FilterSDK [WINDOWS] main="Avisynth v2.6a4+ Manual & FilterSDK","engsdk.hhc","engsdk.hhk","Docs\english\index.htm","Docs\english\index.htm",,,,,0x63520,240,0x387e,[0,0,800,600],0x10b0000,,,1,,,0
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 21st March 2013 at 17:35. |
10th October 2013, 22:50 | #60 | Link |
New version Avisynth docs + FilterSDK in CHM format (compressed HTML), see 1st post.
