5th July 2012, 02:08 | #21 | Link |
syntax_internal_functions_multithreading.htm not referenced at all in any help files.
(looks to me like it should not be there at all). syntax_runtime_environment.htm Appears twice in manual, once under Syntax as "Runtime Environment" and also under Scripting Reference as "Scripting at runtime".
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 5th July 2012 at 12:56. |
6th July 2012, 21:31 | #22 | Link |
New Version Avisynth v2.6 Alpha3+ Compressed Help file.
See 1st post
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 6th July 2012 at 23:44. |
7th July 2012, 02:44 | #23 | Link |
Hi StainlessS, Thanks for the updated help files.
Being a noob at AVIsynth, I was reading the help files hoping to learn a few things. SSRC is described as: Performs a high-quality change of the audio sample rate. It uses SSRC by Naoki Shibata, which offers the best resample quality available. Is this really true? StainlessS, I apologize. You are correct, I will open a new thread. Last edited by Reel.Deel; 7th July 2012 at 03:19. |
7th July 2012, 02:54 | #24 | Link |
I think it used to be true, I believe that Avisynth pretty much uses similar conversion to SSRC.
I'm pretty sure someone will be able to answer your question, but not me. I Use SSRC all the time, I think it's just slower than the ResampleAudio (think thats what its called, bit pissed at the moment). Also, SSRC is limited to what sample rates it can deal with (conversion one to the other) whereas ResampleAudio() aint EVER failed for me. EDIT: Cant remember which but I think, eg 32khz converted to either 44.1khz or 48Khz can fail (with SSRC). Also, Can I just suggest that you open a new thread, I myself dont care and will always talk to anyone, nomatter how objectionable, nor how pissed I am. But to be helpfull to others, a related thread title would be good. No offence intended. Open a new one. (Gonna have a few more cans, sleep well my friend).
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 11th October 2013 at 17:20. |
7th July 2012, 03:14 | #25 | Link |
Then my advise is just use Resampleaudio(), it's real good.
Dont know if it's an optimized SSRC or what, but it is good and works very reliably. SSRC fails too frequently, and I could not personally tell the difference.
8th July 2012, 18:51 | #26 | Link |
@Wilbert,
If its not too difficult, would it be possible to put up a current version of Wiki somewhere (zip/rar/7z), without any old edits files and unnecessary stuff included. If so, then I would be willing to have a go at converting to CHM. If size is going to be prohibitive then dont bother (anything greater than about 20MB uncompressed is unlikely to be of much interest to anyone). Ideally, if it could be automated, then I would like to do it in same fashion as the current CHM on Mediafire so that it could easily be updated by anyone with the automated edited site. Thankyou for your time. PS, I've almost done doing the SDK, which I think I will put up included together with English docs but as a single CHM. Also considering writing a simple tool to batch edit htm files to update bad/outdated links and perhaps have a go at doing an HTML help indexer.
8th July 2012, 18:57 | #27 | Link | |
I will look at your other comments at the end of this month when i have some free time. |
8th July 2012, 19:58 | #28 | Link |
Thankyou Wilbert, your answer saves us both some work.
9th July 2012, 15:54 | #29 | Link |
New Version Avisynth v2.6 Alpha3+, & FilterSDK combined Compressed Help file.
See 1st post.
10th July 2012, 06:50 | #30 | Link |
It integrates well into e.g. PSPad. Unfortunately, it does not always directly open the matching detail page because the page title is not always exactly the same as the name of a single function. But at least the matching index is highlighted, so it is just one more enter or doubleclick. |
10th July 2012, 16:23 | #31 | Link |
LigH,
I (sometimes) use PSPad myself, was not aware that it had that capability. Can it be configured to run eg Media Player Home Cinema on a certain key press? If so then I guess I can finally get rid of the intensely annoying AVSEdit. I shall look into your PSPad issue, presume it references the index, if only index needed editing then that could be fixed but would not want to edit all of the topic pages every time (nor even once come to that). By the way, I did manage to get EasyHHK to create a large index by indexing a copy of the HHP project file after removing all non htm files from the [FILES] section, otherwise it tries to eg index jpegs and png's producing all sorts of nonsense. However, the index was so large and full of errors (like "a:link' entry which I think was some kind of HTML parse error). It does not seem to process the stop list properly (I copied contents of project stoplist into EasyHHK's default version). Did you give it a try recreating the manual, If so, was it painless? I did not realize it but there is a copy of FilterSDK in 2.6 source CVS (and without the missing "Pictures" folder and files in alpha3 setup). I should have used that. EDIT: I downloaded and added the missing pics from the Wiki. By the way, think I must have been tired or something when I said that I had found sources for indexing, think they were only for parsing HTML. If I do have a go at writing an indexer, I shall perhaps try AutoIt, think there is bound to be an HTML parsing source on their forum. It's really good and capable language, with many add on libraries, I picked it up in about 1.5 days (in the main), not very different to Basic with 64 bit ints (I think). For the time being, I'm letting go of the CHM stuff, want to get the DGIndex Batcher thing updated to provide eg Aspect Ratio etc and other infos to the created AVS file, also would like to implement AutoCropping and provide field order (unfortunately not provided by DGIndex, only in either Play or Preview), so as to do Deinterlacing. Also want to detect Soft/Hard Pulldown (although I dont usually touch that nasty stuff) and deal with it, if possible. Lots to do. Have a nice one EDIT: None of the CVS FilterSDK doc files have been changed in last 14 months so all should be current (with a few local links fixed).
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 11th July 2012 at 17:25. |
11th July 2012, 07:05 | #32 | Link |
You can add an "AviSynth" highlighter definition, and define an "External application" for this file type, the first of which can be called via F9 (File | Open with program).
The CHM is assigned in the "Specification" tab of the "Highlighter settings". PSPad calls the help viewer with the word closest to the cursor, so it would probably be useful to include all specific function names to the index (e.g. FadeIn[0|2], FadeOut[0|2], FadeIO[0|2] all to the declaration of "Fade"). I did not yet try to rebuild the CHM by myself. Your current result is already quite useful. |
11th July 2012, 12:05 | #33 | Link |
Thankyou, I'll give it a try.
27th February 2013, 05:04 | #36 | Link |
I'll give it a little while for Wilbert to update and then create updated CHM.
14th March 2013, 15:01 | #39 | Link |
I also could not really contribute much to the wiki for the same reasons (also hate writing documentation).
I'll try to get to the CHM thing as soon as I can, currently near an update to RT_Stats, have had a number of hurdles recently including burnt out motherboard, faulty replacement + other things, so have had little free time.
17th March 2013, 18:03 | #40 | Link | ||
