Old 31st July 2010, 12:25   #8961  |  Link
deank
Programmer (or just 教务长)
deank's Avatar
It happened to me a while ago and it is not the x264 that can't recover but avisynth, which at the point of the glitch stops serving frames properly to the end of the movie.
Old 31st July 2010, 12:47   #8962  |  Link
MB2
@jdobbs
It also does it on another PC aswell... :-(
Do you have version 31.08 still? Unexpired?? Be interesting to try it.
EDIT - I still have 31.08 but its expired.
MB2 is offline   Reply With Quote
Old 1st August 2010, 00:59   #8963  |  Link
jfcarbel
Programmer
Added a new hidden option called "KEEP_HD_LPCM". If
set to "0" while also keeping HD audio for BD25, only
DTS and DD HD audio will be kept intact. LPCM will be
converted to AC3. This is meant to help prevent huge
LPCM audio streams from stealing too much space and
negatively affecting video quality. The default value
is "1".
I am confused by this. Wouldn't I want to be able to completely drop the LPCM track and just keep the DTS-MA or TrueHD tracks.
Why even convert it to AC3? Is it just to keep for backward compatibility so that a older laptop or PC can play the audio?
What is the procedure or settings if I always want to keep the English TrueHD or DTS-MA HD Audio but drop all other stuff like LPCM or the additional AC3 core included extra with TrueHD?
jfcarbel is offline   Reply With Quote
Old 1st August 2010, 01:32   #8964  |  Link
jdobbs
I implemented that as a result of a request. Not all discs have DTS-MA or TrueHD as a choice, and they wouldn't necessarily have the same audio content as the LPCM. There are also discs that have only LPCM (like some concert discs). But most importantly the concept is to have a choice to "Keep HD, unless it's LPCM", because LPCM is so wasteful. That way you can set it and forget it. By the way, note that it only applies when you have also selected "Keep HD audio for BD-25".
Of course you can drop it if you want just by deselecting the track.
To keep only the main audio and drop others -- in the SETUP dialog just say to leep only "English" (for example), and also click "Limit to one track for each Language" -- that way it would only keep the first English track.
Website: www.jdobbs.net
Old 1st August 2010, 03:22   #8965  |  Link
jfcarbel
Programmer
Ok, I think I understand. Dracula is a good example. Contains the LPCM for main track but the 2nd track is DD AC3. So I assume if I had the Keep HD Audio checked and the Keep LPCM set to 0, then it would default to the DD track since there is no other HD Audio other then the LPCM. Is that a correct assumption?
Old 1st August 2010, 03:46   #8966  |  Link
jdobbs
Actually, since it is the main track it would reencode the LPCM track to DD 5.1 640Kbs (since it is the main track) and use that. That's a safeguard because the backup tracks are often only DD 2.0. Also, even though it probably isn't true in the case of "Dracula", sometimes the second audio selection includes unwanted audio (like commentary).
Old 1st August 2010, 04:27   #8967  |  Link
SquallMX
Special SeeD
Weird, using version 34.05 produce no secondary video stream if i use the "SECONDARY_USE_QUALITY=1", i get a 0 Kbps .264 file. If i use "SECONDARY_USE_QUALITY=0" everything goes fine. x264 shows a error but the window is closed so fast that I am unable to watch the error text.
Any idea what is happening:
[Options]
RESIZE=0
MODE=0
ENCODE_QUALITY=0
PRIORITY_CLASS=1
TARGET_SIZE=24000
VERBOSE_STATUS=1
AUDIO_TO_KEEP=all
SUBS_TO_KEEP=all
TRELLIS=1
KEEP_INTERLACING=1
COLOR_BOOST=0
RESIZE_1080=0
DTS_REENCODE=0
AC3_REENCODE=0
AC3_640=1
KEEP_HD_AUDIO=0
AVCHD=1
REMOVE_WORKFILES=0
DISABLE_FFMS=0
FIXED_CRF=20
SECONDARY_CRF=20
SHOW_ENCODER=1
AUDIO_TRACK_LIMIT=0
SUBTITLE_TRACK_LIMIT=0
CUSTOM_TARGET_SIZE=24000
QUICK_EXTRAS=0
CRF_ENCODING=0
TWEAK_PASS_ONE=
TWEAK_PASS_TWO=
SD_CONVERT=0
B_PYRAMID=1
ONEPASS_ENCODING=2
FULL_AVCHD=0
AUTO_QUALITY=0
DEINTERLACE=0
AC3_192=0
REMOVE_OUTPUT=0
OPEN_GOP=1
USE_FILTERS=0
MOVIE_ONLY_LOOP=0
[Paths]
SOURCE_PATH=J:\BLU-RAYS\PRINCESSANDTHEFROG\
WORKING_PATH=D:\TEMP\MOVTEMP\D2VAVS\
[22:15:44] BD Rebuilder v0.34.05 (beta)
  - Source:  PRINCESSANDTHEFROG
  - Input BD size: 45.00 GB
  - Approximate total content: [03:43:39.446]
  - Target BD size: 23.44 GB
  - Windows Version: 6.1 [7600]
  - One Pass ABR Mode enabled
  - Audio Settings: AC3=0 DTS=0 HD=0 Kbs=640
[22:15:51] PHASE ONE, Encoding
 - [22:15:51] Extracting A/V streams [VID_00067]
 - [22:15:56] Reencoding: VID_00067 (1 of 132)
 - [22:15:56] Collecting video information
   - Rate/Length: 23.976fps, 1,626 frames
   - Bitrate: 7,573 Kbs
 - [22:15:56] Reencoding: VID_00067, Pass 1 of 1
 - [22:16:56] Video Encode complete
 - [22:16:56] Reencoding audio tracks (if req'd)
 - [22:16:56] Multiplexing M2TS
 - [22:16:59] Extracting A/V streams [VID_00100]
 - [22:17:40] Reencoding: VID_00100 (2 of 132)
 - [22:17:40] Reencoding secondary video [TRK_02]
 - [22:17:40] Collecting video information
   - Rate/Length: 23.976fps, 7,088 frames
   - Bitrate: 12,069 Kbs
 - [22:17:40] Reencoding: VID_00100, Pass 1 of 1
[22:18:12]PHASE ONE aborted by user request
Using CamStudio I was able to capture the error:
SquallMX is offline   Reply With Quote
Old 1st August 2010, 04:59   #8968  |  Link
jdobbs
@SquallMX
I'll check it out. It's possible some change I made screwed up that option.
Old 1st August 2010, 07:38   #8969  |  Link
jfcarbel
Programmer
Actually, since it is the main track it would reencode the LPCM track to DD 5.1 640Kbs (since it is the main track) and use that. )That's a safeguard because the backup tracks are often only DD 2.0. Also, even though it probably isn't true in the case of "Dracula", sometimes the second audio selection includes unwanted audio (like commentary.
Ok, that makes sense. What encoder does BD-Rebuilder use to do its AC-3 encoding?
UPDATE:
Ok, I see in cmd window it uses Aften encoder
Old 1st August 2010, 15:08   #8970  |  Link
jdobbs
@SquallMX
I tested the secondary encoding and it is working fine in both modes for me...
Old 1st August 2010, 15:36   #8971  |  Link
Capsbackup
Originally Posted by Capsbackup View Post
These glitches are on software players only correct? I have experienced this too on TMT3 only, not PowerDVD 7.3 or my S360.
TMT3 will sometimes, and it seems more often than not, also have audio sync issues for me where PowerDVD will not, nor will my S360!
Originally Posted by SquallMX View Post
The PlayStation 3 is also affected.
I don't have a PS3, but it appears the latest update (3.0.1.185) for TMT3 corrects this pixelation issue for me. Arcsoft was apparently aware of this issue, or it at least mentioned it in the patch update fix log.
My latest full backup to BD9 with "Use open GOP for Encoding" does not display any more of these type of errors.
Capsbackup is offline   Reply With Quote
Old 1st August 2010, 16:18   #8972  |  Link
worknstiff
Wondering About Audio Sync
Thanks, deanK, I'll take a look at it. Strange, though, that the value would change from the original. Sometimes in multi-part playlists you can have a repeated audio packet in two adjoining M2TS files when the connection_condition is right. Maybe it's possible that one of the removed audio streams had this condition and resulted in a very small shortening.
Interesting if nothing else.
While attempting to do a Movie Only Rebuild of Clash of Titans, I noticed it has 7 .m2ts streams that BD_Rebuilder will combine into a (1:46.07.569) runtime. If I use Clown_BD to preprocess it into a blueray it shows a runtime of (1:46.07.562 ) when I use it in BD_Rebuilder. This is after eac3to corrects audio overlaps of anywhere from 5 to 12 miliseconds for each m2ts piece. Does BD_Rebuilder fix the audio overlaps or what accounts for the difference between the 2 runtimes? A difference extremely small but a difference none the less.
worknstiff is offline   Reply With Quote
Old 1st August 2010, 17:02   #8973  |  Link
hedgerow
Hi when trying to do Clash of the Titans (2010) i get the following error
[19:42:00] BD Rebuilder v0.34.05 (beta)
  - Source:  CLASH_OF_THE_TITANS
  - Input BD size: 38.98 GB
  - Approximate total content: [03:51:38.175]
  - Target BD size: 22.90 GB
  - Quality:
  - Audio Settings: AC3=1 DTS=1 HD=1 Kbs=640
[19:42:06] PHASE ONE, Encoding
 - [19:42:06] Extracting A/V streams [VID_00019]
 - [19:42:09] Reencoding: VID_00019 (1 of 34)
 - [19:42:09] Collecting video information
   - Source Video: VC-1, 1920x1080
   - Rate/Length: 23.976fps, 3,309 frames
 - [19:42:09] Reencoding: VID_00019, Pass 1 of 1
 - [19:43:09] Video Encode complete
 - [19:43:09] Reencoding audio tracks (if req'd)
 - [19:43:09] Multiplexing M2TS
 - [19:43:12] Extracting A/V streams [VID_00023]
 - [19:43:16] Reencoding: VID_00023 (2 of 34)
 - [19:43:16] Collecting video information
   - Rate/Length: 23.976fps, 3,637 frames
 - [19:43:16] Reencoding: VID_00023, Pass 1 of 1
 - [19:44:29] Video Encode complete
 - [19:44:29] Reencoding audio tracks (if req'd)
 - [19:44:29] Multiplexing M2TS
 - [19:44:33] Extracting A/V streams [VID_00018]
 - [19:44:39] Reencoding: VID_00018 (3 of 34)
 - [19:44:39] Collecting video information
   - Rate/Length: 23.976fps, 4,243 frames
 - [19:44:39] Reencoding: VID_00018, Pass 1 of 1
 - [19:46:11] Video Encode complete
 - [19:46:11] Reencoding audio tracks (if req'd)
 - [19:46:11] Multiplexing M2TS
 - [19:46:14] Extracting A/V streams [VID_00024]
 - [19:46:19] Reencoding: VID_00024 (4 of 34)
 - [19:46:19] Collecting video information
   - Rate/Length: 23.976fps, 5,034 frames
 - [19:46:19] Reencoding: VID_00024, Pass 1 of 1
 - [19:48:06] Video Encode complete
 - [19:48:06] Reencoding audio tracks (if req'd)
 - [19:48:06] Multiplexing M2TS
 - [19:48:10] Extracting A/V streams [VID_00046]
 - [19:48:17] Reencoding: VID_00046 (5 of 34)
 - [19:48:17] Reencoding secondary video [TRK_02]
 - [19:48:32] Collecting video information
   - Rate/Length: 23.976fps, 3,279 frames
 - [19:48:32] Reencoding: VID_00046, Pass 1 of 1
 - [19:50:02] Video Encode complete
 - [19:50:02] Reencoding audio tracks (if req'd)
 - [19:50:02] Multiplexing M2TS
 - [19:50:05] Extracting A/V streams [VID_00016]
 - [19:50:10] Reencoding: VID_00016 (6 of 34)
 - [19:50:10] Collecting video information
   - Rate/Length: 23.976fps, 5,354 frames
 - [19:50:10] Reencoding: VID_00016, Pass 1 of 1
 - [19:52:07] Video Encode complete
 - [19:52:07] Reencoding audio tracks (if req'd)
 - [19:52:07] Multiplexing M2TS
 - [19:52:12] Extracting A/V streams [VID_00022]
 - [19:52:17] Reencoding: VID_00022 (7 of 34)
 - [19:52:17] Collecting video information
   - Rate/Length: 23.976fps, 5,477 frames
 - [19:52:17] Reencoding: VID_00022, Pass 1 of 1
 - [19:54:19] Video Encode complete
 - [19:54:19] Reencoding audio tracks (if req'd)
 - [19:54:19] Multiplexing M2TS
 - [19:54:24] Extracting A/V streams [VID_00009]
 - [19:54:29] Reencoding: VID_00009 (8 of 34)
 - [19:54:29] Collecting video information
   - Rate/Length: 23.976fps, 5,453 frames
 - [19:54:29] Reencoding: VID_00009, Pass 1 of 1
 - [19:56:26] Video Encode complete
 - [19:56:26] Reencoding audio tracks (if req'd)
 - [19:56:26] Multiplexing M2TS
 - [19:56:31] Extracting A/V streams [VID_00036]
 - [19:56:38] Reencoding: VID_00036 (9 of 34)
 - [19:56:38] Reencoding secondary video [TRK_02]
 - [19:56:52] Collecting video information
   - Bitrate: 8,619 Kbs
 - [19:56:52] Reencoding: VID_00036, Pass 1 of 2
 - [19:58:52] Reencoding: VID_00036, Pass 2 of 2
 - [20:03:50] Video Encode complete
 - [20:03:50] Reencoding audio tracks (if req'd)
 - [20:03:50] Multiplexing M2TS
 - [20:03:55] Extracting A/V streams [VID_00017]
 - [20:04:01] Reencoding: VID_00017 (10 of 34)
 - [20:04:01] Collecting video information
   - Rate/Length: 23.976fps, 5,642 frames
 - [20:04:01] Reencoding: VID_00017, Pass 1 of 1
 - [20:05:43] Video Encode complete
 - [20:05:43] Reencoding audio tracks (if req'd)
 - [20:05:43] Multiplexing M2TS
 - [20:05:48] Extracting A/V streams [VID_00021]
 - [20:05:54] Reencoding: VID_00021 (11 of 34)
 - [20:05:54] Collecting video information
   - Rate/Length: 23.976fps, 5,911 frames
 - [20:05:54] Reencoding: VID_00021, Pass 1 of 1
 - [20:07:54] Video Encode complete
 - [20:07:54] Reencoding audio tracks (if req'd)
 - [20:07:54] Multiplexing M2TS
 - [20:07:59] Extracting A/V streams [VID_00020]
 - [20:08:07] Reencoding: VID_00020 (12 of 34)
 - [20:08:07] Collecting video information
   - Rate/Length: 23.976fps, 6,350 frames
 - [20:08:07] Reencoding: VID_00020, Pass 1 of 1
 - [20:10:27] Video Encode complete
 - [20:10:27] Reencoding audio tracks (if req'd)
 - [20:10:27] Multiplexing M2TS
 - [20:10:32] Extracting A/V streams [VID_00038]
 - [20:10:39] Reencoding: VID_00038 (13 of 34)
 - [20:10:39] Collecting video information
   - Rate/Length: 23.976fps, 7,749 frames
 - [20:10:39] Reencoding: VID_00038, Pass 1 of 1
 - [20:13:21] Video Encode complete
 - [20:13:21] Reencoding audio tracks (if req'd)
 - [20:13:21] Multiplexing M2TS
 - [20:13:25] Extracting A/V streams [VID_00025]
 - [20:13:36] Reencoding: VID_00025 (14 of 34)
 - [20:13:36] Reencoding secondary video [TRK_02]
 - [20:14:02] Collecting video information
   - Rate/Length: 23.976fps, 4,064 frames
   - Bitrate: 16,329 Kbs
 - [20:14:02] Reencoding: VID_00025, Pass 1 of 2
 - [20:16:52] Reencoding: VID_00025, Pass 2 of 2
 - [20:26:19] Video Encode complete
 - [20:26:19] Reencoding audio tracks (if req'd)
 - [20:26:19] Multiplexing M2TS
 - [20:26:26] Extracting A/V streams [VID_00043]
 - [20:26:37] Reencoding: VID_00043 (15 of 34)
 - [20:26:37] Reencoding secondary video [TRK_02]
 - [20:27:03] Collecting video information
   - Rate/Length: 23.976fps, 6,018 frames
 - [20:27:03] Reencoding: VID_00043, Pass 1 of 1
 - [20:29:32] Video Encode complete
 - [20:29:33] Reencoding audio tracks (if req'd)
 - [20:29:33] Multiplexing M2TS
 - [20:29:37] Extracting A/V streams [VID_00033]
 - [20:29:48] Reencoding: VID_00033 (16 of 34)
 - [20:29:48] Reencoding secondary video [TRK_02]
 - [20:30:03] Collecting video information
   - Rate/Length: 23.976fps, 3,981 frames
   - Bitrate: 18,350 Kbs
 - [20:30:03] Reencoding: VID_00033, Pass 1 of 2
 - [20:32:24] Reencoding: VID_00033, Pass 2 of 2
 - [20:40:58] Video Encode complete
 - [20:40:58] Reencoding audio tracks (if req'd)
 - [20:40:58] Multiplexing M2TS
 - [20:41:05] Extracting A/V streams [VID_00040]
 - [20:41:15] Reencoding: VID_00040 (17 of 34)
 - [20:41:15] Reencoding secondary video [TRK_02]
 - [20:41:35] Collecting video information
   - Rate/Length: 23.976fps, 6,112 frames
 - [20:41:35] Reencoding: VID_00040, Pass 1 of 1
 - [20:43:55] Video Encode complete
 - [20:43:55] Reencoding audio tracks (if req'd)
 - [20:43:55] Multiplexing M2TS
 - [20:43:57] Extracting A/V streams [VID_00035]
 - [20:44:08] Reencoding: VID_00035 (18 of 34)
 - [20:44:08] Reencoding secondary video [TRK_02]
 - [20:44:33] Collecting video information
   - Rate/Length: 23.976fps, 4,759 frames
   - Bitrate: 11,937 Kbs
 - [20:44:33] Reencoding: VID_00035, Pass 1 of 2
 - [20:47:11] Reencoding: VID_00035, Pass 2 of 2
 - [20:55:32] Video Encode complete
 - [20:55:32] Reencoding audio tracks (if req'd)
 - [20:55:32] Multiplexing M2TS
 - [20:55:40] Extracting A/V streams [VID_00045]
 - [20:55:52] Reencoding: VID_00045 (19 of 34)
 - [20:55:52] Reencoding secondary video [TRK_02]
 - [20:56:14] Collecting video information
   - Rate/Length: 23.976fps, 6,729 frames
 - [20:56:14] Reencoding: VID_00045, Pass 1 of 1
 - [20:58:41] Video Encode complete
 - [20:58:41] Reencoding audio tracks (if req'd)
 - [20:58:41] Multiplexing M2TS
 - [20:58:46] Extracting A/V streams [VID_00047]
 - [20:58:56] Reencoding: VID_00047 (20 of 34)
 - [20:58:56] Collecting video information
   - Rate/Length: 23.976fps, 11,416 frames
 - [20:58:56] Reencoding: VID_00047, Pass 1 of 1
 - [21:02:26] Video Encode complete
 - [21:02:26] Reencoding audio tracks (if req'd)
 - [21:02:26] Multiplexing M2TS
 - [21:02:36] Extracting A/V streams [VID_00029]
 - [21:02:48] Reencoding: VID_00029 (21 of 34)
 - [21:02:48] Reencoding secondary video [TRK_02]
 - [21:03:13] Collecting video information
   - Rate/Length: 23.976fps, 5,794 frames
   - Bitrate: 15,102 Kbs
 - [21:03:13] Reencoding: VID_00029, Pass 1 of 2
 - [21:06:28] Reencoding: VID_00029, Pass 2 of 2
 - [21:16:51] Video Encode complete
 - [21:16:51] Reencoding audio tracks (if req'd)
 - [21:16:51] Multiplexing M2TS
 - [21:16:59] Extracting A/V streams [VID_00030]
 - [21:17:11] Reencoding: VID_00030 (22 of 34)
 - [21:17:11] Reencoding secondary video [TRK_02]
 - [21:17:32] Collecting video information
   - Bitrate: 15,550 Kbs
 - [21:17:32] Reencoding: VID_00030, Pass 1 of 2
 - [21:20:56] Reencoding: VID_00030, Pass 2 of 2
 - [21:31:46] Video Encode complete
 - [21:31:46] Reencoding audio tracks (if req'd)
 - [21:31:46] Multiplexing M2TS
 - [21:31:54] Extracting A/V streams [VID_00037]
 - [21:32:07] Reencoding: VID_00037 (23 of 34)
 - [21:32:07] Reencoding secondary video [TRK_02]
 - [21:32:57] Collecting video information
   - Rate/Length: 23.976fps, 14,961 frames
   - Bitrate: 2,600 Kbs
 - [21:32:57] Reencoding: VID_00037, Pass 1 of 2
 - [21:37:24] Reencoding: VID_00037, Pass 2 of 2
 - [21:44:03] Video Encode complete
 - [21:44:03] Reencoding audio tracks (if req'd)
 - [21:44:03] Multiplexing M2TS
 - [21:44:18] Extracting A/V streams [VID_00001]
 - [21:44:32] Reencoding: VID_00001 (24 of 34)
 - [21:44:32] Reencoding secondary video [TRK_02]
 - [21:44:53] Collecting video information
   - Rate/Length: 23.976fps, 6,111 frames
   - Bitrate: 17,374 Kbs
 - [21:44:53] Reencoding: VID_00001, Pass 1 of 2
 - [21:48:25] Reencoding: VID_00001, Pass 2 of 2
 - [22:00:26] Video Encode complete
 - [22:00:26] Reencoding audio tracks (if req'd)
 - [22:00:26] Multiplexing M2TS
 - [22:00:35] Extracting A/V streams [VID_00034]
 - [22:00:50] Reencoding: VID_00034 (25 of 34)
 - [22:00:50] Reencoding secondary video [TRK_02]
 - [22:01:10] Collecting video information
   - Rate/Length: 23.976fps, 6,032 frames
   - Bitrate: 19,096 Kbs
 - [22:01:10] Reencoding: VID_00034, Pass 1 of 2
 - [22:04:37] Reencoding: VID_00034, Pass 2 of 2
 - [22:18:27] Video Encode complete
 - [22:18:27] Reencoding audio tracks (if req'd)
 - [22:18:27] Multiplexing M2TS
 - [22:18:37] Extracting A/V streams [VID_00031]
 - [22:18:54] Reencoding: VID_00031 (26 of 34)
 - [22:18:54] Reencoding secondary video [TRK_02]
 - [22:19:39] Collecting video information
   - Rate/Length: 23.976fps, 9,129 frames
   - Bitrate: 15,779 Kbs
 - [22:19:39] Reencoding: VID_00031, Pass 1 of 2
 - [22:24:48] Reencoding: VID_00031, Pass 2 of 2
 - [22:41:33] Video Encode complete
 - [22:41:33] Reencoding audio tracks (if req'd)
 - [22:41:33] Multiplexing M2TS
 - [22:41:45] Extracting A/V streams [VID_00041]
 - [22:42:08] Reencoding: VID_00041 (27 of 34)
 - [22:42:08] Reencoding secondary video [TRK_02]
 - [22:42:59] Collecting video information
   - Rate/Length: 23.976fps, 14,937 frames
   - Bitrate: 12,705 Kbs
 - [22:42:59] Reencoding: VID_00041, Pass 1 of 2
 - [22:50:52] Reencoding: VID_00041, Pass 2 of 2
 - [23:15:08] Video Encode complete
 - [23:15:08] Reencoding audio tracks (if req'd)
 - [23:15:08] Multiplexing M2TS
 - [23:15:22] Extracting A/V streams [VID_00048]
 - [23:15:44] Reencoding: VID_00048 (28 of 34)
 - [23:15:44] Collecting video information
   - Rate/Length: 23.976fps, 26,153 frames
   - Bitrate: 8,018 Kbs
 - [23:15:44] Reencoding: VID_00048, Pass 1 of 2
 - [23:29:38] Reencoding: VID_00048, Pass 2 of 2
 - [00:05:08] Video Encode complete
 - [00:05:08] Reencoding audio tracks (if req'd)
 - [00:05:08] Multiplexing M2TS
 - [00:05:23] Extracting A/V streams [VID_00026]
 - [00:05:51] Reencoding: VID_00026 (29 of 34)
 - [00:05:51] Reencoding secondary video [TRK_02]
 - [00:06:43] Collecting video information
   - Bitrate: 15,271 Kbs
 - [00:06:43] Reencoding: VID_00026, Pass 1 of 2
 - [00:15:13] Reencoding: VID_00026, Pass 2 of 2
 - [00:42:18] Video Encode complete
 - [00:42:18] Reencoding audio tracks (if req'd)
 - [00:42:18] Multiplexing M2TS
 - [00:42:46] Extracting A/V streams [VID_00042]
 - [00:43:17] Reencoding: VID_00042 (30 of 34)
 - [00:43:17] Reencoding secondary video [TRK_02]
 - [00:44:25] Collecting video information
   - Rate/Length: 23.976fps, 19,885 frames
   - Bitrate: 12,680 Kbs
 - [00:44:25] Reencoding: VID_00042, Pass 1 of 2
 - [00:55:00] Reencoding: VID_00042, Pass 2 of 2
 - [01:26:52] Video Encode complete
 - [01:26:52] Reencoding audio tracks (if req'd)
 - [01:26:52] Multiplexing M2TS
 - [01:27:13] Extracting A/V streams [VID_00028]
 - [01:27:49] Reencoding: VID_00028 (31 of 34)
 - [01:27:49] Reencoding secondary video [TRK_02]
 - [01:28:54] Collecting video information
   - Rate/Length: 23.976fps, 17,937 frames
   - Bitrate: 16,804 Kbs
 - [01:28:54] Reencoding: VID_00028, Pass 1 of 2
 - [01:38:55] Reencoding: VID_00028, Pass 2 of 2
 - [02:12:29] Video Encode complete
 - [02:12:29] Reencoding audio tracks (if req'd)
 - [02:12:29] Multiplexing M2TS
 - [02:12:51] Extracting A/V streams [VID_00044]
 - [02:13:34] Reencoding: VID_00044 (32 of 34)
 - [02:13:34] Reencoding secondary video [TRK_02]
 - [02:15:09] Collecting video information
   - Rate/Length: 23.976fps, 27,866 frames
   - Bitrate: 12,625 Kbs
 - [02:15:09] Reencoding: VID_00044, Pass 1 of 2
 - [02:29:59] Reencoding: VID_00044, Pass 2 of 2
 - [03:17:15] Video Encode complete
 - [03:17:15] Reencoding audio tracks (if req'd)
 - [03:17:15] Multiplexing M2TS
 - Error in attempt to multiplex: MUX_00044.meta
 - Can't open file: D:\2\WORKFILES\00044.track_6656.DTS
[03:17:16] - Failed to build structure, aborted
- AVISYNTH Version: 2.5.7.0, Ok
- HAALI Splitter:  Ok
- FFDSHOW: 3326, Ok
- WIN7 preferred AVC CODEC:  Ok
- WIN7 preferred VC-1 CODEC:  Ok
- WIN7 preferred MPEG2 CODEC:  Ok
- FFDSHOW VC-1 set to "wmv9", Ok
- FFDSHOW MPEG2 set to "libavcodec":  Ok
- FFDSHOW AVC set to "libavcodec":  Ok
- BD Rebuilder v0.34.0.5, Ok
- X264:  Ok
- AFTEN:  Ok
- FAAC:  Ok
- MP4BOX:  Ok
- WAVI:  Ok
- TSMUXER:  Ok
i am now going to try with 34.04
any help appreciated
p.s i tried twice same error ripped with anydvdHD 6.6.8.0
hedgerow is offline   Reply With Quote
Old 1st August 2010, 17:12   #8974  |  Link
Ch3vr0n
Ok jdobbs, if got a mystery for ya. First "problem" ever. The problem is simple. Disc recoded successfully into an ISO and has a dual feature. The same movie in theatrical and extended version. In both the panasonic BD60 & BD85 at the screen where you have to select wich version, the problem begins. After you select wich one you like to watch, the angles start to loop that show the copyright notice etc, over and over again. However in PowerDVD after i select the version, the movie starts as it should, in BOTH cases. Don't know if it matter but the disc does not contain java.
I've got no idea why the standalone's don't play it but powerdvd 10 does
[20:50:41] BD Rebuilder v0.34.05 (beta)
  - Source:  ALIEN_VS_PREDATOR_F2
  - Input BD size: 30,77 GB
  - Approximate total content: [02:06:39.007]
  - Target BD size: 22,66 GB
  - Windows Version: 6.0 [6002]
  - Quality:
[20:50:44] PHASE ONE, Encoding
 - [20:50:44] Extracting A/V streams [VID_00000]
 - [20:50:58] Reencoding: VID_00000 (1 of 40)
 - [20:50:58] Collecting video information
   - Source Video: MPEG-2, 1920x1080
   - Rate/Length: 23,976fps, 3.407 frames
   - Bitrate: 15.091 Kbs
 - [20:50:58] Reencoding: VID_00000, Pass 1 of 2
 - [20:52:44] Reencoding: VID_00000, Pass 2 of 2
 - [20:58:34] Video Encode complete
 - [20:58:34] Reencoding audio tracks (if req'd)
 - [20:58:34] Multiplexing M2TS
 - [20:58:44] Extracting A/V streams [VID_00001]
 - [20:59:00] Reencoding: VID_00001 (2 of 40)
 - [20:59:00] Collecting video information
   - Rate/Length: 23,976fps, 5.903 frames
   - Bitrate: 14.690 Kbs
 - [20:59:00] Reencoding: VID_00001, Pass 1 of 2
 - [21:01:56] Reencoding: VID_00001, Pass 2 of 2
 - [21:12:01] Video Encode complete
 - [21:12:01] Reencoding audio tracks (if req'd)
 - [21:12:01] Multiplexing M2TS
 - [21:12:20] Extracting A/V streams [VID_00002]
 - [21:12:32] Reencoding: VID_00002 (3 of 40)
 - [21:12:32] Collecting video information
   - Rate/Length: 23,976fps, 2.440 frames
   - Bitrate: 20.510 Kbs
 - [21:12:32] Reencoding: VID_00002, Pass 1 of 2
 - [21:14:03] Reencoding: VID_00002, Pass 2 of 2
 - [21:19:26] Video Encode complete
 - [21:19:26] Reencoding audio tracks (if req'd)
 - [21:19:26] Multiplexing M2TS
 - [21:19:36] Extracting A/V streams [VID_00003]
 - [21:19:41] Reencoding: VID_00003 (4 of 40)
 - [21:19:41] Collecting video information
   - Rate/Length: 23,976fps, 1.060 frames
   - Bitrate: 20.160 Kbs
 - [21:19:41] Reencoding: VID_00003, Pass 1 of 2
 - [21:25:31] Reencoding: VID_00003, Pass 2 of 2
 - [21:27:42] Video Encode complete
 - [21:27:42] Reencoding audio tracks (if req'd)
 - [21:27:42] Multiplexing M2TS
 - [21:27:47] Extracting A/V streams [VID_00004]
 - [21:27:53] Reencoding: VID_00004 (5 of 40)
 - [21:27:53] Collecting video information
   - Rate/Length: 23,976fps, 1.406 frames
   - Bitrate: 19.633 Kbs
 - [21:27:53] Reencoding: VID_00004, Pass 1 of 2
 - [21:28:47] Reencoding: VID_00004, Pass 2 of 2
 - [21:31:41] Video Encode complete
 - [21:31:41] Reencoding audio tracks (if req'd)
 - [21:31:41] Multiplexing M2TS
 - [21:31:46] Extracting A/V streams [VID_00005]
 - [21:31:57] Reencoding: VID_00005 (6 of 40)
 - [21:31:57] Collecting video information
   - Rate/Length: 23,976fps, 2.626 frames
   - Bitrate: 20.025 Kbs
 - [21:31:57] Reencoding: VID_00005, Pass 1 of 2
 - [21:33:32] Reencoding: VID_00005, Pass 2 of 2
 - [21:39:27] Video Encode complete
 - [21:39:27] Reencoding audio tracks (if req'd)
 - [21:39:27] Multiplexing M2TS
 - [21:39:36] Extracting A/V streams [VID_00006]
 - [21:39:40] Reencoding: VID_00006 (7 of 40)
 - [21:39:40] Collecting video information
   - Rate/Length: 23,976fps, 737 frames
   - Bitrate: 17.350 Kbs
 - [21:39:40] Reencoding: VID_00006, Pass 1 of 2
 - [21:40:07] Reencoding: VID_00006, Pass 2 of 2
 - [21:41:34] Video Encode complete
 - [21:41:34] Reencoding audio tracks (if req'd)
 - [21:41:34] Multiplexing M2TS
 - [21:41:38] Extracting A/V streams [VID_00007]
 - [21:41:45] Reencoding: VID_00007 (8 of 40)
 - [21:41:45] Collecting video information
   - Rate/Length: 23,976fps, 2.204 frames
   - Bitrate: 16.227 Kbs
 - [21:41:45] Reencoding: VID_00007, Pass 1 of 2
 - [21:43:02] Reencoding: VID_00007, Pass 2 of 2
 - [21:47:14] Video Encode complete
 - [21:47:14] Reencoding audio tracks (if req'd)
 - [21:47:14] Multiplexing M2TS
 - [21:47:22] Extracting A/V streams [VID_00008]
 - [21:49:31] Reencoding: VID_00008 (9 of 40)
 - [21:49:31] Collecting video information
   - Rate/Length: 23,976fps, 34.491 frames
   - Bitrate: 20.090 Kbs
 - [21:49:31] Reencoding: VID_00008, Pass 1 of 2
 - [22:08:07] Reencoding: VID_00008, Pass 2 of 2
 - [23:24:48] Video Encode complete
 - [23:24:48] Reencoding audio tracks (if req'd)
 - [23:24:48] Multiplexing M2TS
 - [23:28:23] Extracting A/V streams [VID_00011]
 - [23:28:25] Reencoding: VID_00011 (10 of 40)
 - [23:28:25] Collecting video information
   - Rate/Length: 23,976fps, 740 frames
   - Bitrate: 18.027 Kbs
 - [23:28:25] Reencoding: VID_00011, Pass 1 of 2
 - [23:28:52] Reencoding: VID_00011, Pass 2 of 2
 - [23:30:31] Video Encode complete
 - [23:30:31] Reencoding audio tracks (if req'd)
 - [23:30:31] Multiplexing M2TS
 - [23:30:35] Extracting A/V streams [VID_00012]
 - [23:30:38] Reencoding: VID_00012 (11 of 40)
 - [23:30:38] Collecting video information
   - Rate/Length: 23,976fps, 766 frames
   - Bitrate: 18.202 Kbs
 - [23:30:38] Reencoding: VID_00012, Pass 1 of 2
 - [23:31:04] Reencoding: VID_00012, Pass 2 of 2
 - [23:32:45] Video Encode complete
 - [23:32:45] Reencoding audio tracks (if req'd)
 - [23:32:45] Multiplexing M2TS
 - [23:32:47] Extracting A/V streams [VID_00013]
 - [23:33:04] Reencoding: VID_00013 (12 of 40)
 - [23:33:04] Collecting video information
   - Rate/Length: 23,976fps, 3.753 frames
   - Bitrate: 20.743 Kbs
 - [23:33:04] Reencoding: VID_00013, Pass 1 of 2
 - [23:35:10] Reencoding: VID_00013, Pass 2 of 2
 - [23:43:47] Video Encode complete
 - [23:43:47] Reencoding audio tracks (if req'd)
 - [23:43:47] Multiplexing M2TS
 - [23:44:14] Extracting A/V streams [VID_00015]
 - [23:44:25] Reencoding: VID_00015 (13 of 40)
 - [23:44:25] Collecting video information
   - Rate/Length: 23,976fps, 2.492 frames
   - Bitrate: 21.325 Kbs
 - [23:44:25] Reencoding: VID_00015, Pass 1 of 2
 - [23:45:50] Reencoding: VID_00015, Pass 2 of 2
 - [23:51:31] Video Encode complete
 - [23:51:31] Reencoding audio tracks (if req'd)
 - [23:51:31] Multiplexing M2TS
 - [23:51:46] Extracting A/V streams [VID_00016]
 - [23:51:58] Reencoding: VID_00016 (14 of 40)
 - [23:51:58] Collecting video information
   - Rate/Length: 23,976fps, 2.999 frames
   - Bitrate: 19.209 Kbs
 - [23:51:58] Reencoding: VID_00016, Pass 1 of 2
 - [23:53:45] Reencoding: VID_00016, Pass 2 of 2
 - [00:00:12] Video Encode complete
 - [00:00:12] Reencoding audio tracks (if req'd)
 - [00:00:12] Multiplexing M2TS
 - [00:00:26] Extracting A/V streams [VID_00017]
 - [00:00:29] Reencoding: VID_00017 (15 of 40)
 - [00:00:29] Collecting video information
   - Rate/Length: 23,976fps, 476 frames
   - Bitrate: 17.693 Kbs
 - [00:00:29] Reencoding: VID_00017, Pass 1 of 2
 - [00:00:46] Reencoding: VID_00017, Pass 2 of 2
 - [00:01:46] Video Encode complete
 - [00:01:46] Reencoding audio tracks (if req'd)
 - [00:01:46] Multiplexing M2TS
 - [00:01:48] Extracting A/V streams [VID_00018]
 - [00:01:50] Reencoding: VID_00018 (16 of 40)
 - [00:01:50] Collecting video information
   - Rate/Length: 23,976fps, 515 frames
   - Bitrate: 17.027 Kbs
 - [00:01:50] Reencoding: VID_00018, Pass 1 of 2
 - [00:02:08] Reencoding: VID_00018, Pass 2 of 2
 - [00:03:09] Video Encode complete
 - [00:03:09] Reencoding audio tracks (if req'd)
 - [00:03:09] Multiplexing M2TS
 - [00:03:11] Extracting A/V streams [VID_00019]
 - [00:03:52] Reencoding: VID_00019 (17 of 40)
 - [00:03:52] Collecting video information
   - Rate/Length: 23,976fps, 10.770 frames
   - Bitrate: 20.284 Kbs
 - [00:03:52] Reencoding: VID_00019, Pass 1 of 2
 - [00:09:38] Reencoding: VID_00019, Pass 2 of 2
 - [00:34:43] Video Encode complete
 - [00:34:43] Reencoding audio tracks (if req'd)
 - [00:34:43] Multiplexing M2TS
 - [00:35:42] Extracting A/V streams [VID_00020]
 - [00:35:46] Reencoding: VID_00020 (18 of 40)
 - [00:35:46] Collecting video information
   - Rate/Length: 23,976fps, 964 frames
   - Bitrate: 18.869 Kbs
 - [00:35:46] Reencoding: VID_00020, Pass 1 of 2
 - [00:36:16] Reencoding: VID_00020, Pass 2 of 2
 - [00:38:22] Video Encode complete
 - [00:38:22] Reencoding audio tracks (if req'd)
 - [00:38:22] Multiplexing M2TS
 - [00:38:26] Extracting A/V streams [VID_00021]
 - [00:38:31] Reencoding: VID_00021 (19 of 40)
 - [00:38:31] Collecting video information
   - Rate/Length: 23,976fps, 1.322 frames
   - Bitrate: 18.045 Kbs
 - [00:38:31] Reencoding: VID_00021, Pass 1 of 2
 - [00:39:11] Reencoding: VID_00021, Pass 2 of 2
 - [00:41:57] Video Encode complete
 - [00:41:57] Reencoding audio tracks (if req'd)
 - [00:41:57] Multiplexing M2TS
 - [00:42:01] Extracting A/V streams [VID_00022]
 - [00:42:16] Reencoding: VID_00022 (20 of 40)
 - [00:42:16] Collecting video information
   - Rate/Length: 23,976fps, 3.266 frames
   - Bitrate: 22.077 Kbs
 - [00:42:16] Reencoding: VID_00022, Pass 1 of 2
 - [00:43:55] Reencoding: VID_00022, Pass 2 of 2
 - [00:51:20] Video Encode complete
 - [00:51:20] Reencoding audio tracks (if req'd)
 - [00:51:20] Multiplexing M2TS
 - [00:51:34] Extracting A/V streams [VID_00023]
 - [00:51:46] Reencoding: VID_00023 (21 of 40)
 - [00:51:46] Collecting video information
   - Rate/Length: 23,976fps, 2.716 frames
   - Bitrate: 19.398 Kbs
 - [00:51:46] Reencoding: VID_00023, Pass 1 of 2
 - [00:53:08] Reencoding: VID_00023, Pass 2 of 2
 - [00:59:00] Video Encode complete
 - [00:59:00] Reencoding audio tracks (if req'd)
 - [00:59:00] Multiplexing M2TS
 - [00:59:10] Extracting A/V streams [VID_00024]
 - [00:59:25] Reencoding: VID_00024 (22 of 40)
 - [00:59:25] Collecting video information
   - Rate/Length: 23,976fps, 4.776 frames
   - Bitrate: 17.405 Kbs
 - [00:59:25] Reencoding: VID_00024, Pass 1 of 2
 - [01:01:50] Reencoding: VID_00024, Pass 2 of 2
 - [01:11:48] Video Encode complete
 - [01:11:48] Reencoding audio tracks (if req'd)
 - [01:11:48] Multiplexing M2TS
 - [01:12:04] Extracting A/V streams [VID_00025]
 - [01:12:25] Reencoding: VID_00025 (23 of 40)
 - [01:12:25] Collecting video information
   - Rate/Length: 23,976fps, 5.121 frames
   - Bitrate: 20.534 Kbs
 - [01:12:25] Reencoding: VID_00025, Pass 1 of 2
 - [01:15:06] Reencoding: VID_00025, Pass 2 of 2
 - [01:26:56] Video Encode complete
 - [01:26:56] Reencoding audio tracks (if req'd)
 - [01:26:56] Multiplexing M2TS
 - [01:27:17] Extracting A/V streams [VID_00026]
 - [01:27:23] Reencoding: VID_00026 (24 of 40)
 - [01:27:23] Collecting video information
   - Rate/Length: 23,976fps, 1.812 frames
   - Bitrate: 19.931 Kbs
 - [01:27:24] Reencoding: VID_00026, Pass 1 of 2
 - [01:28:27] Reencoding: VID_00026, Pass 2 of 2
 - [01:32:36] Video Encode complete
 - [01:32:36] Reencoding audio tracks (if req'd)
 - [01:32:36] Multiplexing M2TS
 - [01:32:43] Extracting A/V streams [VID_00027]
 - [01:32:51] Reencoding: VID_00027 (25 of 40)
 - [01:32:51] Collecting video information
   - Rate/Length: 23,976fps, 1.836 frames
   - Bitrate: 19.684 Kbs
 - [01:32:51] Reencoding: VID_00027, Pass 1 of 2
 - [01:33:55] Reencoding: VID_00027, Pass 2 of 2
 - [01:37:53] Video Encode complete
 - [01:37:53] Reencoding audio tracks (if req'd)
 - [01:37:53] Multiplexing M2TS
 - [01:38:01] Extracting A/V streams [VID_00028]
 - [01:38:25] Reencoding: VID_00028 (26 of 40)
 - [01:38:25] Collecting video information
   - Rate/Length: 23,976fps, 6.364 frames
   - Bitrate: 21.029 Kbs
 - [01:38:25] Reencoding: VID_00028, Pass 1 of 2
 - [01:41:44] Reencoding: VID_00028, Pass 2 of 2
 - [01:56:10] Video Encode complete
 - [01:56:10] Reencoding audio tracks (if req'd)
 - [01:56:10] Multiplexing M2TS
 - [01:56:33] Extracting A/V streams [VID_00029]
 - [01:56:35] Reencoding: VID_00029 (27 of 40)
 - [01:56:35] Collecting video information
   - Rate/Length: 23,976fps, 386 frames
   - Bitrate: 19.877 Kbs
 - [01:56:35] Reencoding: VID_00029, Pass 1 of 2
 - [01:56:48] Reencoding: VID_00029, Pass 2 of 2
 - [01:57:37] Video Encode complete
 - [01:57:37] Reencoding audio tracks (if req'd)
 - [01:57:37] Multiplexing M2TS
 - [01:57:39] Extracting A/V streams [VID_00030]
 - [01:57:43] Reencoding: VID_00030 (28 of 40)
 - [01:57:43] Collecting video information
   - Rate/Length: 23,976fps, 1.078 frames
   - Bitrate: 15.211 Kbs
 - [01:57:43] Reencoding: VID_00030, Pass 1 of 2
 - [01:58:15] Reencoding: VID_00030, Pass 2 of 2
 - [02:00:19] Video Encode complete
 - [02:00:19] Reencoding audio tracks (if req'd)
 - [02:00:19] Multiplexing M2TS
 - [02:00:22] Extracting A/V streams [VID_00031]
 - [02:00:35] Reencoding: VID_00031 (29 of 40)
 - [02:00:35] Collecting video information
   - Bitrate: 20.954 Kbs
 - [02:00:35] Reencoding: VID_00031, Pass 1 of 2
 - [02:02:28] Reencoding: VID_00031, Pass 2 of 2
 - [02:10:08] Video Encode complete
 - [02:10:08] Reencoding audio tracks (if req'd)
 - [02:10:08] Multiplexing M2TS
 - [02:10:22] Extracting A/V streams [VID_00032]
 - [02:10:27] Reencoding: VID_00032 (30 of 40)
 - [02:10:27] Collecting video information
   - Rate/Length: 23,976fps, 1.451 frames
   - Bitrate: 18.454 Kbs
 - [02:10:27] Reencoding: VID_00032, Pass 1 of 2
 - [02:11:19] Reencoding: VID_00032, Pass 2 of 2
 - [02:14:17] Video Encode complete
 - [02:14:17] Reencoding audio tracks (if req'd)
 - [02:14:17] Multiplexing M2TS
Ch3vr0n is offline   Reply With Quote
Old 1st August 2010, 17:12   #8975  |  Link
Ch3vr0n
 - [02:14:22] Extracting A/V streams [VID_00033]
 - [02:14:30] Reencoding: VID_00033 (31 of 40)
 - [02:14:30] Collecting video information
   - Rate/Length: 23,976fps, 2.292 frames
   - Bitrate: 18.247 Kbs
 - [02:14:30] Reencoding: VID_00033, Pass 1 of 2
 - [02:15:44] Reencoding: VID_00033, Pass 2 of 2
 - [02:20:25] Video Encode complete
 - [02:20:25] Reencoding audio tracks (if req'd)
 - [02:20:25] Multiplexing M2TS
 - [02:20:33] Extracting A/V streams [VID_00034]
 - [02:21:26] Reencoding: VID_00034 (32 of 40)
 - [02:21:26] Collecting video information
   - Rate/Length: 23,976fps, 15.114 frames
   - Bitrate: 20.366 Kbs
 - [02:21:26] Reencoding: VID_00034, Pass 1 of 2
 - [02:29:43] Reencoding: VID_00034, Pass 2 of 2
 - [03:03:39] Video Encode complete
 - [03:03:39] Reencoding audio tracks (if req'd)
 - [03:03:39] Multiplexing M2TS
 - [03:04:49] Extracting A/V streams [VID_00036]
 - [03:04:53] Reencoding: VID_00036 (33 of 40)
 - [03:04:53] Collecting video information
   - Rate/Length: 23,976fps, 521 frames
   - Bitrate: 18.014 Kbs
 - [03:04:53] Reencoding: VID_00036, Pass 1 of 2
 - [03:05:12] Reencoding: VID_00036, Pass 2 of 2
 - [03:06:13] Video Encode complete
 - [03:06:13] Reencoding audio tracks (if req'd)
 - [03:06:13] Multiplexing M2TS
 - [03:06:15] Extracting A/V streams [VID_00037]
 - [03:06:18] Reencoding: VID_00037 (34 of 40)
 - [03:06:18] Collecting video information
   - Rate/Length: 23,976fps, 1.035 frames
   - Bitrate: 16.811 Kbs
 - [03:06:18] Reencoding: VID_00037, Pass 1 of 2
 - [03:06:54] Reencoding: VID_00037, Pass 2 of 2
 - [03:08:55] Video Encode complete
 - [03:08:55] Reencoding audio tracks (if req'd)
 - [03:08:55] Multiplexing M2TS
 - [03:08:59] Extracting A/V streams [VID_00038]
 - [03:11:10] Reencoding: VID_00038 (35 of 40)
 - [03:11:10] Collecting video information
   - Rate/Length: 23,976fps, 40.363 frames
   - Bitrate: 17.636 Kbs
 - [03:11:10] Reencoding: VID_00038, Pass 1 of 2
 - [03:30:10] Reencoding: VID_00038, Pass 2 of 2
 - [04:37:33] Video Encode complete
 - [04:37:33] Reencoding audio tracks (if req'd)
 - [04:37:33] Multiplexing M2TS
 - [04:41:09] Extracting A/V streams [VID_00055]
 - [04:41:17] Reencoding: VID_00055 (36 of 40)
 - [04:41:17] Collecting video information
   - Rate/Length: 23,976fps, 3.293 frames
   - Bitrate: 11.446 Kbs
 - [04:41:17] Reencoding: VID_00055, Pass 1 of 2
 - [04:42:58] Reencoding: VID_00055, Pass 2 of 2
 - [04:47:57] Video Encode complete
 - [04:47:57] Reencoding audio tracks (if req'd)
 - [04:47:57] Multiplexing M2TS
 - [04:48:09] Extracting A/V streams [VID_00056]
 - [04:48:17] Reencoding: VID_00056 (37 of 40)
 - [04:48:17] Collecting video information
   - Rate/Length: 23,976fps, 3.514 frames
   - Bitrate: 12.842 Kbs
 - [04:48:17] Reencoding: VID_00056, Pass 1 of 2
 - [04:50:11] Reencoding: VID_00056, Pass 2 of 2
 - [04:56:47] Video Encode complete
 - [04:56:47] Reencoding audio tracks (if req'd)
 - [04:56:47] Multiplexing M2TS
 - [04:56:59] Extracting A/V streams [VID_00057]
 - [04:57:06] Reencoding: VID_00057 (38 of 40)
 - [04:57:06] Collecting video information
   - Rate/Length: 23,976fps, 3.466 frames
   - Bitrate: 12.141 Kbs
 - [04:57:06] Reencoding: VID_00057, Pass 1 of 2
 - [04:58:57] Reencoding: VID_00057, Pass 2 of 2
 - [05:04:30] Video Encode complete
 - [05:04:31] Reencoding audio tracks (if req'd)
 - [05:04:31] Multiplexing M2TS
 - [05:04:40] Extracting A/V streams [VID_00058]
 - [05:04:43] Reencoding: VID_00058 (39 of 40)
 - [05:04:43] Collecting video information
   - Rate/Length: 23,976fps, 1.306 frames
   - Bitrate: 11.594 Kbs
 - [05:04:43] Reencoding: VID_00058, Pass 1 of 2
 - [05:05:21] Reencoding: VID_00058, Pass 2 of 2
 - [05:07:25] Video Encode complete
 - [05:07:25] Reencoding audio tracks (if req'd)
 - [05:07:25] Multiplexing M2TS
 - [05:07:28] Extracting A/V streams [VID_00060]
 - [05:07:29] Reencoding: VID_00060 (40 of 40)
 - [05:07:29] Collecting video information
   - Rate/Length: 23,976fps, 6 frames
   - Bitrate: 4.039 Kbs
 - [05:07:29] Reencoding: VID_00060, Pass 1 of 2
 - [05:07:30] Reencoding: VID_00060, Pass 2 of 2
 - [05:07:30] Video Encode complete
 - [05:07:30] Reencoding audio tracks (if req'd)
 - [05:07:30] Multiplexing M2TS
[05:07:31]PHASE ONE complete
[05:07:31]PHASE TWO - Rebuild Started
 - [05:07:31] Rebuilding BD file Structure
[05:07:35] - Encode and Rebuild complete
[05:07:35] Writing BD structure to ISO file
 - ImgBurn completed successfully
 - ALIEN_VS_PREDATOR_F2 folder removed.
 - WORKFILES folder removed.
 - Computer SHUTDOWN initiated.
- FFDSHOW: 3326, Ok
- FFDSHOW MPEG2 set to "libmpeg2":  Ok
- FFDSHOW AVC set to "ffmpeg-mt":  Ok
- X264:  Ok
- AFTEN:  Ok
- FAAC:  Ok
- MP4BOX:  Ok
- WAVI:  Ok
- TSMUXER:  Ok
Gonna retry with mpeg2 set to libavcodec
Old 1st August 2010, 17:16   #8976  |  Link
hedgerow
heres the CLASH_OF_THE_TITANS.ini too
[Status]
LABEL=CLASH_OF_THE_TITANS
VERSION=v0.34.05 (beta)
SOURCE_SIZE=41854758379
SOURCE_VIDEO_SIZE=41617680384
TARGET_SIZE=24589107200
REDUCTION=.585136628959316
RESIZE_1080=0
AUDIO_TO_KEEP=eng;
SUBS_TO_KEEP=all
BACKUP_MODE=0
MOVIEONLY_TYPE=0
QUICK=1
ENCODE_STEP=4
COMPLETED=31
REBUILD_COMPLETE=0
[00019]
AUDIO=0
PGS=11111111
M2TS_TARGET=147905164
NSIZE=150988800
FLINK=0
MLINK=0
[00023]
AUDIO=0
PGS=11111111
M2TS_TARGET=162544327
NSIZE=191975424
FLINK=0
MLINK=0
[00018]
AUDIO=0
PGS=11111111
M2TS_TARGET=187134671
NSIZE=222136320
FLINK=0
MLINK=0
[00024]
AUDIO=0
PGS=11111111
M2TS_TARGET=223480924
NSIZE=221540352
FLINK=0
MLINK=0
[00046]
AUDIO=11110000
PGS=11011111111111000000000000
M2TS_TARGET=237987069
NSIZE=131297280
FLINK=-1
MLINK=0
[00016]
AUDIO=0
PGS=11111111
M2TS_TARGET=239148280
NSIZE=274630656
FLINK=0
MLINK=0
[00022]
AUDIO=1
PGS=11111111
M2TS_TARGET=244217342
NSIZE=317036544
FLINK=0
MLINK=0
[00009]
AUDIO=0
PGS=11111111
M2TS_TARGET=244231722
NSIZE=278833152
FLINK=0
MLINK=0
[00036]
AUDIO=11000000
M2TS_TARGET=248209819
RATE=8619
NSIZE=239978496
FLINK=-1
MLINK=0
[00017]
AUDIO=0
PGS=11111111
M2TS_TARGET=251420123
NSIZE=298524672
FLINK=0
MLINK=0
[00021]
AUDIO=1
PGS=11111111
M2TS_TARGET=263476183
NSIZE=367589376
FLINK=0
MLINK=0
[00020]
AUDIO=0
PGS=11111111
M2TS_TARGET=283529536
NSIZE=356997120
FLINK=0
MLINK=0
[00038]
AUDIO=0
PGS=11111111
M2TS_TARGET=354072185
NSIZE=346073088
FLINK=0
MLINK=0
[00025]
AUDIO=01110000
M2TS_TARGET=427158742
RATE=16329
NSIZE=415266816
FLINK=-1
MLINK=0
[00043]
AUDIO=11100000
M2TS_TARGET=431736304
NSIZE=202721280
FLINK=-1
MLINK=0
[00033]
AUDIO=01100000
M2TS_TARGET=437629091
RATE=18350
NSIZE=425699328
FLINK=-1
MLINK=0
[00040]
AUDIO=01100000
M2TS_TARGET=445291257
NSIZE=92104704
FLINK=-1
MLINK=0
[00035]
AUDIO=11100000
M2TS_TARGET=483849896
RATE=11938
NSIZE=467957760
FLINK=-1
MLINK=0
[00045]
AUDIO=00111110
M2TS_TARGET=495805420
NSIZE=197910528
FLINK=-1
MLINK=0
[00047]
AUDIO=1
PGS=11111111
M2TS_TARGET=504506324
NSIZE=692238336
FLINK=0
MLINK=0
[00029]
AUDIO=01100000
M2TS_TARGET=538409467
RATE=15102
NSIZE=523370496
FLINK=-1
MLINK=0
[00030]
AUDIO=01100000
M2TS_TARGET=558639127
RATE=15550
NSIZE=544856064
FLINK=-1
MLINK=0
[00037]
AUDIO=11000000
M2TS_TARGET=619899563
RATE=2600
NSIZE=598192128
FLINK=0
MLINK=0
[00001]
AUDIO=00110000
M2TS_TARGET=640834564
RATE=17374
NSIZE=619991040
FLINK=-1
MLINK=0
[00034]
AUDIO=01100000
M2TS_TARGET=670510771
RATE=19096
NSIZE=652419072
FLINK=-1
MLINK=0
[00031]
AUDIO=01100000
M2TS_TARGET=895438483
RATE=15779
NSIZE=870979584
FLINK=-1
MLINK=0
[00041]
AUDIO=01100000
M2TS_TARGET=1123863531
RATE=12705
NSIZE=1096341504
FLINK=-1
MLINK=0
[00048]
AUDIO=1
PGS=11111111
M2TS_TARGET=1238566251
RATE=8018
NSIZE=1211633664
FLINK=0
MLINK=0
[00026]
AUDIO=00110000
M2TS_TARGET=1393021896
RATE=15271
NSIZE=1352312832
FLINK=-1
MLINK=0
[00042]
AUDIO=01100000
M2TS_TARGET=1493264310
RATE=12679
NSIZE=1455458304
FLINK=-1
MLINK=0
[00028]
AUDIO=01100000
M2TS_TARGET=1777591610
RATE=16804
NSIZE=1728479232
FLINK=-1
MLINK=0
[00044]
AUDIO=00000111
M2TS_TARGET=2127690703
RATE=12625
Old 1st August 2010, 18:51   #8977  |  Link
jdobbs
Yes. It fixes it.
Old 1st August 2010, 18:55   #8978  |  Link
stonej01
need a little help, i have changed nothing and now my encodes keep failing. Trying currently on Watchmen. This same message in both version 34.04 and 34.05 i just encoded Brooklyn's Finest a few days ago with no issue. Full backup not movie only
[13:44:15] BD Rebuilder v0.34.05 (beta)
  - Source:  WATCHMEN_-_BR
  - Input BD size: 39.79 GB
  - Approximate total content: [04:30:56.990]
  - Auto Quality: Good (Very Fast), Two Pass
  - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640
[13:44:19] PHASE ONE, Encoding
 - [13:44:19] Extracting A/V streams [VID_00524]
 - [13:44:19] Reencoding: VID_00524 (1 of 50)
 - [13:44:19] Reencoding secondary video [TRK_02]
 - [13:44:20] Collecting video information
   - Rate/Length: 23.976fps, 29 frames
   - Bitrate: 1,488 Kbs
 - [13:44:20] Reencoding: VID_00524, Pass 1 of 2
  - Encode failed.  Retrying.
  - Reached retry limit.  Aborting.
  - BD-Rebuilder v0.34.05 (beta)
  - FFDSHOW: 3326, Ok
  - X264:  Ok
  - AFTEN:  Ok
  - FAAC:  Ok
  - MP4BOX:  Ok
  - WAVI:  Ok
  - TSMUXER:  Ok
[13:47:23] - Failed video encode, aborted
stonej01 is offline   Reply With Quote
Old 1st August 2010, 19:04   #8979  |  Link
jdobbs
  - FFDSHOW: 3326, Ok
  - X264:  Ok
  - AFTEN:  Ok
  - FAAC:  Ok
  - MP4BOX:  Ok
  - WAVI:  Ok
  - TSMUXER:  Ok
Well, something has changed... my guess is that something installed has taken over VC-1 decoding. I'd reinstall BD Rebuilder and all components.
Have you changed the minimum M2TS size to be modified? 29 frames seems small to even be included in the job. I guess it could be multi-part, but I've never seen a 29 frame segment in a multi-part feature.
Old 1st August 2010, 19:13   #8980  |  Link
colinhunt
jdobbs, sorry for harping on about this topic but I'd like to go over the "no encoding required" and space calculation method a bit more. Do you happen to have in your arsenal the US version of Astro Boy? It's the perfect title for finetuning this.
Movie-only playlist (00001.MPLS) contains a single file (00001.M2TS) which has a size of 25 403 062 272 bytes. In addition to video, it contains an English DTS-HD MA track and a Spanish Dolby Digital 640kbps track, as well as English and Spanish subs.
Using BD-RB 0.34.05, I set custom output to 24100MB (which actually wouldn't fit on a BD25 which is 25 025 314 816 bytes, i.e. 23866MB - if I calculated correctly) and told BD-RB to do a movie-only backup while keeping HD audio, but dropping Spanish audio and subs. Here's what the .INF says:
SOURCE_SIZE=25403062272
SOURCE_VIDEO_SIZE=25403062272
TARGET_SIZE=25270681600
REDUCTION=.994788790792915
Since REDUCTION is less than 1, BD-RB would actually re-encode the video, correct? So, for s**** and giggles I aborted processing and entered a custom output size of 25550MB. INF reported a value higher than 1, and no re-encoding was done. Total output (directories etc. included) came to 24 859 136 164 bytes, i.e. 23707.52MB which fits on a BD25.
Now, I'm aware that BD-RB has to estimate certain things and there are overheads etc. to factor in, and the whole shebang is much more complicated than I can fathom. I just wanted to show by this example that there's still some room for improvement, that's all.
colinhunt is offline   Reply With Quote
