20th July 2018, 15:28 | #15924 | Link |
You can't restore information which wasn't present in source. It is like having 2d image and asking how to convert to true 3d stereoscopic format.
23rd July 2018, 16:33 | #15925 | Link | |
ByteShare
As it has already been pointed out, you're trying to add info that never existed, like upscaling or something along those lines. Maybe in the future there will be some great script for this but not yet. |
27th July 2018, 08:59 | #15926 | Link |
ByteShare
Incorrect Characters
Not sure why but RipBot is changing
é Code:
Θ The filename displays correctly in the queue. I'm having this issue on a Windows 10 machine. Using RipBot Core 2018.07.11 Example: Code:
Pokémon XYZ - 0889 - From A to Z! [iTunes DL 1080p] (Arian) Code:
PokΘmon XYZ - 0889 - From A to Z! [iTunes DL 1080p] (Arian) Last edited by byteshare; 30th July 2018 at 16:30. |
8th August 2018, 08:40 | #15927 | Link |
So I have a question about the final process of Ripbot, the Muxing of the files.
What is used to do this, as it seems to be only a single threaded utility.... I am just finishing off the longest encode I have EVER done with Ripbot, a 60 Mb/s (original is 48.7 Mb/s), x265, 10bit, 4K encode of the the near 3 hour extended Avatar, it has taken many days (but not 24 hour days) to do this, and it's taking forever to Mux it all back together. Is it possible to use a multi threaded process to do this ??? There has to be a better / faster way !!! I might try a few different "tool's" to mux the files that Ripbot creates in the Jobs folders, and see how long it takes. OK, it's just finished successfully , and now I think I know why it takes so long....if I check the video file in the Jobs folder, it's still the original bitrate, but the finished encode has the higher bitrate, according to MediaInfo. Last edited by burt123; 8th August 2018 at 08:56. |
8th August 2018, 09:00 | #15928 | Link | |
8th August 2018, 13:03 | #15930 | Link |
I hope you are just trolling us now
8th August 2018, 14:31 | #15932 | Link |
mkvmerge.exe or mp4box.exe
8th August 2018, 15:05 | #15936 | Link |
Fastest would be muxing with 2 SSDs, one source and one target. But muxing itself will take only little time. Most time is spent in video encoding. So if you want to speed up things you need: faster CPU and/or lower encoding settings (or faster encoder like x264). Or GPU encoding (but which can impact quality/compression negatively).
Of course converting original 48.7 Mb/s to 60 Mb/s is retarded anyways ... |
8th August 2018, 15:13 | #15937 | Link | |
Nice to know you read my thread Not retarded, just testing the limits, but it does make a difference However, a lot of high end 2160p 4K video's are around the 50 - 60 Mb/s bitrate !! Even encoding at the original, would still take a long time. |
8th August 2018, 16:17 | #15938 | Link | |
ByteShare
Also, you should not be seeing increased quality with just raising the bitrate. My guess, is some of the filters you used or the slight filtering process that encodes use is what you're seeing for the difference. |
8th August 2018, 17:05 | #15939 | Link | |
9th August 2018, 02:00 | #15940 | Link | ||
